»RSS Benchmark sajt
      Strana 7 od 8 PrvaPrva ... 345678 PoslednjaPoslednja
      Prikazani rezultati od 91 do 105 od ukupno 118
      Tema: Onemogućen pristup sajtu Benchmark foruma
      1. #91
        Member Avatar korisnika Villy_Da_Man
        Na forumu od
        Feb 2005
        Lokacija
        Subotica
        Poruka
        2.057
      2. Moja mašina
        • CPU: Ryzen 2600x + tražim cooler
        • MoBo: MSI Tomahawk MAX B450
        • RAM: 16GB (2x8GB) DDR4/3600 ADATA XPG SPECTRIX D41, CL17, RGB
        • VGA: 5600XT Sapphire pulse 6GB
        • MON: Hp 23,9" IPS FHD with Corsair LS100
        • HDD: M.2. 960 EVO 256GB/3x4TB Seagate + NAS 3x4TB WD RED
        • OPT: Samsung SATA external
        • Case: Fractal Define S + CM V750 custom sleeved cables
        • SND: DAC Oppo HA2+Xonar DSX w OP AMP 4562+Microlab SOLO 6C+KEF M500 HiFI HP+Sony zx770bn BT HP
        • OS: Win10
        • LAP: Toshiba i5 6200U, GTX930M, 16GB, 256GB SSD
        • TV: Sony ZG9 Master Series 8K 88" + KD65 XF9005 4K HDR Android, Philips 55PUS6162/12 4K
        • INET: DSL
        • Ostalo: Corsair iCUE RGB sync setup:K70 RGB MK2 SE/ Dark Core RGB PRO SE/RGB Display Band LS100 + PS4PRO
      3. Popravite Ryzen 5 temu u cpu podforumu. Može da se postuje, ali ne može da se vidi zadnja strana. Ovako je već danima
        I'm BI-WINNING!!! Win here, win there win everywhere!
      4. #92
        Newcomers
        Na forumu od
        Oct 2017
        Poruka
        197
        Pokušao da postavim novu temu, dobio poruku "You don't have permission to access /showthread.php on this server."
        Vidim da je tema i pored toga postavljena, ali ne mogu da joj pristupim...
      5. #93
        Member Avatar korisnika CountMike
        Na forumu od
        Jul 2012
        Lokacija
        Beograd. Toronto
        Poruka
        7.175
      6. Moja mašina
        • CPU: Ryzen R7 3700X, CM Nepton 140XL
        • MoBo: Asus PRIME X470 PRO
        • RAM: 2x8GB Kingston Predator 3600MHz
        • VGA: Asus strix 570 OC 4gb
        • MON: BenQ 28" + 2x Samsung 2494
        • HDD: Samsung 960Evo, 250GB, SP V70 240GB, WD Blue 2TB,WD Blue 1TB
        • Case: Raidmax Agusta (customized)
        • SND: On Board
        • OS: Win 10 Pro, Linux Mint
      7. #94
        Member
        Na forumu od
        Sep 2005
        Poruka
        1.359
      8. Moja mašina
        • CPU: Intel G4560
        • MoBo: Asus Strix H270F Gaming
        • RAM: Kingston HyperX 8G 2400 MHz
        • VGA: Intel HD Graphics
        • MON: Dell P2414H
        • HDD: Transcend 256GB 370S, 3x 3TB
        • Case: Fractal Design Define R5, Chieftec 600W
        • SND: Integrusa/Microlab Solo 7C
        • OS: Windows 10 Pro x64
        • TV: LG 47LA620S
        • INET: Bez interneta
      9. Ovde isto https://forum.benchmark.rs/showthrea...-konfiguracije
        Edit: Mike i ja u isto vreme
      10. #95
        Newcomers
        Na forumu od
        Oct 2017
        Poruka
        197
        Da li postoji neko rešenje za ovaj problem?
        Bar da moderatori obrišu temu, kad je već nedostupna
      11. #96
        Member Avatar korisnika poolmaker
        Na forumu od
        Apr 2013
        Lokacija
        Sombor
        Poruka
        9.136
      12. Moja mašina
        • CPU: Intel i5-4690K
        • MoBo: Asus Z97M-PLUS
        • RAM: 2x4GB Kingston HyperX
        • MON: HP Pavilion 23xi
        • HDD: Samsung 850 EVO 250GB, HDD Western Digital 2TB
        • Case: Fractal Design Arc Mini, Seasonic M12II-520 EVO
        • SND: Microlab Solo 6C
        • OS: Windows 10 LTSC x64
      13. Napravi novu, obrisaće staru.
      14. #97
        Newcomers
        Na forumu od
        Oct 2017
        Poruka
        197
        Ne mogu ni novu da napravim, tj. mogao bih, ali bi bio isti slučaj, probao sam...
        Odustajem
      15. #98
        Member Avatar korisnika C4in
        Na forumu od
        May 2005
        Lokacija
        NBG
        Poruka
        2.070
      16. Moja mašina
        • CPU: Ryzen 5 1600X
        • MoBo: Asus ROG STRIX B350-F GAMING
        • RAM: GSkill Ripjaws V F4-3200C16D-16GVK, Patriot Viper 4 Blackout Series DDR4 16GB (2 x 8GB) 3600MHz
        • VGA: XFX R9 270x
        • MON: Samsung 223BW
        • HDD: Adata XPG Gammix S11 Pro M.2 NVMe 1TB, SSD Samsung EVO 250GB, WD 640GB, Transcend externi 320GB
        • OPT: Samsung s223c
        • Case: TT Kandalf LCS + OCZ SXS 600W
        • SND: Asus Xonar DSX
        • OS: Windows 10 64bit
        • INET: DSL
      17. Citat Citiram korisnika: Villy_Da_Man Pogledaj poruku
        +1
      18. #99
        Member Avatar korisnika djalf
        Na forumu od
        Nov 2004
        Poruka
        6.790
      19. Moja mašina
        • CPU: Ryzen 5 2600
        • MoBo: MSI B450M Gaming Plus
        • RAM: G.Skill TridentZ RGB 2X8GB DDR4 3200MHz
        • VGA: Gigabyte RX570 4GB Aorus
        • MON: Dell 23" IPS Full HD
        • HDD: Kingston A1000 480GB M.2 NVMe
        • OPT: Šta to beše?
        • Case: Acer Predator G7200 Blue, Delta 600W
        • OS: Windows 10 Pro 1909
        • LAP: Lenovo Thinkpad T440p
        • TV: Samsung 40" Full HD
        • INET: Kablovska
      20. Kad ce ovo biti sredjeno:
        https://forum.benchmark.rs/showthrea...postu)/page146
        Radi do 145 strane.
      21. #100
        Member Avatar korisnika Lanikor
        Na forumu od
        May 2016
        Poruka
        2.677
      22. Moja mašina
        • CPU: Intel i7 4700HQ 2.4 GHz (3.4 TurboBoost)
        • MoBo: Intel HM 86 Mobile Chipset
        • RAM: 16 GB (2 x 8 GB) DDR3L Samsung 1600 MHz
        • VGA: Intel HD 4600 + Nvidia GTX 850M 2 GB DDR3
        • MON: Full HD 1920x1080 15.6"
        • HDD: Intel 545s 256GB SSD + Hitachi HDD 1.5 TB 5400 rpm
        • OS: Windows 10 Pro 64 bit
        • LAP: ASUS N550JK
        • Ostalo: Xiaomi Mi Max 3
      23. Treba da se spamuje preko TT ili da se udje preko browsera na npr 1 ili 145 stranu pa da se pise da bi preslo zbog novih postova na 147 stranu pa da vidimo sta ce da se desi.
        Inace vec odavno stoji na toj strani, ja sam napisao jedno 5-6 postova sa tom namerom danas a treba 15 po defaultu da predje na narednu stranu.
        EDIT: Proradila tema kad je napisan post za 147-u stranu, ako gleda neki moderator da zna zasto je spamovano
        Menjao Lanikor : 07.03.2020. u 14:45
      24. #101
        Na forumu od
        Nov 2004
        Poruka
        6.790
      25. Moja mašina
        • CPU: Ryzen 5 2600
        • OPT: Šta to beše?
        • INET: Kablovska
      26. Dobra ideja, sad ce da te banuju
      27. #102
        Na forumu od
        May 2016
        Poruka
        2.677
      28. Moja mašina
        • LAP: ASUS N550JK
      29. Pamtite me po pesmama mojim
      30. #103
        Member Avatar korisnika terzazak
        Na forumu od
        Feb 2007
        Lokacija
        Niš
        Poruka
        1.611
      31. Moja mašina
        • CPU: AMD Phenom II 965, Xigmatek S1284
        • MoBo: GA-790FXT-UD5P
        • RAM: Geil GV34GB1600C8DC
        • VGA: Zotac 1060 3GB AMP
        • MON: Benq G2420HD
        • HDD: 850 evo 500gb+WD640+1,5TB HD153WI+3TB P300
        • OPT: Samsung 222f/BEBE
        • Case: CM 690+Chieftec 750W-14cs
        • OS: Win 10, Bitdefender
        • TV: LG 32LH3000, EON full
        • INET: Kablovska
        • Ostalo: Xiaomi Redmi 4 prime
      32. Ne pomazu pesme, opet ne radi, mozda da zapevamo neku uz bubnjeve..
        Nisam u pravu radi, jedino pretposlednja stranica ne, mozda zbog spama..
        Menjao terzazak : 07.03.2020. u 15:21
        Ko sanjari drhti. Ko drhti sanjari ili mu je hladno.
      33. #104
        Na forumu od
        May 2016
        Poruka
        2.677
      34. Moja mašina
        • LAP: ASUS N550JK
      35. Radi sve osim 146 strane, ta strana je ukleta, sva sreca pa je i moj spam u njoj
      36. #105
        Member Avatar korisnika vladat1
        Na forumu od
        Nov 2004
        Lokacija
        Srednje Pomoravlje
        Poruka
        4.777
      37. Moja mašina
        • CPU: I5 6500
        • MoBo: MSI B150M MORTAR
        • RAM: Kingston DDR4 16GB
        • VGA: GeForce GTX 1060 GAMING X 6G
        • MON: ASUS LED 23" VX239H
        • HDD: Samsung F4 2TB, SSD Kingston 128 GB
        • OPT: HL-DT-ST DVD-RAM GSA-H58N
        • Case: Cooler Master - HAF 912
        • SND: SMSL 8a + AR 98LS + A 8650
        • OS: Windows 10 Pro 64-bit
        • LAP: Toshiba Satellite® C650
        • TV: ASUS LED 23" VX239H
        • INET: DSL
        • Ostalo: Hisense H40B5600
      38. Imam problem sa sertifikatom. Kaže da je istekao
        Menjao vladat1 : 06.05.2020. u 08:21
        Goli Otok .... Kako to nudistički zvuči ...
        Pobeda je čista kao suza jer mrtva usta ne govore.
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
