ASUS TUF Gaming VG27AQ Monitor
cocacola
Banned
Banovan
TUF Gaming VG27AQ HDR Gaming Monitor – 27 inch WQHD (2560x1440), IPS, 165Hz*, Extreme Low Motion Blur Sync G-SYNC Compatible, Adaptive-Sync, 1ms (MPRT), HDR10
27-inch WQHD (2560x1440) IPS gaming monitor with ultrafast 165*Hz refresh rate designed for professional gamers and immersive gameplay.
ASUS Extreme Low Motion Blur Sync (ELMB SYNC) technology enables a 1ms response time (MPRT) together with G-SYNC Compatible, eliminating ghosting and tearing for sharp gaming visuals with high frame rates.
Certified as G-SYNC Compatible, delivering a seamless, tear-free gaming experience by enabling VRR (variable refresh rate) by default.
Compatible with industry-standard HDR10 high dynamic range for color and brightness levels that exceed the capabilities of ordinary monitors.
Features an ergonomically designed stand to offer extensive swivel, tilt and height pivot adjustments.
Po meni idealan monitor, kojeg sam vlasnik i mogu vam reci da je slika perfekcija i sve radi kako je navedeno, samo mi nije jasan hdr ali nisam ga jos dobro ni probao, treba vremena da sve ispitam ali sam prvi utisak je vaoooo :D
Gdje si ga kupio i po kojoj cjeni?
Sent from my SM-A505FN using Tapatalk
Ne postoji hdr na monitorima, to jest, kao da ne postoji, nema ga poente koristiti.
Sent from my SM-N975F using Tapatalk
Nema poente za HDR-om sem u par igara gde je to skroz korektno implementirano. Recimo probaj Far Cry 5, tu HDR bukvalno izuvaa ;)
