Koja je svrha tog zakrivljenog ekrana? Jel ima neku funkciju sem sto izgleda fensi, mene je malo zakrivljenje iritiralo na xz premium.
zanima me tehnologija iza slow motion 7000 i kusur fpsa kako su to izveli, hardware ili software?
Nije prevara to koristiti u marketinske svrhe.
Sta je onda Apple event? 5h duze trajanje baterije, kako da ne.
A tek Samsung... Dva cipseta za razlicita trzista, ako to nije prevara onda ne znam sta jeste. [emoji4]
Ali da ne idemo bez potrebe u off. Jos jednom, lagano mob godine ako se resi situacija oko servisa. [emoji4]
Mozda Apple moze imati kompletan mob, ali u nekom drugom zivotu i trzistu.
Ma uopste nije prevara :d Da li je realno sta ljudi sve opravdavaju danas, nije ni cudo sto je huawei dobio toliko ratobornih sledbenika za kratko vreme.
Mob. godine? Mozda, posle ajfona 11 pro max (najkompletnijeg uredjaja na trzistu), Samsunga Note 10+, OnePlus 7 Pro.
A čekajte ljudi niko da pomene da oni u okviru svog SoC imaju 5g rešenje ?
Pa to je veća inovacija od svih inovacija u poslednjih par godina.
A mi pričamo ovde o telefonima koji 3 godine furaju isti dizajn..
https://www.anandtech.com/show/1485...-990-5g-dual-soc-approach-integrated-5g-modem
We bang on consistently about 5G, because that is where a lot of mobile infrastructure and investment is going. Back at Mobile World Congress in February, we covered every company that had announced its own discrete 5G modem – a chip that was added to a device in order to enable 5G. This typically meant that we had a standard processing chip with 4G, and then an extra 5G support chip on top. Ultimately to get the best performance, the 5G chip should be integrated on the same silicon, enabling better efficiency in 5G mode in exchange for die area and design complexity.
True to form, Huawei (and its design arm, HiSilicon), are the first to do it for the smartphone market.
Za Evropu da ali za Aziju ne..https://www.europarl.europa.eu/RegData/etudes/IDAN/2019/631060/IPOL_IDA(2019)631060_EN.pdf
Strane 13 - 25 da bio shvatio koliko je 5G bitan sem na nivou papirnih specifikacija i vikanja "omali su prvi". Tehnološki super i zasita svaka čast, praktično kompletno beskorisno.
Moze, i onda na brzinu neki custom rom. To bi bilo najboljeOčekivana vest. Dozvoliće unlock bootloadera, a posle kad se situacija u trgovinskom ratu promeni oduzeće tu mogućnost korisnicima.
Yes, Huawei is planning to let you unlock the Huawei Mate 30 bootloader
2.2. China
China has invested in a 5G national action plan to orchestrate its industry R&D and deployment efforts
through central government support. Its 5G investments have been organised since 2015 at national
level through the three state-owned mobile operators – China Mobile, China Unicom and China
Telecom. A broad commercial launch of 5G by 2020 is aimed at in the country’s latest Five-Year Plan
and China’s telecoms operators are automatically committed to such targets. In December 2019,
operating licences for 5G were issued to all three MNOs.
China Telecom received 3.4-3.5 GHz and China Unicom was awarded 3.5-3.6 GHz (Handford, 2019). The
latter bands are commonly being seen as leading frequencies for 5G, in the EU and elsewhere.
Moreover, each MNO in China has a different date for its prospective commercial launch, with 2019 for
China Mobile, but sometime in 2020 for China Unicom and China Telecom. However closer analysis
reveals four other crucial influences on the 5G rollout programme:
• The research effort called for under the 5G initiative has a much longer timeframe –to 2025 and
beyond to 2030 for the final developments – because the technical challenges are considered
to be so significant. These may demand rethinking some basic premises of mobile technology
theory. China Mobile’s 2016 presentation of the reworking of the whole mobile model
(Blackman and Forge, 2016) indicates a number of significant highly technical hurdles, ranging
from rethinking antenna engineering for dynamic MIMO beamforming to the basic cellular
model and Shannon’s theory of communications capacity
Kad već udaraš opomene, onda bar prouči materiju malo bolje a ne da vređaš ljude po forumima i pišeš svašta u android temi, sa kojom nemaš mnogo dodirnih tačaka.https://www.europarl.europa.eu/RegData/etudes/IDAN/2019/631060/IPOL_IDA(2019)631060_EN.pdf
