»RSS Benchmark sajt
      Strana 3 od 3 PrvaPrva 123
      Prikazani rezultati od 31 do 43 od ukupno 43
      Tema: u cemu je uopste poenta OC u ovom slucaju?
      1. #31
        Member
        Na forumu od
        Oct 2003
        Lokacija
        Beograd
        Poruka
        2.519
      2. Moja mašina
        • CPU: Ryzen 2600
        • MoBo: Asrock B450M Pro 4
        • RAM: 2x8GB Kingston Predator 3200Mhz
        • VGA: GTX 1060 3GB
        • MON: AOC C24G1 24"/bravia xe8096 55"/FOX TV 50DLE888 50"
        • HDD: 256gb ssd/480gb ssd/2x1tb hdd
        • Case: Chieftec
        • SND: integrale :)
        • OS: win7 64bit/OSX High Sierra
        • LAP: MacBook Pro/HP Elitebook 8570P
        • INET: Kablovska
        • Ostalo: PS4 Pro/iMac upgraded to i7
      3. cek za CPU features, da restartujem komp, za jedno po sata cu, nesto cackam sad za firmu.....
        ooga....
      4. #32
        Newcomers
        Na forumu od
        Aug 2018
        Lokacija
        Beograd, Vracar
        Poruka
        982
      5. Moja mašina
        • CPU: AMD Ryzen 5 2600X 3.6 GHz (4.2GHz), LC-CC-120 RGB
        • MoBo: Msi B450 Tomahawk
        • RAM: HyperX Predator 3000MHz CL15 16gb DDR4 RGB
        • VGA: GEFORCE GTX 1060 6gb
        • MON: LG 29WK500 UltraWide™IPS monitor
        • HDD: Kingston A1000 240gb NVMe
        • Case: NZXT H500, Seasonic m12 2 Evo Edition 520w 80+ bronze
        • SND: Logitech Z207 Bluetooth
        • OS: Win 10 Pro 64
        • Ostalo: Red Dragon k552 mechanical gaming keyboard + k552 gaming mouse + Redragon Suzaku Gaming Mousepad
      6. Aha pa isti cooler imamo
      7. #33
        Member
        Na forumu od
        Oct 2003
        Lokacija
        Beograd
        Poruka
        2.519
      8. Moja mašina
        • CPU: Ryzen 2600
        • VGA: GTX 1060 3GB
        • Case: Chieftec
        • SND: integrale :)
        • INET: Kablovska
      9. evo ti slike, cpu features, i ono nije na PWM za vent, vec auto detect, nego su u sva 4 slucaja bile podesene brzine na 100% pa sam to malo prepravio
        Click image for larger version.
ID:	272563Click image for larger version.
        ooga....
      10. #34
        Member
        Na forumu od
        Oct 2003
        Lokacija
        Beograd
        Poruka
        2.519
      11. Moja mašina
        • CPU: Ryzen 2600
        • VGA: GTX 1060 3GB
        • Case: Chieftec
        • SND: integrale :)
        • INET: Kablovska
      12. @DusanMilosevic - isproba li test?
        ooga....
      13. #35
        Member Avatar korisnika ivanbass1
        Na forumu od
        Apr 2016
        Lokacija
        Nis
        Poruka
        8.162
      14. Moja mašina
        • CPU: Ryzen 5 2600@4.0GHz, LC-CC-120 Push/Pull
        • MoBo: Msi X370 Krait Gaming
        • RAM: G.Skill Aegis 2x8GB 3000MHz CL16
        • VGA: 5700 XT MSI Gaming X
        • MON: AOC Q3279VWFD8
        • HDD: Patriot Ignite 240GB, WD Blue 500GB, Toshiba P300 3TB
        • OPT: Izbaceno zbog beskorisnosti
        • Case: NZXT S340 Elite 2x Arctic P14, 1x Arctic F12, Antec VP700P
        • SND: Microlab Solo 6C, Hyperx Cloud II
        • OS: Windows 10 64bit
        • LAP: Asus Vivobook Pro (i7 8750H, 2x8GB, GTX 1050 4GB, 1080p IPS)
        • Ostalo: HyperX Alloy FPS Pro MX Blue+Logitech g403, Sandberg XXXL
      15. Nikad pregledniji bios, eh da im je svaki ovakav, a ne oni raspadi.
      16. #36
        Newcomers
        Na forumu od
        Aug 2018
        Lokacija
        Beograd, Vracar
        Poruka
        982
      17. Moja mašina
        • OS: Win 10 Pro 64
      18. Nece da prodje test, kako imam cudnu stvar pa to je strasno boostuje V kad ne treba, a kad treba obara, ako pogledate moje slike gore kada je aktiviran game boost mod radi na 4050ghz odprilike na 1.3-1.32V a ne podize V za load i pada test tj iskljuci se racunar...
        kada je sve na stocku u idle mi boostuje na 1.45-1.5V a pri loadu pada na normalnih 1.35 i radi normalno naprimer nista meni ovde nije jasno. Majke mi, dobar je bios pregledan, funkcionalan samo se plasim da mi nesto nije on zabo... jel se razlikuje reset podesavanja iz biosa ili vadjenje baterije? Ne znam sta da radim. Masom se javljaju po netu sa problemima slicnim mom. Ali svi ili odustanu ili nekako im nestane problem sa updatom windowsa ili neka glupost ja sam apsolutno sve probao sto sam znao i mogao. Svi najnoviji driveri, 1903 verzija win-a.. ryzen plan, balanced plan, stalno ide u idlu na 1.4,5,6,7,8V
        Naravno spusta ga i na minimum procesor kada promenin u planu ali sta god da radim on ga zakuca gore..
        ukljucim c-state, iskljucim PBO, sve ostaje isto..
        Jedino kad iskljucim core boost onda je super radi na stock vrednostima i 1.1-1.3V ali nema boost onda i ne pomera se sa te tacke (3600)
        Poludecu majke mi
      19. #37
        Member
        Na forumu od
        Oct 2003
        Lokacija
        Beograd
        Poruka
        2.519
      20. Moja mašina
        • CPU: Ryzen 2600
        • VGA: GTX 1060 3GB
        • Case: Chieftec
        • SND: integrale :)
        • INET: Kablovska
      21. ja bi ti sad tu rekao da je win10 smece, ali skocice odmah njih 20 da mi govore kako nisam u pravu i nemam pojma.....
        ovo ti govorim iz licnog iskustva gde mi je na laptopu posle nekog apdejta win10 sve poludelo, od upotrebe cpu u IDLE pa svega ostalog, da mi je doslo da polupam laptop i gomile drugih nebuloza na kompovima na poslu koji su na win10, a vidim da ti jesi na win10...... onog trenutka kad bude prestalo sve da funkcionise na win7, a ne budu izbacili neku normalnu verziju win-a, prodacu PC i koristicu samo macbook i ps4 pro ili ps5 kad izadje za igre.....
        razmisli da se vratis na win7?
        Menjao oogabooga : 24.07.2019. u 07:14
        ooga....
      22. #38
        Na forumu od
        Apr 2016
        Lokacija
        Nis
        Poruka
        8.162
      23. Moja mašina
      24. Naravno da nisi u pravu, bios daje napone i ako izlazi crn ekran pri opterecenju ili puca znaci da je premalo napona u 99% slucaja.
        Ima sve lepo objasnjeno u prvih nekoliko poruka u Ryzen 5 temi, ali treba neko da procita
      25. #39
        Member
        Na forumu od
        Oct 2003
        Lokacija
        Beograd
        Poruka
        2.519
      26. Moja mašina
        • CPU: Ryzen 2600
        • VGA: GTX 1060 3GB
        • Case: Chieftec
        • SND: integrale :)
        • INET: Kablovska
      27. pa meni ne puca, puca Dusanu, pa nisam ni citao....
        a to za premalo napona znam po igrama, dok mi je bio OC na 4GHz, samo kad je bilo na 1.4125V nije pucalo, komp je radio i na 1.35V i na 1.375, cak i na manje V, ali posle 3 minuta u bilo kojoj igri se zablokirao.....
        ooga....
      28. #40
        Newcomers
        Na forumu od
        Aug 2018
        Lokacija
        Beograd, Vracar
        Poruka
        982
      29. Moja mašina
        • OS: Win 10 Pro 64
      30. Procitao sam 100x sve sto si pisao veruj mi u toj temi. Gore sam napisao da mi na auto oc daje premalo napona i puca komp - crn ekran.. ne podize napone dok podize clockove
        a na stock ide do 1.5v sto ne bi bilo strasno da su peakovi vec konstantno radi na preko 1.44
        Kada mu smanjim minimum proc state. On ide dole ali ne menja se nista u gornjim granicama i ide do 1.5...
        Sve sam ja procitao, ali nije mi jasno da ne mogu da imam stock vrednosti procesora.
        Hocu 3.6 ghz sa boostom na 4.2 i normalnim naponom! Necu da mi stalno bude ili na 800 ili na 4199 na 1.5v
      31. #41
        Na forumu od
        Apr 2016
        Lokacija
        Nis
        Poruka
        8.162
      32. Moja mašina
      33. Stavi 4.2GHz i fiksiraj napon na 1.35-1.38V u zavisnosti od procesora i ne brigaj.
        Nisam ja pisao, moja poruka je pregazena tom porukom, mod ubacio Caridze-ov preveden FAQ.
      34. #42
        Newcomers
        Na forumu od
        Aug 2018
        Lokacija
        Beograd, Vracar
        Poruka
        982
      35. Moja mašina
        • OS: Win 10 Pro 64
      36. u cemu je uopste poenta OC u ovom slucaju?
        svejedno te smatram jednim od mojih gurua od kad sam se uclanio ovde, dosta znas i postujem takve ljude, dosta sam naucio citajuci tvoje postove, uradicu to, ili cu ga ostaviti ovako pa nek radi dok ne crkne a nece sigurno 2 godine dok ne izbace nove biose, nove win update, drivere nesto ce se promeniti
        Jel moze napajanje da pravi problem ovakav? novo je, ali je seasonic m12 2 evo edition 520w bronze 80+ ne znam da li mu je slabasna struja? ili ima veze naponski kablovi posto sam stavljao extendere mixerove... mozda tu nesto ne valja?
        Menjao DusanMilosevic : 24.07.2019. u 13:29
      37. #43
        Na forumu od
        Apr 2016
        Lokacija
        Nis
        Poruka
        8.162
      38. Moja mašina
      39. Ploca (bios) daje napon procesoru, MSI-jev game boost ako puca znaci da nisu napravili kako treba (sto je ovde slucaj koliko vidim). Ionako su auto-OC opcije tupavo resenje, ne moze to biti stabilno (u smislu stabilnih performansi) kao kad se rucno podese klok i napon.
        Da je do napajanja pucalo bi bilo kako da je podeseno, ne samo pri game boostu.Dobro je to napajanje, ljudi i na losijim klokuju procesore koji trose vise.
        Mixerovi kablovi su vrh, koriste ih entuzijaste sa foruma, to dovoljno govori o njima.
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
