Najbolje je da pitaš na njihovom discord serveru..Stigao je 10.0.7 uprate na Oxygen updater. E sad posto nema da se selektuje Mclaren verzija već samo 7T Pro (EU) a ja imam Mclaren verziju, da li će se poremetiti nešto, da li ću izgubiti nešto? Hvala
Inače uradio sam prevod na srpsku ćirilicu za oxgen updater pre nekog vremena pa očekujte u sledećem apdejtu aplikacije prevod odrađen od strane mene [emoji16]
Sent from my OnePlus 7T Pro using Tapatalk
Svaka castNisam, nego aplikacije za koje smatram da su dobre a nemaju srpski prevedem, čisto zbog ljudi koji ne znaju engleski a iz srbije su.. I onda vidim ss iz aplikacije ovde na forumu sa prevodom koji sam ja radio i bude mi jako drago..
Npr i za prvu app kad sam radio, i za ovu mi je trebalo oko 5-7 sati da to bude kako treba i sve prevedeno..
Krenuo update 10.0.8 za 7T.
Changelog:
System
Optimized the RAM management
Improved black/blank screen issues with some apps
Added the feature to support reminders for privacy alerts
Improved system stability and fixed general bugs
Updated Android security patch to 2020.01
Network (India Only)
Integrated the VoWifi registration for the Jio Sim
Cloud Service (India Only)
Supported synchronization with Notes and Contacts
Work-Life Balance (India Only)
Optimized message notification
Optimized the mode and app selection
Added location, calendar, auto-track feature
Looks as if there is a major issue with gboard.
This is what worked for my Moto Android phone.
Gboard is obviously installed but does not appear in the Apps list.
Install Gboard from Play Store, and then immediately uninstall it.
This cleared the issue for me and now I can type in Messenger and SMS without having to use voice!
Narode jel zna neko kako da obrisem automatic voice typing iz odabira tastatura od poslednjeg Gboard apdejta?
https://imgur.com/a/e44N9FQ?desktop=1
Samo od sebe se pojavilo, u settings - languages ga nema pa ne mogu ni da sklonim odatle a cak i kad komplet ugasim voice typing i dalje je tu. Poludeo sam, vec 3 dana kad god hocu na ruski da prebacim slucajno ovo zakacim jer sam navikao da mi je ruski najnizi na listi godinama i prst sam ide.
