»RSS Benchmark sajt
      Strana 107 od 107 PrvaPrva ... 75797103104105106107
      Prikazani rezultati od 1.591 do 1.601 od ukupno 1601
      Tema: Ko sta ima od HI-FI komponenti?!
      1. #1591
        Member
        Na forumu od
        Nov 2004
        Lokacija
        NBGD
        Poruka
        345
        Citat Citiram korisnika: salvatorebgd Pogledaj poruku
        Znači 4x2x0.8 po tebi ima ukupno 8 žica od po 0.8mm. jel si siguran?
        Da, to su 4 puta po dve odvojene parice po 0.8mm + još jedna drain žica koja ide sa spoljnim širmom.
      2. #1592
        Moderator Avatar korisnika Falcon
        Na forumu od
        Feb 2002
        Lokacija
        Beograd / Vračar
        Poruka
        6.617
      3. Moja mašina
        • CPU: Intel i7-5930K :: Prolimatech Megahalems rev.B :: Noiseblocker NB-eLoop
        • MoBo: Asus X99-A/USB3.1
        • RAM: 4 x 8GB Kingston Fury DDR4 2667Mhz
        • VGA: Asus ROG STRIX GTX1080Ti
        • MON: Alienware AW2518HF :: Dell U2414H
        • HDD: Samsung SM951 512GB AHCI M.2 :: QNAP TS-669L (12TB)
        • Case: Corsair 600T :: Corsair HX850W
        • SND: Onkyo TX-NR818 :: Jamo C607 + C60CEN + 4x E8SUR :: SVS PB-1000 :: Sennheiser HD-555 :: X-Fi Pltnm
        • OS: Windows 10 64bit
        • LAP: Dell Latitude 5590
        • TV: Samsung LE40B650 :: BenQ W1050@105":: Apple TV 4
        • INET: Kablovska
        • Ostalo: Alienware AW768 :: Logitech G9x :: PS3 :: PS4 Pro
      4. Tema je "Ko šta ima od Hi-Fi komponenti" a ne elektro-materijal.
        Social media gives legions of ldiots the right to speak when they once only spoke at a bar after a glass of wine, without harming the community [...] but now they have the same right to speak as a Nobel Prize winner. It's the invasion of the ldiots. - Umberto Eco
      5. #1593
        VIP member Avatar korisnika zormanic
        Na forumu od
        Sep 2002
        Lokacija
        Pirot, End Of The World
        Poruka
        1.664
      6. Moja mašina
        • CPU: Intel Core 2 Quad Q9400
        • MoBo: GIGABYTE P43-ES3G
        • RAM: HyperX 4GB
        • VGA: NVIDIA Quadro NVS 290
        • MON: LG 204WT
        • HDD: Kingston A400 & WD500GBAAKS & S.Baracuda320
        • OPT: Pioneer 112 & Teac540
        • Case: LC 600W
        • SND: SB Live Value 128
        • LAP: Dell Latitude D520, Acer ONE D270
        • INET: DSL
      7. Usmerne bakarne žice, preseka kojih se Đerdap ne bi postideo si osnova HiFi dojagnoze!
      8. #1594
        Newcomers
        Na forumu od
        Jul 2017
        Lokacija
        Beograd
        Poruka
        26
        Citat Citiram korisnika: Falcon Pogledaj poruku
        Koliko je meni poznato, kablovi i jesu Hi-fi komponenta. Još odavno.
      9. #1595
        Member Avatar korisnika vladat1
        Na forumu od
        Nov 2004
        Lokacija
        Srednje Pomoravlje
        Poruka
        4.521
      10. Moja mašina
        • CPU: I5 6500
        • MoBo: MSI B150M MORTAR
        • RAM: Kingston DDR4 16GB
        • VGA: MSI RX 580 Armor 4 Gb OC
        • MON: ASUS LED 23" VX239H
        • HDD: Samsung F4 2TB, SSD Kingston 128 GB
        • OPT: HL-DT-ST DVD-RAM GSA-H58N
        • Case: Cooler Master - HAF 912
        • SND: SMSL 8a + AR 98LS + A 8650
        • OS: Windows 10 Pro 64-bit
        • LAP: Toshiba Satellite® C650
        • TV: LG W2243
        • INET: DSL
      11. DIY Linear power supply, ploča Zero Zone, za DAC SMSL 8a
        Click image for larger version.
        Hvala @chika_milan u sa hi-files.com foruma. U pitanju je napajanje još u beta fazi. Obajsniću u par rečenica i zašto:
        - u pitanju je izgled same kutije. Planiram da delove ubacim u kutiju, od Hrasta ili Oraha. Nisam smislio još dizajn. Trenutno je napravljana od paleta Treba da se kutija popravi još malo bajcom. Zeleni prekidač je inspirisan NAD om. Da li imate preporuku za neki koji takođe ne svetli?
        - Led dijodica toliko jako sija, da sam morao da je dodatno smanjim, i oblepim sa 2 sloja plave izolir trake Trenutna rupica je 3 mm. Mora da se smanji na makar 1,5 mm.
        - Trenutno ožičenje je "Zaječarac 1,5 mm". Planiram neki Lapp ili nešto drugo, što mi dođe pod ruku, a učini mi se interesantno. Nisam siguran.
        - Trenutni EAC je Yamate. Zamenio bih ga sa EAC om sa filterom (koji trenutno ne mogu da pronađem u sobi )
        - Možda mi najveći problem pravi utičnica iz napajanja u DAC. Nigde nisam mogao da nađem neku novu, pa čak ni kvalitetniju . Neće da pasuje rupa i ako je na izgled identična. Zato sam odsekao sa starog HP napajanja za lap top.
        DAC je proban par dana sa Power Bank om, fabričkim originalim SMSL napajanjem, i na kraju sa ovim DIY Zero Zone Linear nim napajanjem. Oseća se velika razlika u zvuku. Po meni ide ovako. Zero Zone, ISY Power Bank i fabričko napajanje. Zero Zone ima još prostora za napredak, posebno u kablu iz napajanja u DAC.
        Još malo informacija. Zero Zone se sada radi sa boljim materijalom, fabrički sklapan. Moj je ručno lemio goksy sa hi-files.com foruma. Ploča košta oko 35€ + trafo (trafko) oko 10€ .
        Goli Otok .... Kako to nudistički zvuči ...
        Pobeda je čista kao suza jer mrtva usta ne govore.
      12. #1596
        Member Avatar korisnika Generator
        Na forumu od
        Mar 2011
        Poruka
        292
        Ja bih ipak smestio u neku alu kutiju, ova tvoja me podseca na one kutije od nakita
      13. #1597
        Member
        Na forumu od
        Oct 2003
        Lokacija
        Beograd
        Poruka
        2.220
      14. Moja mašina
        • CPU: Ryzen 1600X
        • MoBo: MSI B450 Gaming Plus
        • RAM: 2x8GB 2667
        • VGA: GTX 1070 Ti/8GB
        • MON: samsung 24"/bravia xe8096 55"
        • HDD: 256gb ssd/480gb ssd/2x1tb hdd
        • Case: Chieftec
        • SND: integrale :)
        • OS: win7 64bit/OSX High Sierra
        • LAP: MacBook Pro
        • INET: Kablovska
        • Ostalo: PS4 Pro
      15. posto sam ja i dalje u vintage fazonu, i nemam nameru da odustajem, malo sam se "ponovio":
        NAD model 200 amp, pravo remek delo:
        kutije Kenwood KL888Z:
        ooga....
      16. #1598
        Member
        Na forumu od
        Oct 2013
        Lokacija
        Ниш
        Poruka
        7.635
      17. Moja mašina
        • CPU: G3220
        • MoBo: Gigabyte GA-H81M-HD3
        • RAM: Corsair XMS CL9 4GB 1600MHz
        • VGA: Intel HD интегруша
        • MON: Dell U2312HM
        • HDD: Seagate ST3000DM008 i ST1000DM003
        • OPT: LiteOn iHAS324
        • Case: Chieftec Matrix MX-01WD-D
        • SND: Realtek ALC892 High Definition 7.1-channel интегруша
        • OS: Arch linux
        • LAP: HP ProBook 4710s
        • INET: Kablovska
      18. Тада је било много ремек дела, мада ипак више волем оне од почетка осамдесетих, мислим да су ту направили корак даље у спецификацијама али је остао квалитет. У то време сам знао напамет малтене сваки Hi-Fi уређај и сваки технички детаљ.
        Још увек чекам да ми другар оправи Маранц појачало (привремено користим неки Техникс) али често имам и ја жељу да потражим неко од тада јачих и скупљих појачала па да имам ново ремек дело. Ионако је то практично једина Hi-Fi компонента (осим наравно звучника) коју и даље користим.
      19. #1599
        Member
        Na forumu od
        Oct 2003
        Lokacija
        Beograd
        Poruka
        2.220
      20. Moja mašina
        • CPU: Ryzen 1600X
        • RAM: 2x8GB 2667
        • Case: Chieftec
        • SND: integrale :)
        • LAP: MacBook Pro
        • INET: Kablovska
        • Ostalo: PS4 Pro
      21. ovaj NAD model 200 sam jurio 3 godine da kupim (imam "mladjeg brata" NAD model 60 odavno, isto vrhunsko pojacalo, ali nemoze da isprati ove kenwoode), i nadjem na oglasima u Italiji, i zapucam za Veronu pre 2 meseca po njega.... pogledaj specifikacije modela 200 na netu, videces da je zaista remek delo
        ooga....
      22. #1600
        Member
        Na forumu od
        Oct 2013
        Lokacija
        Ниш
        Poruka
        7.635
      23. Moja mašina
        • CPU: G3220
        • MON: Dell U2312HM
        • OS: Arch linux
        • INET: Kablovska
      24. Ма ок, сама килажа довољно говори, тада бих имао замерке на пар спецификација (које углавном не значе много или ништа) али сада не бих имао ништа против. Мада сам и тада планирао Quad 405/44 који на папиру није нешто али ми је за мало измакао. Али да не шарамо превише, тема је нешто друго, када и ја купим нешто ново похвалићу се свакако.
      25. #1601
        Member
        Na forumu od
        Oct 2003
        Lokacija
        Beograd
        Poruka
        2.220
      26. Moja mašina
        • CPU: Ryzen 1600X
        • RAM: 2x8GB 2667
        • Case: Chieftec
        • SND: integrale :)
        • LAP: MacBook Pro
        • INET: Kablovska
        • Ostalo: PS4 Pro
      27. @calexx tako je
        a ovo je "mali bata", NAD model 60, isto prilicno kvalitetna spravica
        ooga....
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
