»RSS Benchmark sajt
      Strana 1 od 3 123 PoslednjaPoslednja
      Prikazani rezultati od 1 do 15 od ukupno 41
      Tema: Nokia 8.1
      1. #1
        Member Avatar korisnika pshnd
        Na forumu od
        Jan 2011
        Lokacija
        Novi Sad, RS
        Poruka
        2.351
      2. Moja mašina
        • CPU: AMD Athlon™ FX-6300 / X4 840
        • MoBo: Gigabyte Technology Co., Ltd. GA-78LMT-S2 / F2A68HM-S1
        • RAM: Silicon Power 8GB DDR3 1600MHz / 8GB DDR3 1600MHz
        • VGA: XFX Radeon RX 560 4GB / MSI GeForce GTS 450 1GB OC
        • MON: LG 27MB38VQ 27" FHD LED IPS / ViewSonic VA2231w 22" FHD
        • HDD: Kingston SSD A400 480GB + WD 1TB Blue / WD 320GB Blue + WD 640GB Black
        • OPT: No optical disk drives detected
        • Case: LC Power Dragonslayer + Chieftec GPS-550AB-A 550W / MS Cyclops III + Rhino RX-550PA
        • SND: Integrated + Genius SP-HF1201A & AIWA NSX-R41Focusrite Scarlett Solo 2nd Gen + Alesis Elevate 5 MKII
        • OS: Windows 10 Pro / Windows 10 Pro
        • LAP: Dell Vostro A860
        • TV: VOX 32DSA314H 32" HD Ready
        • INET: DSL
      3. Nokia 8.1
        Network Technology
        GSM / CDMA / HSPA / LTE
        2G bands GSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2
        3G bands HSDPA 850 / 900 / 1900 / 2100
        4G bands LTE
        Speed HSPA 42.2/5.76 Mbps, LTE-A (2CA) Cat6 300/50 Mbps
        GPRS Yes
        EDGE Yes
        Launch Announced 2018, December
        Status Available. Released 2018, December
        Body Dimensions 154.8 x 75.8 x 8 mm (6.09 x 2.98 x 0.31 in)
        Weight 180 g (6.35 oz)
        Build Front/back glass, aluminum frame
        SIM Hybrid Dual SIM (Nano-SIM, dual stand-by)
        Display Type IPS LCD capacitive touchscreen, 16M colors
        Size 6.18 inches, 95.3 cm2 (~81.2% screen-to-body ratio)
        Resolution 1080 x 2280 pixels, 19:9 ratio (~408 ppi density)
        Protection NEG
        Platform OS Android 9.0 (Pie); Android One
        Chipset Qualcomm SDM710 Snapdragon 710 (10 nm)
        CPU Octa-core (2x2.2 GHz 360 Gold & 6x1.7 GHz Kryo 360 Silver)
        GPU Adreno 616
        Memory Card slot microSD, up to 400 GB (uses SIM 2 slot)
        Internal 64 GB, 4 GB RAM
        Main Camera Dual 12 MP, f/1.8, 1/2.55", 1.4µm, dual pixel PDAF, OIS
        13 MP
        Features Zeiss optics, dual-LED dual-tone flash, panorama, HDR
        Video 2160p@30fps, 1080p@30fps (gyro-EIS)
        Selfie camera Single 20 MP, f/2.0, 0.9µm
        Video
        Sound Loudspeaker Yes
        3.5mm jack Yes
        - Active noise cancellation with dedicated mic
        Comms WLAN Wi-Fi 802.11 a/b/g/n/ac, dual-band, WiFi Direct, hotspot
        Bluetooth 5.0, A2DP, LE
        GPS Yes, with A-GPS, GLONASS, BDS
        NFC Yes
        Radio No
        USB 2.0, Type-C 1.0 reversible connector, USB On-The-Go
        Features Sensors Fingerprint (rear-mounted), accelerometer, gyro, proximity, compass
        Battery Non-removable Li-Ion 3500 mAh battery
        Charging Fast battery charging 2A/9V (18W)
        Misc Colors Blue, Silver, Steel, Copper, Iron, Steel
        Price About 400 EUR
        Izvor: GSMArena
      4. #2
        Na forumu od
        Jan 2011
        Lokacija
        Novi Sad, RS
        Poruka
        2.351
      5. Moja mašina
        • INET: DSL
      6. Iiiii stiže krajem nedelje.
      7. #3
        Member Avatar korisnika Bobajakuda
        Na forumu od
        Sep 2013
        Lokacija
        Beograd
        Poruka
        1.471
        Ti bas volis Nokiu cim si promenio toliko modela.
        Zbog cega si odlucio da uzmes 8.1?
      8. #4
        Na forumu od
        Jan 2011
        Lokacija
        Novi Sad, RS
        Poruka
        2.351
      9. Moja mašina
        • INET: DSL
      10. Citat Citiram korisnika: Bobajakuda Pogledaj poruku
        Mislim da si me pomešao sa nekim.
        Zadnju Nokiju sam imao Lumiju 630 pre 4 godine, a od tada samo P9 lite, Honor 8 lite i Mi A1 koji još koristim.
        Kontam da će posle Mi A1 ovo biti sasvim ok nadogradnja na nekih godinu i po. Možda su mogli da se iskese pa da stave 6GB RAM, ali šta sad... Tu je sasvim solidna kamera sa OIS, Android One, veoma dobar ekran... Poslužiće lepo u tom periodu.
        Menjao pshnd : 05.03.2019. u 18:41
      11. #5
        Member Avatar korisnika ivanbass1
        Na forumu od
        Apr 2016
        Lokacija
        Nis
        Poruka
        7.528
      12. Moja mašina
        • CPU: Ryzen 5 2600@4.0GHz, LC-CC-120 Push/Pull
        • MoBo: Msi X370 Krait Gaming
        • RAM: G.Skill Aegis 2x8GB 3000MHz CL16
        • VGA: RX 470 Sapphire Nitro+ 4gb
        • MON: AOC Q3279VWFD8
        • HDD: Patriot Ignite 240GB, WD Blue 500GB, Hitachi 500GB
        • OPT: Izbaceno zbog beskorisnosti
        • Case: MS Falcon 2x Arctic F14, 3x Arctic F12, Antec VP700P
        • SND: Microlab Solo 6C, Hyperx Cloud II
        • OS: Windows 10 64bit
        • LAP: Asus Vivobook Pro (i7 8750H, 2x8GB, GTX 1050 4GB, 1080p IPS)
        • Ostalo: Redragon Usas K553+Logitech g400s, Sandberg XXXL
      13. Precenjeno.
        Okej, 320e na oglasima, nije toliko strasno, ali je opet precenjeno.
      14. #6
        Na forumu od
        Jan 2011
        Lokacija
        Novi Sad, RS
        Poruka
        2.351
      15. Moja mašina
        • INET: DSL
      16. Citat Citiram korisnika: ivanbass1 Pogledaj poruku
        Precenjeno.
        Ja sam ga poručio iz Gigatrona, k'o i A1. Oglasi me ne zanimaju.
        Da li je precenjen? Možda i jeste, ali s obzirom da ću ga koristiti duži period biće mi sasvim ok.
        Menjao pshnd : 05.03.2019. u 19:05
      17. #7
        Na forumu od
        Apr 2016
        Lokacija
        Nis
        Poruka
        7.528
      18. Moja mašina
      19. Imao si dosta bolje telefone za taj novac, Meizu 16, Mi 8, LG G7, isto u domacim radnjama. Nokia 8.1 je high-midrange telefon po ceni flagshipa drugih (i ne mora kineskih) proizvodjaca.
        Svakako ce da posluzi svrsi, SD 710 i stock Android, baterija nije mala, 4GB rama, okej fon.
        Menjao ivanbass1 : 05.03.2019. u 19:08
      20. #8
        Na forumu od
        Jan 2011
        Lokacija
        Novi Sad, RS
        Poruka
        2.351
      21. Moja mašina
        • INET: DSL
      22. Citat Citiram korisnika: ivanbass1 Pogledaj poruku
        I svi padaju kod mene na jednom od najbitnijih kriterijuma - Android One.
        To mi je prva stavka po prioritetu, za tim da dolazi sa zadnjim aktuelnim sistemom da bih bio miran tih godinu i po do dve, a onda što kvalitetnija kamera.
        Ovaj je bio jedini koji ispunjava sve uslove.
        Menjao pshnd : 05.03.2019. u 19:16
      23. #9
        Newcomers
        Na forumu od
        Jul 2018
        Poruka
        643
        Od navedenih je jedino Mi 8 malo bolji, mada i ja bih verovatnije isao na Nokiju.
      24. #10
        Na forumu od
        Apr 2016
        Lokacija
        Nis
        Poruka
        7.528
      25. Moja mašina
      26. Od navedenih je svaki daleko bolji.
        @pshnd
        Naravno, svako ima svoje afinitete, ako je Android One must-have, to je to
        Menjao ivanbass1 : 05.03.2019. u 19:31
      27. #11
        Na forumu od
        Jan 2011
        Lokacija
        Novi Sad, RS
        Poruka
        2.351
      28. Moja mašina
        • INET: DSL
      29. Citat Citiram korisnika: ivanbass1 Pogledaj poruku
        I opet ni jedan ne ispunjava sve tražene uslove. Različite su nam svima potrebe tako da ako su na papiru bolji možda neće biti bolji određenom korisniku.
        Menjao pshnd : 05.03.2019. u 19:28
      30. #12
        Na forumu od
        Sep 2013
        Lokacija
        Beograd
        Poruka
        1.471
        @pshnd Izvini ja sam nesto pobrkao. Znam da ima jedan forumas koji bas voli Nokia telefone i cesto ih menja.
        Mozda si mogao da sacekas Nokiu 9 (pod uslovom da ima AndroidOne kad ti je bitna stavka) ako vec menjas telefone na 2god. Verovatno nece biti neka preterana razlika u ceni.
      31. #13
        Na forumu od
        Jan 2011
        Lokacija
        Novi Sad, RS
        Poruka
        2.351
      32. Moja mašina
        • INET: DSL
      33. @Bobajakuda Pitanje je da li će uopšte biti kod nas, a još će me i ovaj koštati 50.000 din što mi je baš maksimum maksimuma koji bih mogao isplatiti u neko dogledno vreme.
      34. #14
        Newcomers
        Na forumu od
        Mar 2017
        Poruka
        15
        Uzeo sam ovaj telefon pre mesec dana u mts-u i bas sam zadovoljan. Kamera mi je bolja nego na prethodnom telefonu (huawei p10), baterija nenormalna, nikad nisam punio tel na dva dana sa mojim korišćenjem, gura preko 7h sot-a. Ne znam kako da postavim sliku potrosnje baterije.
      35. #15
        Member Avatar korisnika Joxy
        Na forumu od
        Aug 2014
        Poruka
        2.490
        Citat Citiram korisnika: Migrant Pogledaj poruku
        Ovaj model ne moze da se poredi sa Mi8 ni po cemu.
        Ali covek je naveo svoje kriterijume koje mu 8.1 savrseno ispunjava i to je to. Suludo bi bilo da kupuje nesto sto mu ne odgovara.
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
