CountMike
Old but gold
- Ryzen 9 7900x Arctic Liquid Freezer III 360
- ASrock B650 Pro RS
- Kingston 6000 2x16GB.
- Gigabyte, AMD Rx 6600xt
- Kingston KC3000.1TB. Samsung 970 Evo Plus, 500GB. Samsung 960 Evo 250GB, , Cruical P1 1TB, Lexar NVME 2TB
- Zvuk
- On board Realtek 870
- Seasonic 750W
- Monitor
- 3 x 27"
- Laptop
- HP 630
- Mobilni telefon
- Samsung A12
- Mobilni internet
Znali neko za nešto kao ovo gde ima kod nas ?
https://www.amazon.com/Front-Panel-Header-Extension-Motherboard/dp/B077RWWJ5G
CY USB 3.1 Front Panel Header to USB 3.0 20Pin Header Extension Cable for ASUS Motherboard
Connector1: USB 3.0 Front Panel Header; Connector2: USB 3.1 Front Panel Header
USB 3.1 require a different front panel header than USB 3.0.
The USB 3.1 port interface is using the USB 3.0 pin set and more. It is design to be backwards compatible (will explain later).
There are no official release of the specs for the USB 3.1 header yet (as of this writing), But first motherboard with this is the ASUS ROG MAXIMUS IX FORMULA,STRIX Z270I/Z270G etc.The cable only support usb3.1/usb3.0 device, it can't work at USB2.0(480Mbps)
