Nokia 7.1
pshnd
Banned
Banovan
NETWORK Technology
GSM / CDMA / HSPA / LTE
BODY Dimensions -
Weight 160 g (5.64 oz)
Build Front/back glass, aluminum frame
SIM Single SIM (Nano-SIM) or Hybrid Dual SIM (Nano-SIM, dual stand-by)
DISPLAY Type IPS LCD capacitive touchscreen, 16M colors
Size 5.84 inches, 85.1 cm2 (~79.9% screen-to-body ratio)
Resolution 1080 x 2280 pixels, 19:9 ratio (~432 ppi density)
Multitouch Yes
Protection Corning Gorilla Glass 3
- HDR10 compliant
PLATFORM OS Android 8.1 (Oreo), planned upgrade to Android 9.0 (Pie); Android One
Chipset Qualcomm SDM636 Snapdragon 636
CPU Octa-core 1.8 GHz Kryo 260
GPU Adreno 509
MEMORY Card slot microSD, up to 400 GB (uses SIM 2 slot)
Internal 64 GB, 4 GB RAM or 32 GB, 3 GB RAM
MAIN CAMERA Dual 12 MP, f/1.8, 1.28µm, Dual Pixel PDAF
5 MP, f/2.4, 1.12µm, depth sensor
Features Zeiss optics, dual-LED dual-tone flash, panorama, HDR
Video 2160p@30fps, 1080p@30fps (gyro-EIS)
SELFIE CAMERA Single 8 MP, f/2.0, 24mm
Video
SOUND Alert types Vibration; MP3, WAV ringtones
Loudspeaker Yes
3.5mm jack Yes
- Active noise cancellation with dedicated mic
COMMS WLAN Wi-Fi 802.11 a/b/g/n/ac, dual-band, WiFi Direct, hotspot
Bluetooth 5.0, A2DP, EDR, LE, aptX
GPS Yes, with A-GPS, GLONASS, BDS
NFC Yes
USB 2.0, Type-C 1.0 reversible connector, USB On-The-Go
FEATURES Sensors Fingerprint (rear-mounted), accelerometer, gyro, proximity, compass
Messaging SMS(threaded view), MMS, Email, Push Email, IM
Browser HTML5
- Fast battery charging 9V/2A 18W
- MP4/H.264 player
- MP3/WAV/eAAC+/FLAC player
- Photo/video editor
- Document viewer
BATTERY Non-removable Li-Ion 3060 mAh battery
Stand-by Up to 408 h (3G)
Talk time Up to 19 h 30 min (3G)
MISC Colors Gloss midnight blue, gloss steel
Price About 350 EUR
Dosta dobar telefon. Pitanje je samo kolika će mu cena biti.
Bugararena hands on
https://www.gsmarena.com/nokia_7_1_hands_on-review-1830.php
The phone runs Android 8.1 Oreo and is a part of the Android One program. It will get an upgrade to 9.0 Pie in November followed by a 2-year-long period of major updates and 3 years of monthly security patches.
edit:
And if you're residing in the EU, you'd be looking at a starting price of €320 for the 3GB/32GB model and only €20 for the 4GB/64GB upgrade.
Sent from my MI 8 SE using Tapatalk
Jos jedan lep i nesalomivo-neunistiv telefon. Malo manje mi se svidja ono gore na ekranu ali sta je tu je.
Još kad bi mi neko rekao u čemu se suštinski razlikuje od Nokie 6.1 plus
Jedva se razlikuje od 6.1 Plus koji se u Indiji prodaje za manje novca od Mi A2. Realna cena ~200e.
Nema LED za notifikaciju ?? Nekog sam malo pre u drugoj temi pitao sta li ce mu mSD u telefonu a ja bez LED notifikacije ne bih uzeo telefon. Svako ima svoje uslove. Plus je minus stari 636. Inace mi je 5.8 inca sa zubom idealna velicina telefona, ovaj nema notifikaciju, Mi 8 SE nema Band 20, Huawei necu.
@liverpoll,za tebe je idealno S9 da uzmes
Lep telefon. Samo da ne preterajj sa cenom; za 200-230 eur bio bi pun pogodak.
@Pavell Znam. Hvala. [emoji3]
Sent from my POCOPHONE F1 using Tapatalk
Nece ovo ici ispod 350 ja iskreno mislim, lepo izgleda, ali ne vidim bas poentu postojanja, gadjaju se sa Xiaomi-jem pa ko ubode - ubode
Pa za taj novac ima N7 Plus koji nije nista losiji, ako ne i bolji, od ovog fona.
Pa dobro, to bi mu bila početna cena. Svakako 7 Plus treba da nasledi 7.1 Plus. Trebalo bi da ima SD710, 6/128 i 4/64 itd.
N7 Plus je iskreno po meni za nijansu bolji,a 7.1 ima malo moderniji dizajn, narocito sa prednje strane....
@pshnd , nisam siguran da planiraju 7.1 Plus, bilo bi zanimljivo....
@Čkalja šuška se po netu, kao i uvek. Ne bi bilo loše da ga zaista izbace. :)
Nisam pratio previse u poslednje vreme , ce vidimo :D
https://youtu.be/8pZTUpV4sUk
Са ових снимака са стране, са овом обрадом метала, ме све више подсећа на неки ајфон 5ицу. Умеша се ту и 4s да овим незакривљеним стакленим леђима. Добро то све изгледа, уме нокија дизајна нема шта. Једино се морамо навићи на предњу страну, јер лепша ова "обрва" неће постати.
Ljudi, razmišljam se ovu Nokiu da uzmem ženi, čini mi se kvalitetan a i stilski lijep telefon? Da li njega ili pak P20 lite, ili čak Mate 20 lite ?
Sent from My Galaxy S9+ using Tapatalk
Nije ovo tema za poredjenje,ali ako mene pitas ipak uzmi Mate.
Kakva mu je kamera?
Kad bi poredili kameru sa S8 kakva je?
Koliko dugo radi, odnosno kako brzo trosi bateriju, odnosno koliko cesto mora da se dopunjuje?
Ne bih ti znao uporediti sa S8. Vjerujem da S8 ima bolju kameru. Ali kamera mu je odlicna za ovaj rang telefona, jos kad se instalira gcam daje odlicne fotke. Izrada mu je super, zvuk dobar, ekran odlican. Baterija mu nije najbolja strana, moze da izdrzi oko 6 sati sota, izgura ponekad 7ipo. Uglavnom moze jedan dan i to je to. Manje zahtjevnim korisnicima mozda dan ipo.
Zna li neko veličinu senzora glavne kamere na ovom modelu?!
Koliko sam video po spec 12 MP, f/1.8, 1.28µm, Dual Pixel PDAF
Samo Vivo V11 Ima ovako nešto i veličina je 1/2.8 i recimo BB Key2 1/2.3...
Misterija čiji je senzor , Sony nije , Samsung nije...
Kupio sam telefon u Telenoru i nazalost kao i svaki telefon preko operatera mora da ima neku falinku (mislim na software) koji utice na sam rad.
Telefon je odlican ali dzaba performanse kada ga ubija telenor update...
