»RSS Benchmark sajt
      Strana 29 od 32 PrvaPrva ... 192526272829303132 PoslednjaPoslednja
      Prikazani rezultati od 421 do 435 od ukupno 477
      Tema: B450 ploče [ASRock, Asus, Biostar, Gigabyte, MSI]
      1. #421
        Member Avatar korisnika vamosalaplaya
        Na forumu od
        Dec 2001
        Lokacija
        BG
        Poruka
        417
      2. Moja mašina
        • CPU: Ryzen R5 3600, Wraith Stealth
        • MoBo: MSI B450 TOMAHAWK MAX
        • RAM: 16GB DDR4@3200CL16
        • VGA: XFX RX580 GTS
        • MON: AOC Q3279VWFD8
        • HDD: 500GB NVMe + 3 TB HDD
        • Case: RAIDMAX COBRA RX-800AE, Chieftec BX-02B-B-SL
        • SND: Jazz speakers JY3002
        • INET: Kablovska
        • Ostalo: Ajazz AK33
      3. Turpija bi definitivno rešila problem
        "Have you tried turning it off and on again?" "Is it definitely plugged in?", Roy Trenneman, The IT Crowd
      4. #422
        Member Avatar korisnika MightyOutlaw
        Na forumu od
        Jan 2009
        Lokacija
        Požarevac
        Poruka
        925
      5. Moja mašina
        • CPU: AMD Phenom II X4 955 + Zalman CNPS10x Performa
        • MoBo: Gigabyte GA-MA770T-UD3P
        • RAM: DDR3 Kingston Genesis 2x4Gb 1600Mhz Cl9
        • VGA: MSI HD6790/1Gb
        • MON: BenQ E2200HDA
        • HDD: Samsund F4 320Gb/WD 640Gb/16Mb+WD 500Gb/16Mb
        • OPT: LG 16x SATA
        • Case: Thermaltake m9 + Thermaltake ToughPower 775W
        • SND: integruša
        • OS: Windows7 x64
        • INET: Kablovska
      6. Citat Citiram korisnika: mcekovic Pogledaj poruku
        Ako te ne mrzi pitaj i za Gigabyte B450 AORUS Pro? (malo ima bolju podrsku za periferije i bolji codec od MSI Tomahawk MAX)
        Isto važi za tvoju kao i za aorus m
        Sent from my MI 9 using Tapatalk
      7. #423
        Member Avatar korisnika Millan1
        Na forumu od
        Nov 2013
        Poruka
        590
      8. Moja mašina
        • LAP: HP ProBook 455
      9. Montirajte kuler 'vako, nista ne zaklanja...
      10. #424
        Moderator Avatar korisnika Chinaski
        Na forumu od
        Mar 2005
        Lokacija
        Bench House
        Poruka
        5.867
      11. Moja mašina
        • CPU: Ryzen 5 1600X pod LC-CC-120
        • MoBo: Asus B350M-E
        • RAM: HyperX Savage 8GB 2400MHz
        • VGA: Asus GTX1060 Strix OC
        • MON: Samsung C27HG70
        • HDD: Silicon Power V60 240GB i Seagate ST3000DM001
        • OPT: LG something
        • Case: Anidees AI6 Black; ThermalTake SP-750M
        • SND: Altec Lansing PT 6021
        • OS: Windows 10 Home 64bit
        • TV: LG 32LH2000
        • INET: Kablovska
        • Ostalo: Mionix Naos 5000 i Logitech K740
      12. Citat Citiram korisnika: MightyOutlaw Pogledaj poruku
        Ovo je samo za aorus m, za koju još da pitam?
        tek sada videh. pa mislio sam za sve B450 ploca, mozda i A320. jel to neko unificirano obelezavanje ili vazi samo za pojedine modele?
        edit: mada vrv u tom slucaju i pise na kutiji Ryzen 3000 ready.
        Menjao Chinaski : 16.10.2019. u 19:16
        Bog slusa Mötley Crüe
      13. #425
        Member
        Na forumu od
        Nov 2007
        Lokacija
        Banja Luka, RS
        Poruka
        1.292
      14. Moja mašina
        • CPU: i7 3770k
        • MoBo: MSI Z77A-G43
        • RAM: HyperX Performance 2x4gb 2400MHz
        • VGA: Intel 4000 :)
        • MON: Dell U2312HM 23'
        • HDD: Samsung 830 120GB & 2 x seagate 2TB sata III 5900rpm
        • OPT: SH-S203B & SH222
        • Case: TT Mambo + Cors TX 650W
        • SND: Audigy 2 ZS, Asus Xonar DS; Logitech G51
        • OS: Win 7 SP1
        • INET: DSL
        • Ostalo: Sennheiser HDR 170
      15. Ovo vazi samo za Gigabyte maticne.
      16. #426
        Na forumu od
        Mar 2005
        Lokacija
        Bench House
        Poruka
        5.867
      17. Moja mašina
        • OPT: LG something
        • TV: LG 32LH2000
        • INET: Kablovska
      18. pa to, nisam ni mislio da vazi za MSI znaci za sve GA ploce je tako.
      19. #427
        Member
        Na forumu od
        Nov 2007
        Lokacija
        Banja Luka, RS
        Poruka
        1.292
      20. Moja mašina
        • CPU: i7 3770k
        • OS: Win 7 SP1
        • INET: DSL
      21. Ne pise jos uvijek Ryzen 3000 Ready na kutijama , ali ce ubrzo to dodati na kutije.
        Izgleda da je ovo sema serijskog broja kod Ga ploca:
        Prva dva god proizvodnje, treci i cetvrti sedmica proizvodnje.
      22. #428
        Member
        Na forumu od
        Sep 2012
        Poruka
        642
        Kakva je AsRock B450M-PRO4 za 2600? Ne planiram OC. Ili da idem na neku drugu?
      23. #429
        Member Avatar korisnika dobrivoj
        Na forumu od
        Mar 2005
        Lokacija
        Serbia Subotica
        Poruka
        438
      24. Moja mašina
        • CPU: AMD Ryzen 5 2600 LC-CC-120
        • MoBo: ASROCK B450M Pro4
        • RAM: G.SKILL 16GB Aegis DDR4 3000MHz CL16
        • VGA: Sapphire RX 580 4GDDR5
        • MON: LG 27MP75HM-P 27" IPS LED
        • HDD: 2 x Biostar-480gb
        • Case: Thermaltake Versa H18
        • SND: Mikrolab H 500
        • OS: Linux
        • LAP: ThinkPad x230
        • TV: 42LB650V
        • INET: Kablovska
        • Ostalo: Mi Max2
      25. Ja koristim tu kombinaciju AsRock B450M-PRO4 i 2600 sve stock gura rx 580. Za 1080 savrsena kombinacija a sa llc i hladna.
        WARNING: Military software detected, top secret clearance required
      26. #430
        Member Avatar korisnika Boqy
        Na forumu od
        Dec 2003
        Lokacija
        Dorcol
        Poruka
        265
      27. Moja mašina
        • CPU: R5 2600@4GHz + LC-CC-120-RGB
        • MoBo: MSI B450 Tomahawk MAX
        • RAM: 2x8GB Patriot Viper 4 3200
        • VGA: RX580 Sapphire Nitro+ 8GB
        • MON: Dell U2312HM
        • HDD: HyperX 3K 120GB, Intel 545s 256GB, WD 640AAKS, WD10EZEX
        • OPT: LG
        • Case: Antec P182 - Corsair HX650W
        • SND: Realtek :)
        • OS: Win 10 x64
        • LAP: HP 6470b
        • TV: LG 50UK6500
        • INET: Kablovska
        • Ostalo: Roccat Kone
      28. Izasao AGESA 1.0.0.4 (stable) bios za Tomahawk MAX, V34.
      29. #431
        Member Avatar korisnika anarki1302
        Na forumu od
        Feb 2009
        Lokacija
        Gornji Milanovac
        Poruka
        1.688
      30. Moja mašina
        • CPU: Ryzen 3700X@4.2ghz 1.3v / AC LF II 240
        • RAM: 16GB Patriot Viper Steel 3600C17@3800C16
        • VGA: Gigabyte 1070ti Gaming OC
        • MON: BenQ XL2411z 3D 144hz
        • HDD: A-Data Gammix S11 PRO, Cuda 3TB
        • OPT: ...
        • Case: CM 690 III+Seasonic Focus Plus Gold 850w
        • SND: Logitech G35/Logitech X530
        • OS: WIN 10
        • TV: LG 32LH3000
        • INET: Kablovska
        • Ostalo: ...
      31. Citat Citiram korisnika: Boqy Pogledaj poruku
        Sada cu da sacuvam profile i da probam.
        EDIT:
        Sacuvao i usrao motku. Naravno, novi BIOS, vidim ima neki novih opcija, nisam mogao profil da ubacim.
        Inace, meni isti djavo, boot isto traje, sve isto. Cak mi je single core boost na defu nizi nego na v33.
        Posto ne drzim na defu, nego 4200 fiksno, ostavicu ga malo ovako, da vidim kako se ponasa.
        NS je pao malo, sa 65.5 na 64.5, eto cisto onako.
        Memoriju sada ponovo moram da testiram i zatezem.
        Menjao anarki1302 : 01.11.2019. u 13:16
        Ne kazem da sam sveznalica,ali ovde ima nekoliko velikih neznalica...
      32. #432
        Na forumu od
        Feb 2009
        Lokacija
        Gornji Milanovac
        Poruka
        1.688
      33. Moja mašina
        • OPT: ...
        • OS: WIN 10
        • TV: LG 32LH3000
        • INET: Kablovska
        • Ostalo: ...
      34. Izvinjavam se za dupli post
        Neka se on igra sa mamom i tatom, memorija nije stabilna. Stabilna 100% Prime i sve ostalo na v33, v34 nije.
        Mrzi me da se sada igram i sve ponovo testiram, ali mi se ne svidja uopste.
        Inace, dodaje vise napona na memoriju nego prosli.
      35. #433
        Member
        Na forumu od
        Nov 2006
        Lokacija
        Šabac-N.Sad
        Poruka
        40
      36. Moja mašina
        • CPU: AMD Ryzen 5 3600X
        • MoBo: MSI B450 Mortar MAX
        • RAM: Corsair 3200 MHz 16GB DDR4
        • VGA: Sapphire RX 590 Nitro 8GB
        • MON: Dell U2518D x 2
        • HDD: NVMe Samsung EVO 970 500 GB, SSD Samsung 480GB, HDD Toshiba 3 TB
        • Case: NZXT H400
        • SND: Creative SB X-Fi Xtreme Audio, Solo 6C
        • OS: Windows 10
        • LAP: HP Envy 15
        • TV: Samsung UE40F6400
        • INET: Kablovska
        • Ostalo: PSU: NZXT E650 Keyboard: Logitech G513 Carbon Mouse: Logitech G502 Lightspeed RGB: NZXT Hue 2
      37. Instalirao novi BIOS v.24 za MSI Mortar MAX. Da li je još neko probao i kakva su iskustva? Kod mene je bio problem bootovanja sa NvME, nije hteo odmah da prepozna Samsunga 970... nakon 2 restarta i čačkanja oko boot ordera je proradilo.
        Čini mi se da se Windows podiže za nijansu brže, mada ništa spektakularno. I da, takodje dodaje više napona na memoriju.
      38. #434
        Na forumu od
        Feb 2009
        Lokacija
        Gornji Milanovac
        Poruka
        1.688
      39. Moja mašina
        • OPT: ...
        • OS: WIN 10
        • TV: LG 32LH3000
        • INET: Kablovska
        • Ostalo: ...
      40. Ta dva restarta su zbog memorije, ne zbog ssd-a.
        Imas dole memory attempt ili sta vec, stoji 2 po defu. To memorija zeza.
        Tajminzi nesto nisu kao za prethodni bios, zato sam i vratio na v33.
      41. #435
        Member Avatar korisnika jurodivi
        Na forumu od
        Aug 2011
        Lokacija
        Copper-city
        Poruka
        1.899
      42. Moja mašina
        • CPU: Intel i5-4670K + Phanteks PH TC-14PE
        • MoBo: Asus Z87 Pro (V Edition)
        • RAM: 2x4GB DDR3 Patriot Viper 3 2400MHz
        • VGA: Asus Expedition GTX 1060 6GB
        • MON: BenQ GW2750 27" 1080p VA
        • HDD: 850 EVO 120 GB + Toshiba P300 3TB + ext. Verbatim 4TB
        • Case: Fractal Design Define R4 (white) + ThermalTake SPS-730M
        • SND: SMSL SD-793II + Takstar Pro82
        • OS: Windows 10 LTSC
        • INET: DSL
        • Ostalo: Drevo Tyrfing v2 + CM Xornet II
      43. 5 meseci kasnije, AMD i dalje kuburi s BIOSima a Navi karte sa drajverima...svaka im čast na Ryzenima ali bi trebalo da prođu bacačem plamena kroz softversko odeljenje i zaposle nove ljude koji znaju šta rade.
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
