»RSS Benchmark sajt
      Strana 14 od 33 PrvaPrva ... 410111213141516171824 ... PoslednjaPoslednja
      Prikazani rezultati od 196 do 210 od ukupno 483
      Tema: B450 ploče [ASRock, Asus, Biostar, Gigabyte, MSI]
      1. #196
        Member Avatar korisnika nestolex
        Na forumu od
        Aug 2010
        Lokacija
        Vršac
        Poruka
        527
      2. Moja mašina
        • CPU: AMD Ryzen 5, 2600
        • MoBo: MSI B450M-Mortar
        • RAM: Kingston HyperX Fury Black 16GB, DDR4, 3200MHz, CL18
        • VGA: Gigabyte GeForce RTX 2060 Super Windforce 8GB OC, 256bit
        • MON: 27" LG 27MP38 IPS LED, 1920x1080(Full HD)
        • HDD: SSD Kingston 250GB + Seagate 500GB + WD Blue 1TB
        • OPT: Externi LG combo DVD-RW/Blueray
        • Case: CoolerMaster MB511 + FSP Hammer 600w full modular
        • SND: Integrisana /Zvučnici Blueberry SW-M20 2,1
        • OS: Win 10 64-bit
        • TV: LG 4K UHD 55UJ620V-ZA 55"
        • INET: Kablovska
        • Ostalo: 5 x LED ventilatori Alexander Weiss
      3. Bog te mazo...kako se ulazi u BIOS od ove ploče? B450 Mortar... probao sa DEL, sa F2...neće pa neće
        "Lomim kevama kosti !"
        -Kevin Kostner
      4. #197
        VIP member Avatar korisnika BokiPK
        Na forumu od
        Dec 2000
        Lokacija
        Niš, Sr, Europe, Earth...
        Poruka
        3.954
      5. Moja mašina
        • CPU: Intel Xeon E5450, OCZ Vendetta 2
        • MoBo: ASUS P5B DeLuxe
        • RAM: 2x2GB Kingston KHX DDR2 1066 Cl5
        • VGA: ASUS GF GTX 560Ti DCU II 1GB GDDR5
        • MON: 24" TFT Prestigio P7240WD 1920x1200
        • HDD: Seagate 250GB+500GB + WD mobile 320GB USB3
        • OPT: LH-20A1L, SH-223L
        • Case: Enlight, OCZ 600 SXS
        • SND: SoundMax HD, KOSS
        • OS: XP SP3 + W7 SP1
        • LAP: IBM/Lenovo T61
        • TV: SHARP 40" FHD
        • INET: UMTS/GPRS
        • Ostalo: Logi kb&m, Sony XZ2C & LG Q6, Mustek 800VA Pro, gomila fleški, Prestigio GV450, MiFi, Huawei LTE, g
      6. UEFI, a?
        citat u originalu
        Spoiler:
        Please do that:
        - remove the GPU
        - remove the cell battery and the power cord during >30mn then plug it again
        - power On, then wait 30s
        - plug the GPU
        - power On keeping <Del> pressed during 30s, then (even if the screen is black,/blanck) press <F6>, then press <F10>, then press <Enter>, then wait >5s
        - Power Off then On
        Have you bios splash screen display now?
        Ako je Win već instaliran, onda imaš i alat za restart u uefi BIOS
        "...ja sam genije, suvi genije..." PeraKojot
      7. #198
        Member
        Na forumu od
        Mar 2011
        Lokacija
        Sabac
        Poruka
        399
      8. Moja mašina
        • CPU: I5 4670K NOCTUA NH-U12P
        • MoBo: AsRock Z87 Pro3
        • RAM: Kingston 10GB DDR3 @1333
        • VGA: R9 270X
        • MON: DELL UH2321
        • HDD: WD 320GB + WD1.5TB + SSD120GB
        • OPT: Pioneer
        • Case: Chieftec BIG Tower
        • OS: WIN 10 64 bit
        • INET: Kablovska
        • Ostalo: Huawei Mate 10 Lite
      9. Ja sad hteo da pitam bas kako da dodjem do uefi biosa na b450m mortar. Ne mogu da verujem da treba da se drkam ovoliko. Sklopio sam detetu komp ali nije hteo da se pokrene i prepozna m2 ssd i nisu mi radili kuleri na kucistu, black widow. Bio je uefi bios. Skinem novi bios, flesujem bas preko biosa i on kad se pokrenuo onda onaj stari interfejs, ali je proradio ssd i komp se pokrenuo. Medjutim ne rade mi ventilatori na kucistu. Pokusavao sam sa sva tri ulaza, sys fan 1,2 i 3, i nece. Ukljucio sam u biosu i probao i pwm i dc mode, nece. Mogu li nekako iz windows da pokrenem te kulere?
      10. #199
        Member
        Na forumu od
        Mar 2011
        Lokacija
        Sabac
        Poruka
        399
      11. Moja mašina
        • VGA: R9 270X
        • MON: DELL UH2321
        • OPT: Pioneer
        • OS: WIN 10 64 bit
        • INET: Kablovska
      12. Resio sam problem, samo je trebalo zakaciti na napajanje, ne na maticnu.
      13. #200
        Member Avatar korisnika CountMike
        Na forumu od
        Jul 2012
        Lokacija
        Beograd. Toronto
        Poruka
        6.658
      14. Moja mašina
        • CPU: Ryzen R7 3700X, CM Nepton 140XL
        • MoBo: Asus PRIME X470 PRO
        • RAM: 2x8GB Kingston Predator 3600MHz
        • VGA: Asus strix 570 OC 4gb
        • MON: BenQ 28" + 2x Samsung 2494
        • HDD: Samsung 960Evo, 250GB, SP V70 240GB, WD Blue 2TB,WD Blue 1TB
        • Case: Raidmax Agusta (customized)
        • SND: On Board
        • OS: Win 10 Pro, Linux Mint
      15. To nije baš najbolje rešenje, sada ti ventilatori rade samo punom brzinom.
      16. #201
        Member Avatar korisnika rev
        Na forumu od
        Jan 2003
        Lokacija
        BG, Centar
        Poruka
        344
      17. Moja mašina
        • CPU: Ryzen 5 2600 @ 4ghz + LC-CC-120-RGB
        • MoBo: MSI Mortar B450M
        • RAM: 16GB KHX Predator 3200mhz DDR4
        • VGA: GIGABYTE GTX 1060 OC 3GB
        • MON: BenQ XL2411Z
        • HDD: Crucial MX500 500GB M.2 SSD, Samsung F2 1.5TB HDD
        • Case: Fractal Design Meshify C mini, Seasonic SS-520GM2
        • SND: Asus Xonar U5 + Xiaomi Piston 3
        • OS: Windows 10 Enterprise LTSC
        • LAP: Lenovo Ideapad 330S-15IKB
        • TV: LG 43LH541V
        • INET: Kablovska
        • Ostalo: HyperX Alloy FPS Pro (MX Red), Logitech G305, Zowie G-SR
      18. Ma ima fan controler na kucistu, tako da je to sasvim ok. Leti na high, ostatak godine na low i pici. Moze i preko headera na ploci, ali ako koristis najnoviji bios, moras rucno da kucas voltaze, po defaultu je 0 za sve ja mislim. To je jedna od retkih stvari koja mi se ne dopada kod novog biosa, stari je imao fan curve koji je mogao da se podesava.
      19. #202
        Member Avatar korisnika mcekovic
        Na forumu od
        Nov 2002
        Lokacija
        Belgrade
        Poruka
        829
      20. Moja mašina
        • CPU: Intel Core i5 4670 3.4 GHz @ CM Hyper 212 EVO
        • MoBo: Gigabyte H87-D3H
        • RAM: 2x8GB DDR3 1866 MHz Kingston HyperX Savage
        • VGA: Sapphire AMD Radeon R9 270X DUAL-X
        • MON: DELL P2417H 24" HD
        • HDD: SSD Samsung 840 EVO 250 GB; OCZ Vertex 4 128MB; HDD Samsung F3 1TB, WD 1TB Caviar Green
        • OPT: DVD-RW Pioneer 215D
        • Case: Cooler Master Centurion 5 II, Chieftec CFT 650W
        • SND: Altec Lansing VS4121
        • OS: Windows 7 64b, Linux Mint
        • LAP: Dell Insprion 15 5570 15.6" HD, Core i5 8250U, 16 GB DDR4, 128GB SSD, 1TB HDD
        • TV: Sony 50" HD LCD KDL50W807C
        • INET: Kablovska
      21. Jel ima neko iskustva za B450 plocama i Ryzen 3000 procesorima?
        Nameravam da uskoro uzmem Ryzen 3600 i B450 plocu, ali vidim po forumima da ima problema i da mnoge ploce i dalje nemaju update-ovan BIOS.
        Jel moze ko god uspe da upari B450 plocu sa Ryzen 3000 procesorom da ubaci kratak post sa kombinacijom koja je uspela?
      22. #203
        Na forumu od
        Dec 2000
        Lokacija
        Poruka
        3.954
      23. Moja mašina
        • TV: SHARP 40" FHD
        • INET: UMTS/GPRS
      24. Moraš da apdejtuješ BIOS pre ubacivanja proca. Ako kupuješ nova oba, tj nemaš stariji cpu na raspolaganju, zaglavićeš.
        Kod većine proizvođača apdejt mora da se odradi u više etapa, i to je naznačeno na matičnim stranicama. Najpre se apdejtuje na verziju biosa koja podržava novi AGESA, pa tek onda na bios koji podržava same CPU. A može i da se desi da moraš i na i varijantu pre toga, koja podržava novi metod flešovanja.
        Dakle - treba ti stariji CPU i minimum dva BIOS imidža.
        Ako nemaš - pravac prvi kršteni servis. Naplaćuju uslugu, i to masovno.
        Menjao BokiPK : 19.07.2019. u 14:43
      25. #204
        Banned
        Na forumu od
        Sep 2018
        Poruka
        119
        Posto je pitanje u vezi b450 maticne vezane za audio kodeke.
        Jel moze neko da mi kaze koje su razlike izmedju ova dvoje realtek alc1220 vs alc892, znam da je alc 1220 noviji i bolji posto ga imam na Z370 krait gaming maticnoj ali sada uzimam jos jednu konfiguraciju sa amd procesorom gde ce biti b450 tomahawk i 2600 pa me interesuje koliku razliku u zvuku da ocekujem?
        I jel ima neko neki predlog za neke sluske do 50 evra sa kp, to mozete da saljete na private da ovde ne zatrpavamo temu... hvala? Nove ili polovne bitno da su jastuci ocuvani i da nisu polomljene.
      26. #205
        Member Avatar korisnika HighONE
        Na forumu od
        Feb 2005
        Lokacija
        Sombor
        Poruka
        1.860
      27. Moja mašina
        • CPU: Intel Core i7-4770k, Noctua NH-U14S (2xNF-A15 PWM)
        • MoBo: ASUS Maximus VI Hero
        • RAM: Corsair Vengeance Pro 2x8GB DDR3 2400
        • VGA: MSI GTX 970 Gaming
        • MON: BenQ G2420HDBL
        • HDD: Crucial MX100 256GB, Crucial M4 128GB, Seagate Barracuda 7200.14 2 TB, 7200.12 1TB
        • Case: Fractal Design Define R4, Cooler Master V700
        • SND: integrisana
        • OS: Windows 10, Arch Linux
        • TV: LG 42LM660S
        • INET: Kablovska
        • Ostalo: Cooler Master QuickFire TK Brown, Storm Mizar, Storm Skorpion, A4Tech X7-200MP
      28. Citat Citiram korisnika: mcekovic Pogledaj poruku
        Ja sam nedavno flesovao poslednji UEFI na MSI Mortar B450 Titanium, i iako nemam Ryzen 3000, ne vidim zasto taj setup ne bi radio. Da li ces imati PCI-E 4.0, to ne znam... Mislim da za MSI ploce nema specijalnog koraka, dovoljno je staviti poslednji UEFI - na B450 su morali da prebace UEFI na lite mode - bez slicica etc, da bi mogli da uguraju podrsku za nove procesore u ogranicenu velicinu BIOS-a (UEFI-a). Po meni je ovako 10x bolje, ali ukusi su razliciti.
      29. #206
        Moderator Avatar korisnika Corvus Corax
        Na forumu od
        Sep 2008
        Lokacija
        Niš
        Poruka
        9.813
      30. Moja mašina
        • CPU: Intel® Core™ i5-2500K 3.3GHz + CM Hyper 212 EVO
        • MoBo: ASUS Maximus IV Gene-Z Gen3
        • RAM: Patriot G2 1600MHz 4x4GB
        • VGA: XFX Radeon RX580 GTS XXX Edition 8GB GDDR5
        • MON: LG 29WK500-P 29" UltraWide 2K
        • HDD: SSD Patriot Blast 240GB SATA3 + HDD WD Green 1TB SATA2
        • OPT: Sony Optiarc DVD-RW AD-7240S
        • Case: Thermaltake Element S + OCZ ModXStream 600W
        • OS: Windows 7 x64
        • LAP: Dell Inspiron 7559 MS Signature Edition
        • TV: Skyworth 49E3200 49" FHD
        • INET: Kablovska
        • Ostalo: Mionix Naos QG, PS4 Pro + PSVR, NAS (GA-E350N WIN8 + 4GB RAM + Raidmax 300W + WD 3TB+4TB)
      31. Nes, postoji podforum "Šta da kupim", pa postavi svoje pitanje tamo.
        Menjao Corvus Corax : 21.07.2019. u 13:35
      32. #207
        Member Avatar korisnika p3dJ4
        Na forumu od
        Sep 2009
        Lokacija
        bogu iza grbinu
        Poruka
        334
      33. Moja mašina
        • CPU: ryzen 5 3600
        • MoBo: biostar b350et2
        • RAM: 2x4gb DDR4 2400mhz samsung
        • VGA: Rx 580 4gb sapphire pulse
        • MON: benq 24' 1080p 60hz
        • HDD: ssd 240gb kingston
        • Case: MS Winston - Chiftec 500w Smart - 3x red FAN MS
        • SND: Blueberry 2.1
        • OS: W10 x64 pro
        • TV: VOX 43"
        • INET: DSL
        • Ostalo: babaroga
      34. gigabyte b450 s2h ili asrock b450 hdv sta mislite koja ima bolji vrm?
        La Prestige :
        April-maj 2k,preko leta max do 3k kretanje.
      35. #208
        Member Avatar korisnika jurodivi
        Na forumu od
        Aug 2011
        Lokacija
        Copper-city
        Poruka
        1.904
      36. Moja mašina
        • CPU: Intel i5-4670K + Phanteks PH TC-14PE
        • MoBo: Asus Z87 Pro (V Edition)
        • RAM: 2x4GB DDR3 Patriot Viper 3 2400MHz
        • VGA: Asus Expedition GTX 1060 6GB
        • MON: BenQ GW2750 27" 1080p VA
        • HDD: 850 EVO 120 GB + Toshiba P300 3TB + ext. Verbatim 4TB
        • Case: Fractal Design Define R4 (white) + ThermalTake SPS-730M
        • SND: SMSL SD-793II + Takstar Pro82
        • OS: Windows 10 LTSC
        • INET: DSL
        • Ostalo: Drevo Tyrfing v2 + CM Xornet II
      37. Citat Citiram korisnika: p3dJ4 Pogledaj poruku
        Otprilike su tu negde...obe su bottom tier.
      38. #209
        Member Avatar korisnika dobrivoje
        Na forumu od
        Jul 2011
        Poruka
        798
      39. Moja mašina
        • CPU: Ryzen 3600, MasterLiquid 120
        • MoBo: GIGABYTE B450 AORUS
        • RAM: GeIL EVO 2x 8GB 3600MHz
        • VGA: Sapphire RX 470 Nitro+
        • MON: Samsung 27" PLS FreeSync
        • HDD: XPG GAMMIX S11 512GB
        • Case: MasterBox Q500L, FSP 500W
        • OS: Windows 10 Pro Build 1903
        • INET: Kablovska
        • Ostalo: illusion, imperator 2
      40. Citat Citiram korisnika: p3dJ4 Pogledaj poruku
        Imam obe, R5 1400 i R3 2200G na njima, a posle 6 meseci korišćenja mala prednost za gigu.
      41. #210
        Na forumu od
        Sep 2009
        Lokacija
        bogu iza grbinu
        Poruka
        334
      42. Moja mašina
        • CPU: ryzen 5 3600
        • OS: W10 x64 pro
        • TV: VOX 43"
        • INET: DSL
        • Ostalo: babaroga
      43. hm,zanimljivo,koji bi ste plocu minimalno preporucili za ryzen 3600 gde bi cpu radio manje vise stalno?
        La Prestige :
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
