dzonihsv
Does anyone else had a problem with xbox gamepad not working? Anyone was able to fix it? Usual DS shenanigans didn't help: removing HID device, repluging gamepad after it etc.
UPDATE: I was able to fix that. From Software games apparently cannot recognize xinput devices that aren't «id=0». Turns out in my case id=0 was taken by another controller (that I disconnected about a year ago, but that's another story). So how to fix this according to me:
* remove all controllers except for xbox one
* download and run x360ce
* accept all initial prompts
* if only one tab is marked with green square, I can't help you
* if two tabs marked with green squares, check that second one is your xbox controller and head to the first tab
* select last subtab and make note of VID field (483 in my case)
* go to device manager, Humane Interface Devices branch
* find «HID-compliant consumer control device» with matching VID (to check VID: Right click on device → Properties → Details → Hardware Ids)
* when desired device is found just disable it
Worked for me.
https://www.reddit.com/r/CrackWatch/comments/b3rx9p/-/ej2kvxh
Imaš još par komentara ispod ovog na reddit-u sa mogućim rešenjima/objašnjenjima, pa baci pogled.
