Magnifico 79
Poštovan
Kako ce se pokazati baterija od 3000 mAh na ovakvom displayu? Mogli su bar za 10% staviti vecu.
Srednje žalosno, kako drugačije!Kako ce se pokazati baterija od 3000 mAh na ovakvom displayu? Mogli su bar za 10% staviti vecu.
The official presentation of the LG G7 ThinQ will be tomorrow in New York. LG apparently wants to offer one of the cheaper flagship smartphones of the year 2018, because the price will probably be below 680 euros in this country.
LG said a few days ago that they would like to offer an extremely high brightness, which reaches up to 1000 candelas per square meter. In addition, the DCI P3 standard is fully supported, so the color space is at least 100 percent covered for this standard used by the film industry. LG also promises that the panel uses up to 30 percent less energy than previous models.
As usual with LG, there are two cameras on the back, whereby we only know their maximum resolution of 16.3 megapixels and can confirm that LG is using an F / 1.6 aperture here. The second sensor is also a 16-megapixel camera with F / 1.6 aperture, although it is still unclear whether a wide-angle lens is offered here again.
The LG G7 ThinQ is also equipped with a 3000mAh battery, which can be charged extremely quickly via Qualcomm QuickCharge 4.0, which of course uses a USB-C port. The weight is 162 grams, while the LG G7 brings it to a height of 7.9 millimeters
Depending on the model and region, it is combined with 4 or 6 GB of RAM, whereas according to the information available to us, the internal flash memory occupies 64 GB.
Perhaps the only number to give me pause is the G7's 3,000mAh battery. It's 300mAh smaller than the one in the G6, and we've seen battery regression on phones running Oreo — the Galaxy S9 comes to mind — so I'm worried the same thing will happen here. Right now my concern is only speculative, as the unit I used wasn't running final software, but given the phone's slimness, and the extra space afforded to the speaker (and the presence of a headphone jack), LG clearly decided to forgo longevity for convenience.
We also have a headphone jack — on the bottom, natch, which is an improvement over the V30 — and the same beloved Quad DAC has made the LG V series so prized among audiophiles. Indeed, LG isn't leaving much room between the G and V series anymore.
Like the G6, the phone shares the same shooter between the primary and wide-angle cameras, but this year LG is using the 16MP Sony IMX351 sensor that debuted in the V30. The main lens, which has a ƒ1.6 aperture, is optically stabilized while the ƒ/1.9 wide-angle lens isn't, but the upside is that you're getting pretty much the same image quality from either camera this time around, and that's fantastic. I love that LG cares about wide-angle photography, and I appreciate that it's making appreciable improvements to the experience every year.
A pa to je sad popularno - videli od drugih kao i ostale stvari
849€ for the LG G7 with 4/64GB in Germany. WTF. My retail source was obviously off, but LG is slowing killing itself with this pricing.
Svetliji 9+Na konto osvetljenja, zar nije Note 8 najsvetliji sa 1200 nita? Ili je nesto drugo u pitanju? Notch je retardiran. Ostavi brate gornji i donji bezel, ubaci front zvucnike, senzore, sta sve treba i svi zadovoljni. Ja bih isao kontra opcijom za budale koje hoce notch. Napravis da se displej zatamni samo u tom delu gde bi notch bio pa neka se furaju koliko hoce A nama neka ostave pun ekran kako je Bog i zapovedio.
+1Još ima nade za bateriju, kažu da ekran troši 30% manje a tu je i 845. Videćemo. Dobre kamere, wireless punjenje, najsvetliji ekran bez burn in, notch koji koristi prostor gde ranije nije bilo ičega a još može i da se malo prilagodi, doduše jedan zvučnik ali takođe nikad jači, 3.5 dac ulaz a već vidim i da se šuška da će zasebno asistent dugme moći da se podesi po želji... Na prvu loptu uopšte ne deluje loše, ne znam šta ste očekivali [emoji102]
Već vidim i da se šuška da će zasebno asistent dugme moći da se podesi po želji... Na prvu loptu uopšte ne deluje loše, ne znam šta ste očekivali [emoji102]
Kako misliš dobre kamere?Još ima nade za bateriju, kažu da ekran troši 30% manje a tu je i 845. Videćemo. Dobre kamere, wireless punjenje, najsvetliji ekran bez burn in, notch koji koristi prostor gde ranije nije bilo ičega a još može i da se malo prilagodi, doduše jedan zvučnik ali takođe nikad jači, 3.5 dac ulaz a već vidim i da se šuška da će zasebno asistent dugme moći da se podesi po želji... Na prvu loptu uopšte ne deluje loše, ne znam šta ste očekivali [emoji102]
Nisu ubacili jer nemaju kapacitet da naprave svog asistenta za sada dugme može da se koristi samo za startovanje Google asistenta.Da i to je ok jer nisu ubacili svog asistenta po ugledu na onu Samsung bixby grozotu
+ će moći google assistent dugme da se koristi i za druge svrhe.
