SAMA Armor 80PLUS GOLD
newpc
Poštovan
Kod nas su počela da se pojavljuju i SAMA napajanja sa GOLD sertifikatom, sa cenom prilbližnom koju ima BRONZE ostalih prozivodjala.
Npr.:
SAMA ARMOR 80PLUS GOLD 650W
SAMA ARMOR 80PLUS GOLD 750W
Od detaljnih testova/review-a nalazim samo za FORZA TITANIUM seriju, ali ne i za ARMOR.
Da li je neko imao iskustva sa ovim napajanjima ili čak i detaljno testirao?
Ovde su rasturili 550W i bese iznenadjenje da se koriste vrhunske komponente kao i vrhunska izrada, jedina zamerka je cudna pozicija hladnjaka gde se sumnja da hladjenje nije adekvatno.
Cene su bar u Nemackoj iste sa Gold verzijama tipa BeQuiet, Enermax i sl...
MindFactory "ludaci" (korisnici koji vole da testiraju sve zivo) su napisali sledece:
6: Conclusion and rating:
In my opinion, the Inter-Tech 750 W power supply does not have to hide from top dogs such as BeQuiet !, EVGA and consorts. In terms of processing technology, Inter-Tech has really succeeded in achieving a quiet product at eye level, while the additional component securing or the "nice to have" packaging bags once again look like the icing on the cake in this category, which appeals to me personally. The actual power supply in my test system can provide a maximum power of 1 kW and is thus a performance level above the Inter-Tech. Nevertheless, the tested power supply did not want to give up and even in extreme load scenarios it was neither overheated, nor did it shut down. Whether this remains the same in 24/7 situations, I can not assure on the basis of the short test time. Also tested by me were the short-circuit protection, the overcurrent shutdown and the thermally induced shutdown and everything worked without problems. The idle shutdown has done its job.
So if you are looking for a 750 watt power supply for your rather potent gaming PC, which is not a mimosa and can sometimes perform above the specified performance, you can strike here in my opinion! At a Mindfactory price of 92.33 euros, you get an all-round good power supply for this performance class and no Chinaböller!
Enclosed a small pro / contra list:
+ Good P / L ratio
+ Additional component fuse on the board
+ Quiet fan
+ Power reserves over specification
+ Clear, no-frills design
- Only a common 12V + rail
- Maybe too little power for really potent high-end systems
Da ne bude zabune, u Ger se prodaje pod Inter tech imenom, poznati distributer jeftinih napajanja i periferija.
Sve u svemu, kvalitet je isti kao kod BeQuiet napajanja
Evo još jedan test:
http://www.expreview.com/56643-2.html
Jeftinije jeste, jeste da je tu Chemicon, Infineon i sl. ali na na ostalom se dosta štedilo. Nema kondenzatora na modularnoj tabli, lemljenje loše, štedilo se na lepku - muzički doživljaj veoma moguć...
Hvala.
U ovom drugom linku je malo detaljnije testirano. Iz teksta se navodi da su kondenzatori KMW serija, a to je svega 2000 radih sati...
http://www.chemi-con.com/data-sheets
Da, izgleda da se štedelo na svemu. I nije baš sve sjajno za GOLD sertifikat.
Za ovaj pomenuti iz FORZA TITANIUM serije, sve je takodje detaljno istestirano na 12 strana i zaključkak takodje nije baš povoljan:
https://www.techpowerup.com/reviews/SAMA/FTX-800-2/12.html
To je onda to. Hvala još jednom na linkovima.
Da li ima još neko iskustva sa gore pomenutim napajanjem?
Razmišljam se između njega i Thermaltake Smart SE 730W
