»RSS Benchmark sajt
      Strana 6 od 6 PrvaPrva ... 23456
      Prikazani rezultati od 76 do 90 od ukupno 90
      Tema: "OdySSey" project
      1. #76
        Member Avatar korisnika nessa78
        Na forumu od
        Jan 2011
        Lokacija
        downtown
        Poruka
        2.201
      2. Moja mašina
        • CPU: i7 5820k 4.5Ghz + EK WB
        • MoBo: MSI X99A Mpower
        • RAM: 16gb HyperX Predator 2666Mhz
        • VGA: SLI - Asus GTX 770 dc2 + EKWB
        • MON: Dell 27" IPS + Dell 24" IPS
        • HDD: Transcend SSD 370s 256Gb RAID0
        • OPT: Asus
        • Case: Cooler Master V1000 - "MasterX5" project
        • Ostalo: PROJEKTI: www.sspcmodding.com https://www.facebook.com/sspcmodding
      3. HyperX Predator RGB je stigao! Hvala puno na podrsci
      4. #77
        Na forumu od
        Jan 2011
        Lokacija
        downtown
        Poruka
        2.201
      5. Moja mašina
        • OPT: Asus
      6. Jos jedan detaljcic i ocekujte uskoro finalne fotke i video
      7. #78
        Na forumu od
        Jan 2011
        Lokacija
        downtown
        Poruka
        2.201
      8. Moja mašina
        • OPT: Asus
      9. Okay guys, the project is finished!
        I'm happy with the result. I've succeeded in dividing the inside of the case. I'm not a big fan of RGB but in this case, it really suits the project. The outside of the case is beautiful as it already was, I've just put on some additional touches.
        With this project I'm participating in Cooler Master WS 2018!
        https://www.cmws.global/blog/odyssey-project
        Hardware which I've used in this project is:
        Cooler Master C700P
        Cooler Master V1200 Platinum
        Cooler Master Masterfan 140 AP RGB (12pcs)
        Asus ROG Zenith Extreme X399
        Asus GTX 1080 Ti Strix
        AMD Trearipper 1900x
        RAM HyperX Predator RGB 4x8Gb 2933Mhz
        SSD HyperX Savage 240Gb
        EKWB full custom dual-loop water cooling system
        Big thanks to all of the sponsors for support!
        Menjao nessa78 : 23.06.2018. u 20:29
      10. #79
        Member Avatar korisnika Serbianboss
        Na forumu od
        Jan 2005
        Lokacija
        С Р Б И Ј А Београд
        Poruka
        1.856
      11. Moja mašina
        • CPU: AMD Ryzen3 1200 @3.5 Ghz default voltaza | EKWB custom loop
        • MoBo: Gigabyte GA-AX370 Gaming 5
        • RAM: 16GB DDR4 3000Mhz Corsair Vengance LPX + RGB heatsink
        • VGA: Sapphire RX480 Nitro + Byiski WaterBlock
        • MON: 2x HP Pavillion 23xi
        • HDD: Samsung 970EVO M2 500GB, 2TB WD Red Pro, 480 GB SSD Kingston
        • OPT: nemam :(
        • Case: Cooler Master H500P Mesh - modovano - Arctic
        • SND: Harman kardon
        • OS: Win10 Pro, Linux Debian
        • LAP: Asus N751
        • INET: Kablovska
        • Ostalo: ThermalTake 650W, Canopus ADVC 110, CoolerMaster Quick Fire XT - Cherry MX Brown
      12. jako lepo, neka je sa srecom.
      13. #80
        Newcomers
        Na forumu od
        Jul 2017
        Poruka
        29
      14. Moja mašina
        • CPU: i5 6600k 5000mhz EK voda
        • MoBo: ASRock z170 Extrime6 +
        • RAM: Corsair Vengance LPX DDR4 4x4gb 3000mhz
        • VGA: Asus GTX 1080ti EK vodeno
        • MON: ASUS VG248QE 144hz
        • HDD: Kingston NVM A1000 m2,SP S60 SSD 240gb + Patriot Burst 240gb
        • Case: Thermaltake x31
        • SND: Logitech Z506 and Logitech G35
        • OS: WIN 10
        • INET: Kablovska
      15. Bravo Neso meni se extra svidja bomba srecno!!!
      16. #81
        Na forumu od
        Jan 2011
        Lokacija
        downtown
        Poruka
        2.201
      17. Moja mašina
        • OPT: Asus
      18. Citat Citiram korisnika: Serbianboss Pogledaj poruku
        Citat Citiram korisnika: KA3HA Pogledaj poruku
        Hvala drugari, trebace srece, @Serbianboss i tebi zelim da uspesno zavrsis!
      19. #82
        Member Avatar korisnika mirza82
        Na forumu od
        Oct 2007
        Lokacija
        Cuprija
        Poruka
        4.637
      20. Moja mašina
        • CPU: F82
        • MoBo: MPOWER
        • Case: M4
        • SND: AKRAPOVIC
        • INET: Bez interneta
      21. Svaka cast, brutalno odlicno.
        Puno srece na takmicenju.
        "Nije znanje znanje znati, vec je znanje znanje dati!"
      22. #83
        Na forumu od
        Jan 2011
        Lokacija
        downtown
        Poruka
        2.201
      23. Moja mašina
        • OPT: Asus
      24. Citat Citiram korisnika: mirza82 Pogledaj poruku
        Hvala @mirza82,
        evo i vec uobicajenog intevrjua novog projekta "OdySSey", Dule i ja samo se potrudili da vam sto realnije priblizimo i prestavimo sta je sve uradjeno i kako se sve odvijalo, uzivajte
      25. #84
        Na forumu od
        Jan 2011
        Lokacija
        downtown
        Poruka
        2.201
      26. Moja mašina
        • OPT: Asus
      27. Another set of photos
      28. #85
        Na forumu od
        Jan 2011
        Lokacija
        downtown
        Poruka
        2.201
      29. Moja mašina
        • OPT: Asus
      30. Evo jos malo fotki i tu bi zavrsio sa fotkama ovog projekta
      31. #86
        Member Avatar korisnika CountMike
        Na forumu od
        Jul 2012
        Lokacija
        Beograd. Toronto
        Poruka
        6.428
      32. Moja mašina
        • CPU: Ryzen R7 3700X, CM Nepton 140XL
        • MoBo: Asus PRIME X470 PRO
        • RAM: 2x8GB Kingston Predator 3600MHz
        • VGA: Asus strix 570 OC 4gb
        • MON: BenQ 28" + 2x Samsung 2494
        • HDD: Samsung 960Evo, 250GB, SP V70 240GB, WD Blue 2TB,WD Blue 1TB
        • Case: Raidmax Agusta (customized)
        • SND: On Board
        • OS: Win 10 Pro, Linux Mint
      33. Samo mogu da kažem BRAVO, odavno nisam video ovako čistu instalaciju.
      34. #87
        Na forumu od
        Jan 2011
        Lokacija
        downtown
        Poruka
        2.201
      35. Moja mašina
        • OPT: Asus
      36. Citat Citiram korisnika: CountMike Pogledaj poruku
        Hvala, drago mi je sto ti se dopada i sto pratis moj rad!
        Project OdySSey is nominated for MOTM on BitTech forum:
        https://www.bit-tech.net/features/mo...ith-corsair/1/
      37. #88
        Member Avatar korisnika ericm
        Na forumu od
        Jun 2011
        Lokacija
        nbgd
        Poruka
        3.332
      38. Moja mašina
        • CPU: 8700K @ 4.9Ghz + D15s + HC4 ---- 6700 + Pure Rock
        • MoBo: Z370i Strix ---- VIII Impact
        • RAM: TridentZ 2x8GB 4000Mhz ---- LPX 2x8GB 2666Mhz
        • VGA: 2080 Duke OC ---- 1660Ti Gaming X
        • MON: Alienware AW3418DW ---- Predator XB241H
        • HDD: 970evo 500GB + 960evo 250GB ---- 850evo 500GB / Time Capsule 2TB
        • Case: H200i + G2 650W ---- Metis Plus + SF600
        • SND: Bose Companion 3 / B&O H6 / Bose SoundLink mini ---- Audioengine A2+
        • OS: Win 10 + Win 7 ---- macOS + Win 10
        • INET: Kablovska
        • Ostalo: ikbc C87 + EC2-B ---- ikbc C87 + EC2-A
      39. svaka cast, cestitamo
        tvoj mod je ubedljivo najelegantniji.
        it just doesn't work
      40. #89
        Na forumu od
        Jan 2011
        Lokacija
        downtown
        Poruka
        2.201
      41. Moja mašina
        • OPT: Asus
      42. Glasanje je pocelo, sve je objasnjeno u video klipu, ako vam se dopada nas rad podrzite ga!
        Link za glasanje: https://www.cmws.global/
      43. #90
        Na forumu od
        Jan 2011
        Lokacija
        downtown
        Poruka
        2.201
      44. Moja mašina
        • OPT: Asus
      45. More photos ...
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
