Bismuth [BIS]
@irsi
Poštovan
if you use optihash.exe from https://github.com/maccaspacca/stuff/releases and actual release https://github.com/hclivess/Bismuth/releases
Bismuth node isn't working on Win7 actually, but optihash as a standalone miner is!
If you want to mine on optipool (pool.bismuth.online), here is a quick help:
1.) download optihash source from maccaspacca's github-repo: https://github.com/maccaspacca/Optipoolware/releases
2.) download optihash.exe from same location (or download it after step 3, directly in the directory you extracted the source-code to)
3.) extract the files in a folder of your choice
4.) copy optihash.exe in same folder
5.) adjust miner.txt (it is the config-file for optihash)
6.) change mining-ip to 78.28.250.56 (it is pool.bismuth.online)
7.) change mining_threads
8.) change miner_address to your wallet address
9.) change miner_name (optional but useful if you run the miner on more than one machine)
10.) start optihash and wait for share to be found
using optihash under linux is basically the same, without downloading optihash.exe and start optihash.py with python3 instead of the exe-file
Linux dependency is pip3 and pysocks
sudo apt-get install python3-pip
sudo pip3 install pysocks
python3 optihash.py
Pratim ga više od godinu dana još od starog threada, na papiru izrazito zanimljivo.
Nažalost, teška šejdi priča, stalno su nešto odlagali, tj muljali, nisam ni hteo posle da se zezam sa cpu miningom.
Ali baš zbog svega toga navedenog, ovde se uleće ALL IN, ide 10x-100x puta gore.
Sat otkucava, tik-tak, tik-tak, buy all, buy all
Kopaju sa gpu-om od samog starta i imaju jakog MM. Bice fin p&d da 'distribuiraju' iskopano, kupovalo se otc po 4-5k satosija.
Zasad ide fino...uskoro idu i masternodovi, trebalo bi da bude 10k novcica za jedan.
Imali ste free dojavu, nadam se da je neko ispratio..jos nije kasno da se kopa, mislim da tek krece pump, moze potrajati par meseci
Odlična zarada, posebno sa Nvidia,čini mi se više stabilne nego AMD u ovome,mada je možda i do nedorađenog majnera)
Poslano sa mog MI 4LTE koristeći Tapatalk
Svaka čast, to je pos’o [emoji16]
Pa dobro zna li se sa Nvidia 1070 koliko se dnevno izrudari sa 6x??Odlicna zarada..nigde nema o tome ni na coinz ni na WTM?
