»RSS Benchmark sajt
      Strana 7 od 90 PrvaPrva ... 345678910111757 ... PoslednjaPoslednja
      Prikazani rezultati od 91 do 105 od ukupno 1340
      Tema: Electroneum
      1. #91
        Member
        Na forumu od
        Jun 2016
        Lokacija
        Kruševac
        Poruka
        2.084
      2. Moja mašina
        • CPU: Intel g3260 i Noctua NH-D14
        • MoBo: Asrock pro btc
        • RAM: Kingston 8gb
        • VGA: Palit gtx 1080 Game rock
        • MON: Samsung 26 inch
        • HDD: WD 500gb+WD 160gb+ssd samsung 860 evo 250gb
        • Case: Raidmax Monster II i Super Flower Leadex 2000w Platinium
        • SND: Genius gx sw-g2.1 1250 gaming edition
        • OS: Win 8.1
        • INET: Modemska veza
      3. Pa pronadji fajl pod nazivom wallet.adress idi na edit obrisi tu adresu u fajlu i stavi svoju public adresu iz Paper wallet-a.
        Evo detaljno upustvo kako lako je samo prati stavke mozes da prebacis iskopano samo za sada a ko je kupio Ico coin poput mene mora da ceka da prebaci te novcice jos nekoliko sati.
        Be sure to have your paperwallet available with all 3 adresses (public, private view, private share!)
        STEP 1
        Goto https://downloads.electroneum.com/
        Download the Windows Direct Miner (ZIP)
        Unzip it!
        STEP 2
        Press win_button + R
        A lil window will appear, type CMD and press ENTER
        STEP 3
        Browse to the root directory of the unzipped windows miner you just loaded.
        Example starting in C:\Users\Username>
        Type: cd Downloads\win-x64-0.11.0.0
        (Going the wrong path? cd.. takes you back a step.)
        STEP 4
        Check with "dir" command that files are present.
        Now we are going to restore the wallet. Type the following: electroneum-wallet-cli --generate-from-keys New_Wallet_Name.abc
        Choose whatever name you want for New_Wallet_Name.abc.
        If typed correctly it'll ask for Standard address. Copy&paste yourpublic view key. After that your private spend and view key aswell.
        Make sure to copy them to notepad before and delete every SPACE you might find. Otherwise it'll prompt you with an error.
        Last step is to secure it with a strong password. Dont miss out on this!
        STEP 5
        View your wallet.
        Navigate into your unzipped folder, its important to have the deamon running. Start electroneumd.exe. Keep it open, unblock it if firewall promp comes up.
        Now start the electroneum-wallet-cli.exe
        Its gonna ask for the wallet file name. The name you have choosen in Step 4. Type it. In this case: New_Wallet_Name.abc
        It'll ask for the password you've choosen before. Type it in.
        If done correctly it'll synch with the blockchain. Might take a few.
        Once thats done it'll show you all your transactions aswell as your balance. You are now free to update it whenever you want. Just type the following: refresh.
        Menjao Fallout 3 : 02.11.2017. u 18:42
      4. #92
        Member Avatar korisnika suboticanin
        Na forumu od
        Jul 2015
        Lokacija
        pored komsije
        Poruka
        600
      5. Moja mašina
        • CPU: i5 4690k, hladjenje, Corsair h110i gt
        • MoBo: asus z97 sabertooth mark2
        • RAM: 8gb 1600mhz
        • VGA: sapphire r9 280x
        • MON: philips 221v
        • HDD: ssd vertex 4 128gb i hdd wd5000aakx
        • Case: fractal design core 3300
        • OS: win 10
        • LAP: neki siemens
        • TV: lg 42ls5600
        • INET: DSL
        • Ostalo: napajanje cft650w
      6. To je sve sto imam
      7. #93
        Member
        Na forumu od
        Jun 2016
        Lokacija
        Kruševac
        Poruka
        2.084
      8. Moja mašina
        • RAM: Kingston 8gb
        • OS: Win 8.1
      9. Si skinuo sva 3 fajla odavde https://github.com/zone117x/cryptono...iner/releases/ ?
        Onda kad skines sva 3 fajla moras da ih raspakujes takodje.
        I onda moras da imas wallet.adress negde.
        Ako ih opet nemas skini https://downloads.electroneum.com direct mining sofware i pokreni ga i sacekaj da se sinhronizuje onda opet pogledaj da li imas wallet.adress fajl.
        Menjao Fallout 3 : 02.11.2017. u 18:57
      10. #94
        Na forumu od
        Jul 2015
        Lokacija
        pored komsije
        Poruka
        600
      11. Moja mašina
        • RAM: 8gb 1600mhz
        • MON: philips 221v
        • OS: win 10
        • LAP: neki siemens
        • TV: lg 42ls5600
        • INET: DSL
      12. Ja mislim da sam sve uradio kako si rekao. Miner died stalno ispisuje
      13. #95
        Member
        Na forumu od
        Jun 2016
        Lokacija
        Kruševac
        Poruka
        2.084
      14. Moja mašina
        • RAM: Kingston 8gb
        • OS: Win 8.1
      15. U wallet address stavis samo adresu tvoju bez share i private key....I to samo public adresu iz Paper wallet-a.A za paper wallet moras da se registrujes na electroneum i da ga posle tamo napravis si uradio to?
        Vidis da ti pise private key unknown comand.
        Kad otvaras prvi put wallet.address pisace ti neka adresa tu adresu slobodno obrisi i ubaci tvoju iz Paper wallet-a.
        Menjao Fallout 3 : 02.11.2017. u 19:35
      16. #96
        Na forumu od
        Jul 2015
        Lokacija
        pored komsije
        Poruka
        600
      17. Moja mašina
        • RAM: 8gb 1600mhz
        • MON: philips 221v
        • OS: win 10
        • LAP: neki siemens
        • TV: lg 42ls5600
        • INET: DSL
      18. Sve mi je jasno sto si mi napisao, dobio sam adresu kad sam isao na offlinepaper wallet imam je u pdf. Unesem je wallet.adress, kad pokrenem miner, tamo mi je adresa ali ne mrda dalje
      19. #97
        Member
        Na forumu od
        Jun 2016
        Lokacija
        Kruševac
        Poruka
        2.084
      20. Moja mašina
        • RAM: Kingston 8gb
        • OS: Win 8.1
      21. I sta se desava kad kliknes start mining?Izbacuje gresku ili?
        Probaj port 3333.
        Probaj da stavis cpu cores 1 ili 2 a ne 3.Koji to procesor imas pa si stavio 3 cores?Ako imas taj iz potpisa treba da stavis cpu cores 4 a ne 3 jer ima 4 jezgra.
        Ako imas neki razmak u samoj adresi moras da ih sastavis mozda zbog toga nece.
        Si kliknuo na save kad si stavio tvoju adresu u wallet?
        U pool host stavis samo electroneum.hashparty.io i nista vise.
        Menjao Fallout 3 : 02.11.2017. u 20:31
      22. #98
        Na forumu od
        Jul 2015
        Lokacija
        pored komsije
        Poruka
        600
      23. Moja mašina
        • RAM: 8gb 1600mhz
        • MON: philips 221v
        • OS: win 10
        • LAP: neki siemens
        • TV: lg 42ls5600
        • INET: DSL
      24. Miner died
        Da da save
      25. #99
        Member
        Na forumu od
        Jun 2016
        Lokacija
        Kruševac
        Poruka
        2.084
      26. Moja mašina
        • RAM: Kingston 8gb
        • OS: Win 8.1
      27. Probaj sve gore napisano mora da ti proradi ne postoji niko kome ne radi.
        Posalji mi public adresu na pm da vidim da li ima razmake ako te ne mrzi.Ja tu public adresu ionako ne mogu da koristim bez one 2 adrese jos sto su u Paper walletu.
        Nema virus sigurno ne znam sto ti to izbacuje.
        Evo kako je kod mene.http://prntscr.com/h5ene4
        Jel ti graficka kopa nesto trenutno?
        Menjao Fallout 3 : 02.11.2017. u 20:39
      28. #100
        Na forumu od
        Jul 2015
        Lokacija
        pored komsije
        Poruka
        600
      29. Moja mašina
        • RAM: 8gb 1600mhz
        • MON: philips 221v
        • OS: win 10
        • LAP: neki siemens
        • TV: lg 42ls5600
        • INET: DSL
      30. Novo njesra
        Samo je restart falio
        Menjao suboticanin : 02.11.2017. u 20:41
      31. #101
        Member
        Na forumu od
        Jun 2016
        Lokacija
        Kruševac
        Poruka
        2.084
      32. Moja mašina
        • RAM: Kingston 8gb
        • OS: Win 8.1
      33. Opet to ne valja stratum se nije povezao vidis da pise stratumrecvlinefailed ne kopa to nista trenutno.Probaj da pokrenes opet onaj program njihov direct mining software od 106 mb u njemu nadji electroneumd i pokreni i sacekaj da se zavrsi sinhronizacija i nemoj da ga zatvaras,pa onda pokreni miner i vidi da li ti se stratum povezao kako treba.
        U svakom slucaju hash je tacan i dobar taj procesor kopa 90 h/s sto je ekstra u odnosu na ovaj moj .
        Jel si siguran takodje da ti adresa nema razmake da su sva slova jedna do drugog?
        Menjao Fallout 3 : 02.11.2017. u 20:50
      34. #102
        Newcomers
        Na forumu od
        Oct 2017
        Poruka
        21
        Meni radi ovako kako je fallout napisao i kopa mi 28h/s na i3. Samo me interesuje da li mogu sa tri kompa na istu wallet adresu i gde mogu da proverim koliko je iskopano?
        Послато са SM-G925F уз помоћ Тапатока
      35. #103
        Member
        Na forumu od
        Jun 2016
        Lokacija
        Kruševac
        Poruka
        2.084
      36. Moja mašina
        • RAM: Kingston 8gb
        • OS: Win 8.1
      37. Ne vidim sto ne bi mogao ljudi kopaju sa 1000 grafickih odjedanput ovo.Mozes na istu wallet adresu sto da ne.
        Mozes da proveris na pool-u na kojem kopas.Videces dole na electroneum.hashparty.io samo ubacis svoju adresu i kliknes na lookup.
        Menjao Fallout 3 : 02.11.2017. u 20:54
      38. #104
        Member Avatar korisnika undertaker_84_
        Na forumu od
        Mar 2004
        Lokacija
        Novi Sad
        Poruka
        915
      39. Moja mašina
        • CPU: Intel i7-5960X EKWB
        • MoBo: Asus STRIX X99 Gaming
        • RAM: Corsair 4 x 8GB DDR4 3000MHz
        • VGA: SLI Asus GTX 1080ti EKWB
        • MON: 34" Asus ROG PG348Q
        • HDD: Plextor 1TB M8Pe(G) M.2 PCIe
        • Case: Chieftec BX-B-B-B-03
        • SND: Logitech Z-5500
        • OS: Windows 10 PRO x64
        • LAP: HP 440 g4
        • TV: Samsung PS50C530
        • INET: DSL
      40. Pored grafika koje na komad bacaju preko 20x vise hash-a mislim da nema smisla kopati procesorom.
      41. #105
        Member
        Na forumu od
        Jun 2016
        Lokacija
        Kruševac
        Poruka
        2.084
      42. Moja mašina
        • RAM: Kingston 8gb
        • OS: Win 8.1
      43. Meni procesor kopa Etn a grafe kopaju Zen-a tako da ono ne gledam sta se isplati koliko iskopa iskopa nije bitno .Ionako holdujem .
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
