»RSS Benchmark sajt
      Strana 3 od 11 PrvaPrva 1234567 ... PoslednjaPoslednja
      Prikazani rezultati od 31 do 45 od ukupno 151
      Tema: ZenCash
      1. #31
        Member Avatar korisnika Stormbringer_bg
        Na forumu od
        Sep 2000
        Lokacija
        Blok 30
        Poruka
        3.110
      2. Moja mašina
        • CPU: I5-3570K 3.4 @ 4.0 GHz & OCZ Vendetta 2
        • MoBo: Sapphire P67 Hydra Pure Black
        • RAM: Kingston Savage 2 x 8 GB ddr3 1866 MHz, 9,10,10,24, 1T, 1.5 V, DC
        • VGA: Sapphire Nitro+ SE RX580 8 GB
        • MON: 24" Dell U2412M IPS/LED
        • HDD: Samsung 840 EVO 250 GB & 2 TB WD Black 7200 rpm & 3x3 TB WD Red 5400
        • OPT: LD DVD-RW GH24NSD1 Sata
        • Case: Cooler Master V750 W & Thermaltake Urban T31
        • SND: Audigy 2/Logitech X-530
        • OS: Windows 7 64-bit SP1
        • INET: Kablovska
      3. I kod mene se sve raspada.
      4. #32
        Member
        Na forumu od
        Mar 2014
        Poruka
        78
        upravo je objavio OC : Hmm nothing I can do at the moment, I've tried all kinds of possibilites but the blocks simply get orphaned .. Not rejected, not errors whatsoever, they get mined fine and after the next block they're orphaned. I've compared transactions, blocks, nonces etc.. all is good, i've tried z-nomp as well with no luck..
        I'll give it up for now, without any error message it's hard to debug as well.
      5. #33
        Newcomer
        Na forumu od
        Apr 2016
        Poruka
        141
        Zasto ne probate solo mining ako diff nije prevelik? Barem ljudi koji imaju po par rigova? Da li blok vredi 12.5 zena kao kod zeca?
        Ljudi kod zec/zen nije prosti copy/paste koda sa izmenjenim parametrima kao kod btc/ltc
        procitajte ovo mnogo je interesantno...
        https://forum.z.cash/t/cross-chain-a...-stellar/13524
        Menjao MrClean : 31.05.2017. u 16:26
      6. #34
        Member
        Na forumu od
        Aug 2016
        Poruka
        1.307
        mislim da mu je diff krenuo od diffa zclassica
      7. #35
        Newcomer
        Na forumu od
        Apr 2016
        Poruka
        141
        Znaci nema sanse da se udari block za dan sa recimo 3 kilo sola?
      8. #36
        Member Avatar korisnika fearco
        Na forumu od
        Aug 2007
        Lokacija
        Novi Sad
        Poruka
        632
      9. Moja mašina
        • CPU: i5 4460
        • MoBo: asus b85 PG
        • RAM: fury 8gb
        • VGA: shapphire 280x dual x vapor
        • MON: crt
        • HDD: ssd samsung evo 256gb
        • Case: vortex
        • SND: Creative SB Live 5.1, Altec Lansing atp-3
        • INET: DSL
        • Ostalo: Mish Logitech G5, slushke altec lansing ahp 524!
      10. Na suprnova pulu vise puca nego sto radi, dok na miningspeed pulu radi odlicno.
        da te ponudim necim slatkim.......salcici
      11. #37
        Member
        Na forumu od
        Aug 2016
        Poruka
        1.307
        samo da ne bude na kraju da ste se badava kopali
        Ja sam se vratio na zec-a.
      12. #38
        Member
        Na forumu od
        Aug 2016
        Poruka
        1.307
        Evo ima ga na bittrexu ali je wallet under maintenance
      13. #39
        Member Avatar korisnika gsi5555
        Na forumu od
        Oct 2008
        Lokacija
        BG
        Poruka
        771
        Ja sam imao par desetina ZCL na bittrexu, i dobio sam isto toliko ZEN coina. i meni stoji vec 10 dana wallet under maintenance, nadam se da ce ga pustiti do sutra...
        ZCL je pre razdvajanja bio 10$, posle 110000 bloka pao je na 3.5$, tako da mislim da ZEN ne bi trebao da bude ispod 5$, s obzirom da je ceo DEV tim presaltan na ZEN.
        u oktobru bice u novembru, u novembru bice u decembru
      14. #40
        Member
        Na forumu od
        Aug 2016
        Poruka
        1.307
        ja nekako nisam za kopanje na one temporary adrese, nekako ta adresa nije pod mojom kontrolom, odnosno pod kontrolom menjacnice...
      15. #41
        Banned
        Na forumu od
        Dec 2001
        Lokacija
        Novi Sad
        Poruka
        13.382
      16. Moja mašina
        • CPU: i5 4570 & Alpenfoehn Brocken cooler
        • MoBo: Asus z87-a
        • RAM: Kingston 2x 8Gb 2400Mhz
        • VGA: HD4600 + MSI 1070 + 290x
        • MON: Samsung C530 + Acer 22inc
        • HDD: Samsung evo 250Gb + Samsung 2TB
        • OPT: NEC 5240
        • Case: CM Trooper, Seasonic SS-750KM3
        • SND: integrusa
        • OS: Win 10 x64
        • INET: Kablovska
        • Ostalo: Pinnacle PCTV
      17. Onaj sajt sto je delio kao zen adrese je nestao
      18. #42
        Member
        Na forumu od
        Aug 2016
        Poruka
        1.307
        Pa to ti i kazem, navukli su garant na hiljade ljudi kao evo vam temporary adresa kopajte tu, i onda... nestanu...
        Ako ocminer kaze da postoje problemi sa coinom, i ugasio je taj pool dok se ne srede, onda je to tako.
        Pretpostavljam da svi ovi drugi koji "isplacuju" su navlakuse, jer je ocigledno da neki problem sa coinom postoji.
        Menjao d.darko : 01.06.2017. u 07:19
      19. #43
        Na forumu od
        Sep 2000
        Lokacija
        Blok 30
        Poruka
        3.110
      20. Moja mašina
        • INET: Kablovska
      21. Sajt bre radi, ne ložite ljude bezveze.
      22. #44
        Banned
        Na forumu od
        Dec 2001
        Lokacija
        Novi Sad
        Poruka
        13.382
      23. Moja mašina
        • MoBo: Asus z87-a
        • OPT: NEC 5240
        • SND: integrusa
        • OS: Win 10 x64
        • INET: Kablovska
      24. Sad radi, nije bio updatoovan ~12h, videt cemo kazu da su spavali
      25. #45
        Newcomer
        Na forumu od
        Apr 2017
        Lokacija
        Novi Sad
        Poruka
        57
        Evo da vam predlozim nas domaci pool za ZenCash. Bilo bi lepo da nas ima vise!
        http://zpool.crypto.ba/getting_started
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
