»RSS Benchmark sajt
      Strana 10 od 10 PrvaPrva ... 678910
      Prikazani rezultati od 136 do 150 od ukupno 150
      Tema: ZenCash
      1. #136
        VIP member Avatar korisnika Dandy
        Na forumu od
        Jul 2000
        Lokacija
        Beograd, Banovo Brdo
        Poruka
        9.138
      2. Moja mašina
        • CPU: Core i5-3570K @ 4.2GHz, Cooler Master Hyper 412S
        • MoBo: Asus P8Z77-V Deluxe
        • RAM: 16GB DDR3 @ 1333
        • VGA: Gigabyte Radeon HD6950 2GB DDR5
        • MON: Dell U2711
        • HDD: 256GB SSD + 60 GB SSD + 500GB + 640GB + 1TB + 1x1.5TB + 3x2TB + 2x3TB + 2x4TB
        • OPT: LG
        • Case: Fractal Design XL, Cooler Master Real Power Pro 1250W
        • SND: Integrisana + Philips pojačalo godište 1984. i Jamo zvučnici 2x150W sinusne snage
        • OS: Win7 x64
        • LAP: Toshiba Satellite P200-1I6
        • INET: Kablovska
      3. ZenCash: Technical & Fundamental Analysis
        https://steemit.com/cryptocurrency/@...ental-analysis
        "Before you speak, ask yourself, is it kind, is it necessary, is it true, does it improve on the silence?"
      4. #137
        Na forumu od
        Jul 2000
        Lokacija
        Poruka
        9.138
      5. Moja mašina
        • MON: Dell U2711
        • OPT: LG
        • OS: Win7 x64
        • INET: Kablovska
      6. "Before you speak, ask yourself, is it kind, is it necessary, is it true, does it improve on the silence?"
      7. #138
        Member Avatar korisnika Stormbringer_bg
        Na forumu od
        Sep 2000
        Lokacija
        Blok 30
        Poruka
        3.044
      8. Moja mašina
        • CPU: I5-3570K 3.4 @ 4.0 GHz & OCZ Vendetta 2
        • MoBo: Sapphire P67 Hydra Pure Black
        • RAM: Kingston & Crucial Balistix 4 x 4 GB ddr3 1600 MHz, 8,9,9,24, 2T, 1.6 V, DC
        • VGA: MSI RX570 8 GB Armor
        • MON: 24" Dell U2412M IPS/LED
        • HDD: Samsung 840 EVO 250 GB & 2 TB WD Black 7200 rpm & 3x3 TB WD Red 5400
        • OPT: LD DVD-RW GH24NSD1 Sata
        • Case: Cooler Master V750 W & Thermaltake Urban T31
        • SND: Audigy 2/Logitech X-530
        • OS: Windows 7 64-bit SP1
        • INET: Kablovska
      9. Zato je zen divljao noćas do 0.009 btc
      10. #139
        Na forumu od
        Jul 2000
        Lokacija
        Poruka
        9.138
      11. Moja mašina
        • MON: Dell U2711
        • OPT: LG
        • OS: Win7 x64
        • INET: Kablovska
      12. ZenCash Statement On Double Spend Attack
        https://blog.zencash.com/zencash-sta...-spend-attack/
      13. #140
        Na forumu od
        Jul 2000
        Lokacija
        Poruka
        9.138
      14. Moja mašina
        • MON: Dell U2711
        • OPT: LG
        • OS: Win7 x64
        • INET: Kablovska
      15. "Before you speak, ask yourself, is it kind, is it necessary, is it true, does it improve on the silence?"
      16. #141
        Na forumu od
        Jul 2000
        Lokacija
        Poruka
        9.138
      17. Moja mašina
        • MON: Dell U2711
        • OPT: LG
        • OS: Win7 x64
        • INET: Kablovska
      18. ZenCash postaje Horizen
      19. #142
        Na forumu od
        Jul 2000
        Lokacija
        Poruka
        9.138
      20. Moja mašina
        • MON: Dell U2711
        • OPT: LG
        • OS: Win7 x64
        • INET: Kablovska
      21. Software Upgrade: ZEN 2.0.15 And 51% Attack Prevention
        scheduled for release on September 27th, 2018.
        https://blog.zencash.com/zen-software-upgrade-2-0-15/
      22. #143
        Na forumu od
        Jul 2000
        Lokacija
        Poruka
        9.138
      23. Moja mašina
        • MON: Dell U2711
        • OPT: LG
        • OS: Win7 x64
        • INET: Kablovska
      24. "Before you speak, ask yourself, is it kind, is it necessary, is it true, does it improve on the silence?"
      25. #144
        Na forumu od
        Jul 2000
        Lokacija
        Poruka
        9.138
      26. Moja mašina
        • MON: Dell U2711
        • OPT: LG
        • OS: Win7 x64
        • INET: Kablovska
      27. Horizen Sidechains White Paper: Decoupled Consensus Between Chains
        https://blog.zencash.com/horizen-sid...ain_whitepaper
        Horizen’s sidechains will allow everyone to introduce exciting new functionalities by developing blockchain-based applications that are able to safely exchange coins with the mainchain in a decentralized and distributed way. Horizen’s sidechain SDK will hide the complexity of the cross chain transfer protocol and will provide a solid base for blockchain based application development.
      28. #145
        Na forumu od
        Jul 2000
        Lokacija
        Poruka
        9.138
      29. Moja mašina
        • MON: Dell U2711
        • OPT: LG
        • OS: Win7 x64
        • INET: Kablovska
      30. Huobi Global Lists Horizen(ZEN) on November 07, 14:30 (GMT +8)
        Click image for larger version.
        https://huobiglobal.zendesk.com/hc/e...7-14-30-GMT-8-
      31. #146
        Member
        Na forumu od
        Jan 2014
        Poruka
        114
        Kako ce sve ove vesti uticati na gpu minning?
      32. #147
        Na forumu od
        Jul 2000
        Lokacija
        Poruka
        9.138
      33. Moja mašina
        • MON: Dell U2711
        • OPT: LG
        • OS: Win7 x64
        • INET: Kablovska
      34. Mandatory Software Upgrades: ZEN 2.0.16
        https://blog.zencash.com/mandatory-s...es-zen-2-0-16/
        A new version of ZEN (2.0.16) is scheduled for release on January 2nd, 2019. All mining pools, node operators, and full node wallet users must upgrade to ZEN 2.0.16 prior to block 449312, which will occur around January 18th.
        ZEN 2.0.16 replaces the current version 2.0.15, which is set to deprecate (no longer run). Please note, the new version includes a mandatory network upgrade at block 455555, which will occur around January 29th. There is going to be a testnet network upgrade at block 369900 as well, expected to occur around December 29th. Pool operators are encouraged to test the mining software compatibility on testnet.
        The major focus of this version is the introduction of a new shielded transaction (type: -3) that will replace the current one (type: 2). Type -3 uses a new Zero Knowledge proving system based on Groth16, that brings significant benefits compared to the current circuit, including more robustness, more speed in making the proof and verification, and reduces memory usage. This change is a first step towards supporting/integrating Sapling.
        The update also modifies the block mining reward allocated to the Treasury, increasing it from 10% to 20%. This will allow the Foundation to enable sustainable & continuous operations in a negative economic conjuncture, as described HERE. The new block reward will be then split as follows:
        10% to Secure Nodes
        10% to Super Nodes
        60% to Miners
        20% to Treasury
      35. #148
        Na forumu od
        Jul 2000
        Lokacija
        Poruka
        9.138
      36. Moja mašina
        • MON: Dell U2711
        • OPT: LG
        • OS: Win7 x64
        • INET: Kablovska
      37. Jan 29th, 2019 – We are proud to announce that we have successfully completed the Horizen hard fork!
      38. #149
        Na forumu od
        Jul 2000
        Lokacija
        Poruka
        9.138
      39. Moja mašina
        • MON: Dell U2711
        • OPT: LG
        • OS: Win7 x64
        • INET: Kablovska
      40. Horizen’s Latest Upgrade Fixes Zk-SNARKS Vulnerability
        https://blog.zencash.com/shielded-tr...and-zk-snarks/
        On November 13, 2018, the ZCash team approached Horizen regarding a technical concern associated with zk-SNARKs shielded transactions. After careful evaluation of the technical concern and Sapling release, the Horizen team implemented a subset of Sapling features (Groth16) that directly affected the concerned codebase and released the fix with ZEN 2.0.16 release.
      41. #150
        Na forumu od
        Jul 2000
        Lokacija
        Poruka
        9.138
      42. Moja mašina
        • MON: Dell U2711
        • OPT: LG
        • OS: Win7 x64
        • INET: Kablovska
      43. Horizen Is Now Available On HitBTC Exchange
        https://blog.zencash.com/horizen-listed-on-hitbtc/
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
