Second half flagship smartphone Samsung Galaxy Note 8 is coming is expected to be released in New York on 26 August.
A Samsung Electronics official said on August 20, "The Galaxy Note 8 will be released at the unpacking event in New York, USA on Aug. 26." The schedule may be pulled for a day or two depending on whether or not the place is confirmed. It will be done on the scheduled date."
Initially, note 8 was likely to be released in September. According to the Galaxy Note 7 discontinuance, the rumor was more convincing than the early release. More specifically, it is expected to appear in IFA 2017 , the European consumer electronics exhibition in Berlin, Germany, starting September 1 .
In a word, the specification of note 8, Galaxy S8 plus dual camera and the Notebook series identity S Pen combined smart phone 'is. The exterior design, including the Vicks Bebutton, is similar to the Galaxy S8 plus, meaning it did not change significantly. Iris, facial recognition, and so on.
Note 8, however, compared to the Galaxy S8 series, the rear camera has changed to dual, and the S pen has been slightly upgraded. The screen is slightly larger than the infiniti display of the Galaxy S8 +, which is 6.2 inches, by 6.3 inches. Like the Galaxy S8, the fingerprint sensor remains on the back. The location was just next to the camera, so the inconvenience was moved to the middle.
In the end, it is said that the fingerprint sensor is not realized in the note 8 due to the problems such as the recognition rate. A Samsung official said, "I know there were some prototypes of Note 8 that can be fingerprinted on the display, but the test speed and recognition rate seemed to be worse than I thought."
I smanjenim kapacitetom baterije kao i obicno, do tamo nekog Note 9-10.Maltene isti mob kao s8+ sa dodatkom olovke i dual kamere.
Ne znam da li koristite S8 i meni je bilo skroz bzv mesto dok nisam poceo da ga koristim i sad mi je skroz ql, cak i bolje nego na G6 npr koji ima fp senzor po sredini.
Pa ponovo će prodati priču u fazonu evo vam Iris skener 3.0 , ko još koristi senzor za otisak itd itd. Ubeđen sam da će biti isti kao sa ovih renderaIskreno se nadam da nece izgledati ni ovako kako je Pakao okacio , a ni Sumadinac , ovaj OnLeaks render izgleda bas uzasno sto se tice poledjine uredjaja , ako vec mora dual kamera nazad onda nek bude u horizontalnom polozaju , nikako vertikalnom , pa jos da gura otisak prsta nazad i sve da ih redja vertikalno pa na sta bi to licilo ? Mogu onda i back i recennt apps isto da stave na poledjinu pa nek ih korisnik juri gde su i sta su...napred samo displej i to je to...
