Kineski polovi koji su ujedno i BTC i LTC, odlucili su da litecoin bude zrtva borbe segwit-a protiv bitcoin unlimited-a (BTC), i tako vec 2 meseca blokiraju zvanicni klijent koji signalizuje Segwit iako preko 90% korisnika i investitora su za isti kao i Coblee koji je ovu inicijativu pokrenuo pre vise od 6 meseci
Segwit bi dao jasnu poruku berzama i klijentima da ce LTC transakcije u narednih 10 godine biti marginalne a uz pomoc Lightning-a bice moguce izvrsiti i do 1000 puta vise transakcija nego danas!
Mozda jedina velika sansa je problem BTC fee-a koji LTC zbog kineskih polova naisao na totalnu blokadu od istih jer isti imaju INTERES velikog fee na BTC-u i tu je LTC samo koleteralna steta za njih
Zato cu ja reddit-u javno predloziti softfork ili hardfork na algo koji je iskljucivo GPU i za koji bi bilo jako tesko napraviti asic
Primer drafta dajem ovde:
Malim vas da date predloge...... cak i oni koji ne vide sustinu LTC-a bolje da ga mi kopamo nego da isti ide u ruke kinezima koji za isti NISU uradili nista 3 godine!!!
Decentralize LTC mining, switch to GPU POW
We all know that in past years we only see asic miners dumping, while BTC is having problems with block overload. What did litecoin did?
NOTHING at all?
Few Chinese pools decided to block any litecoin development and usability by blocking Segwit and in the process made litecoin weak and controlled by a few greedy people!
I propose that we soft fork to dual POW mining with GPU or even hard fork to some GPU heavy algo for which it is infeasible to create fast ASICs, or at least make it very expensive.
It could be equihash or some varient or lyra2 algo tuned for GPU
I am 100% sure 95% GPU miners would be open and eager to push segwit, that move would also make as on radar of huge number of people mining it
At same way we would decentlaize mining all over a world!
In past I was never for hard fork or algorithm change, but if you as an investor and user of litecoin became hostage of 2-3 pools which have zero respect for the future and community, is it not right to do what majority wants?
