Ispalo bolje nego sto sam mislio za ipc. Jedino zao sto je tezak za OC. Stvarno ispalo plafon 4,2GHz. Ocekivao sam da svaki primerak gura preko 4, a ovako sam malo razocaran sto se toga tice. Cekam leto, da malo sazrije.![]()
Primecujem. Ne zanima mene igranje Crysis 3 nego endzin kako radi pod opterecenjem. Jer ga Star Citizen gura do krajnjih granica, neverovatno procesorski zahtevna igra. Kao ta trava samo jos gore i tako kroz citavu multiplejer sekciju u otvorenom svemiru. Samo nisam znao da vidi vise od 4C/8T. Valjda ce neko i Star Citizen da testira, da vidimo kako se tamo ponasa.
Fino radi u Dishonored 2, mada ne kao u Crysis 3. Kod DH2 je Haswell-E ipak znacajno jaci klok za klok. Nego im nisu konzistentna podesavanja, variraju frekvencije mnogih procesora od testa do testa. Negde su svi na default, nego max OC. Valjda zavisi od toga da li je igra stabilna pod OC ili ne.
Eh da, koliko je smesan 8350 u odnosu na Ryzen. Smesan je i onaj 2C/4T Pentium, takozvani best buy.
Guru 3D komentar vezano za Gaming performanse:
Francuzi su prvi tvitovali odličnu brzinu IMC-a i lošu latenciju pre neki dan.So here is where we need to write an entire paragraph. You have been able to see that the Ryzen 7 1800X performance is good, but not just yet 100% where it needs to be. During the past week we have been going back and forth to figure out what could be causing the relatively lower game performance. To date, we have no valid answer to that. The graphics card runs properly at PCI-Express x16 3.0. We know from the RAW and synthetic performance benchmarks that the cores are fast enough, in fact VERY fast. Somehow that does not relate to game performance. It will be interesting to see if other media / websites will show similar results to ours. It rather feels and smells a little like what Nvidia has been fighting a while ago, a DPC latency issue. Next to that we find Ryzen 7 rather memory bound with fairly high memory latency in the 80 to 100ns+ ranges depending on your configuration. It is what it is though, the performance definitely is good enough for what it needs to be, but currently at 1080P with a fast enough GPU the performance lacks a little compared to where it needs to be and can be. I will need to give AMD the benefit of the doubt here, the platform is young and everything is new. The processor certainly is fast enough compared to the Intel 59xx / 69xx counterparts. We will keep an eye on this and when we have to report anything about it we'll update this content. And also in closing on this topic, if you are a little GPU bound or use 2560x1440, this really is a non-issue as perf there is top notch.
#RadeonRebellion against electrical safety
Nije neophodna, Hero je tako dobro napravljena ploca da je vise za ln2. Ali opet da kupujem i da ocu da OCujem, uzeo bih Hero. 45C VRM tokom stres testa, haos.
To je cisto do mene i toga sto se lozim na kvalitetne ploce
BF1 ne koristi sva jezgra vec 10-ak thread-ova. Nazalost nismo probali SMT OFF, iako smo imali info da ce dosta igara bolje raditi, ali nazalost vreme nije dozvoljavalo. Verovatno cemo se na to vise okrenuti kada budemo testirali 4/6core modele.
BTW. Video sam dosta rezultata gde Ryzen jako kasni na 1080p, dok na 2k tera egal ili bolje. Cisto da imate info, AMD je obavestio reviewere da stave high performance plan u windowsu za gaming testove, jer je zbog downclocka/parkiranja jezgara 1080p rezultat dosta losiji bio.
Da li je to do BIOS-a i power saving opcija ili windows ne ume jos lepo da radi sa arhitekturom, ne znam.
Procesor kida i sad vam ne valja što ne može na 5ghzVerovatno će neki 4/8 moći na 4.5ghz odma sahraniste cpu.
Menjao PCBeast : 02.03.2017. u 16:33
to je i najavljeno ... a ne najbolji za game-ing ...
odvaljuje intel od 1300$ , i neki ladno napisu "fail" ...![]()
pitanje je kako Ryzen radi i komunicira sa AMD gpu-om, svi testovi radjeni sa nekim Nvidijama, mogao je neko da uzme i Fury-x pa da uradi testove vise je Fury ovisan o procesoru nego Pascal kartice, nesto ne stima u multimedia testovima i odredjenim igricama, tamo gdje se testovi oslanjaju cisto na sirovu snagu procesora - Ryzen kida.
Boga mi, nesto slabija performansa u igricama.
https://youtu.be/caDxAJMAu0w
Sent from my A0001 using Tapatalk
Can i root that?
Bookmarks
