Da li je reseno premotavanje emisija?Pokušavam da ga pokrenem na tv-u ali nikako ne ide,non stop izbacuje grešku,PRV eon 21.7.6 android armv7a.zip.
Malo više informacija,koja verzija kodija,koja greška...Pokušavam da ga pokrenem na tv-u ali nikako ne ide,non stop izbacuje grešku,PRV eon 21.7.6 android armv7a.zip.
Verovatno si skidao sa githuba-a?Kodi omega greška za eon adons addon failed to install due to invalid structure,probao sve isvašta, sad mi ni kodi ne vidi zip fajl koji prebaci na tv .
Vraćanje radi ali samo premotavanje ne...Da li je reseno premotavanje emisija?
Jedna od izmena kod mene na fs 4k max v2 je da ne radi. Radi ali neće da izlista strimove, kao izbroji sve ali se ne desi ništa ili kaže 'item failed to play'.Nova jubilarna verzija 0.1.100 Elementuma je izasla. Ima dosta izmena, pa ko voli...
v0.1.100 izmene:
- Many changes around caching and parsing speed to make browsing faster.
- Changed default 'gold' color to 'bold' to show properly on light backgrounds. (Thanks to @vasilky3)
- Removed auto-scrape functionality to avoid bombing websites with search queries.
- Fixed listing TMDB countries/languages.
- Added config setting to avodi installing Elementum standalone repository.
- Added config setting for order of public DNS-over-HTTPS services.
- Many changes around Trakt lists rendering and Arts selection in general. (Thanks to @antonsoroko, @matke-84)
- Added config settings for Second Language to be used if Primary language translation is not available.
- Replaced Opensubtitles.org with Opensubtitles.com API.
- Thanks to @antonsoroko , @vasilky3 , @matke-84 , @GladistonXD and other people (sorry for not mentioning you, ping me to fix this) who took part in reporting issues, testing, development!
