»RSS Benchmark sajt
      Strana 4 od 4 PrvaPrva 1234
      Prikazani rezultati od 46 do 51 od ukupno 51
      Tema: Core i7 7700K Overcloking
      1. #46
        Member
        Na forumu od
        Jul 2001
        Poruka
        2.704
      2. Moja mašina
        • CPU: i5 6600k@4.6GHz Megahalems Rev.B 2xScythe 800rpm ||| i7 960@4.2GHz LC-CC-120
        • MoBo: Asus Z170-A / Gigabyte GA-EX58-UD4P
        • RAM: G.SKILL Trident Z F4-3200C16D-16GTZ / Mushkin Enhanced Silverline 12GB
        • VGA: MSI GTX 1060 Gaming X 6G / Gigabyte GV-N660OC-2GD
        • MON: BenQ G2420HD / BenQ GW2270
        • HDD: 128GB/1.5TB/2TB | 128GB/1TB
        • Case: Fractal Design Arc XL CM G650M | CM 690 II Advanced Corsair VX450W
        • SND: FX Audio DAC - X6 / Harman Kardon / Infinity
        • OS: Windows 8.1 x64 Enterprise N / Windows 8.1 x64 Enterprise
        • LAP: Lenovo ThinkPad T420s
        • TV: Samsung UE46F6500SB
        • INET: Kablovska
        • Ostalo: iPad mini
      3. Citat Citiram korisnika: G955F Pogledaj poruku
        Thermal Grizzly Hydronaut sam stavio.
        5ghz na 1.37v, ali temperatura je ludili u fazonu 90+
        Atačment 231997
        Atačment 231998
        Atačment 231999
        Sama pasta izgleda da se osusila, tesko se maze.
        Mislim da si previse paste stavio
      4. #47
        Banned
        Na forumu od
        Jun 2017
        Poruka
        45
        Citat Citiram korisnika: Alister Pogledaj poruku
        Da, upravu si.
        Thermal the Grizzly Hydronaut
        Variation older. Here, the manufacturer has already said about the items and use the acceleration, coupled with efficient water cooling system. Well, she and Hydra. Unlike Aeronaut'a, consistency has changed. Pasta is not liquid, slightly more complicated is spread on the surface, but after the warm-up on the radiator and fingerprinting observed the remains of a small layer. To draw an analogy, remember the creation Noctua - application process is almost identical.
      5. #48
        Banned
        Na forumu od
        Jun 2017
        Poruka
        45
        5.0ghz 1.39v
        4.8ghz 1.27v.
        0.12v razlika za 200mhz je mnogo.
      6. #49
        Member Avatar korisnika KOLOS
        Na forumu od
        Nov 2007
        Poruka
        1.824
      7. Moja mašina
        • CPU: i7-3770K | EK-Supremacy EVO
        • MoBo: Asus Maximus V Gene
        • RAM: Corsair Vengeance Pro 16GB
        • VGA: GTX 1070 FE | EK-FC1070 GTX
        • MON: BenQ GW2406Z
        • HDD: Samsung 850 EVO 500GB
        • Case: Fractal Design Define R5
        • TV: LG 42LB650V
      8. Nije mnogo ~100mV jer nije isto 200MHz sa 4.8 na 5 i npr. 4.3 na 4.5GHz, gde bi recimo bio dovoljan ~50mV viši napon.
      9. #50
        Member Avatar korisnika rAMA
        Na forumu od
        Feb 2007
        Poruka
        9.441
      10. Moja mašina
        • CPU: i7 6700k + NH-D15
        • MoBo: Maximus VIII Ranger
        • RAM: G.SKILL TridentZ RGB 16GB DDR4 3000MHz (F4-3000C16D-16GTZR)
        • VGA: GeForce® GTX 1080 G1 Gaming 8G
        • MON: Acer Predator XB271HU 27" G-Sync @150Hz
        • HDD: Samsung 830 128GB + SEAGATE BarraCuda 3TB ST3000DM008 + 1.5TB Samsung EcoGreen F2 + WD6400AAKS
        • OPT: ...?
        • Case: Fractal Define XL Titanium Grey
        • SND: Creative Sound Blaster Z; Altec Lansing 5100, Sennheiser HD 598, Presonus HD7
        • TV: Sony KDL-50W756C
      11. Citat Citiram korisnika: G955F Pogledaj poruku
        5.0ghz 1.39v
        4.8ghz 1.27v.
        Uglavnom na tim graničnim vrednostima za maksimalni oc je i potrebno 0.05-0.06v za svaki skok od 100Mhz.
        ▒▓██ P █ A █ R █ T █ I █ Z █ A█ N ██▓▒Mi ćemo stvarati, drugi neka ruše, mi ćemo ulepšavati, drugi neka ruže▒▓██ █ █ ██▓▒
      12. #51
        Member Avatar korisnika Villy_Da_Man
        Na forumu od
        Feb 2005
        Lokacija
        Abu Dhabi, UAE / Subotica & Kragujevac
        Poruka
        1.931
      13. Moja mašina
        • CPU: i7 7700K @5GHz + EKWB Predator 240 + R7 1700x @3.9 + Phanteks
        • MoBo: Z170 AsRock Extreme 4 + Asus 370 Pro
        • RAM: 2x8GB 2400MHz DDR4 Kingston Black + 2x16GB @ 2933MHz
        • VGA: Gigabyte GTX1060 6G OC + Nvidia Tesla K80 24GB GDDR5 CUDA
        • MON: 3x Hp 23,9" IPS FHD + Dell 24" 4K
        • HDD: M.2. 960 EVO 256GB/4TB Seagate/3x1TB 2.5/4x2TB green + m.2.SSD Samsung 850 Pro 512GB
        • OPT: Samsung SATA external
        • Case: CM V750 Full Modular + CM V1000 Full Modular
        • SND: ASUS Xonar STX Altec MX5021+Microlab SOLO 6C + Asus Xonar U7
        • OS: Win10
        • LAP: Toshiba i5 6200U, GTX930M, 16GB, 256GB SSD
        • TV: Sony 55x8507 4K, Android,
        • INET: DSL
        • Ostalo: FOrd Mondeo 2014 Titanium, Note 5, DeskJet 4530, Oppo HA2 DAC + Kef M500, Razor Mamba+Chroma, PS4 PR
      14. 1.45V 5.0GHz Linx Stabilno posle delida. Coolaboratory. Posle sat linxa, pod vodom, u dobro provetrenom kucistu na sobnoj temp od 26C, cpu temp je 75C, tj max core temp po Coretempu
        Bez delida na def vrednostima je imao isto 75C, cisto radi poredjenja....
        Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	233415   Click image for larger version.
        I'm BI-WINNING!!! Win here, win there win everywhere!
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
