»RSS Benchmark sajt
      Strana 101 od 288 PrvaPrva ... 5191979899100101102103104105111151201 ... PoslednjaPoslednja
      Prikazani rezultati od 1.501 do 1.515 od ukupno 4309
      Tema: ZCash [ZEC] (Equihash)
      1. #1501
        Member
        Na forumu od
        Jan 2014
        Poruka
        1.600
        Citat Citiram korisnika: Fallout 3 Pogledaj poruku
        Molim vas jel moze neko da mi kaze da li Zec ide sa Flypool-a na Poloniex bez problema?
        radi
      2. #1502
        Banned Avatar korisnika neogeo
        Na forumu od
        Aug 2002
        Lokacija
        КШ
        Poruka
        5.836
        Citat Citiram korisnika: MareG Pogledaj poruku
        Napravi fajl u folderu gde je majner, nazovi ga monitor_restart.ps1 i prekopiraj u njega ovo :
        Kod:
        do {
            Write-Host "Setting up process" -ForegroundColor Green
            [int]$global:count = 0
            [int]$global:countstr = 0
            [bool]$global:restart = $false
            $pinfo = New-Object System.Diagnostics.ProcessStartInfo
            $pinfo.FileName = "genoil.exe"
            $pinfo.Arguments = "-c eu1-zcash.flypool.org:3333 -u t1ZU2eMFczcCSZXrBrbDxxcELsaWNv7Ro3Q -p z -g 0 1 2 3 4 -k zec zec"
            $pinfo.UseShellExecute = $false
            $pinfo.CreateNoWindow = $false
            $pinfo.RedirectStandardOutput = $true
            $pinfo.RedirectStandardError = $false
            $process = New-Object System.Diagnostics.Process
            $process.StartInfo = $pinfo
            $OutEvent = Register-ObjectEvent -InputObject $process -EventName OutputDataReceived -Action {
        $global:countstr = 0;
                $stdout = $Event.SourceEventArgs.Data
                Write-Host $stdout
        if ($stdout.Contains(": 0.0S/s"))
                    Write-Host "--WARNING. PROCESS WILL BE RESTARTED SOON-- Count error:" $global:count -ForegroundColor Yellow
                    $global:count += 1;
                if ($stdout.Contains(": job not found"))
                    $global:count += 1;
                if($global:count -gt 5)
                    Write-Host "--KILLING PROCESS AND RESTARTING--" -ForegroundColor Red
                    $global:restart = $true
                    $global:count = 0
                    Stop-Process -processname genoil
            $process.Start()
            $process.BeginOutputReadLine()
            Write-Host "Process started" -ForegroundColor Green
            while (!$process.HasExited)
        $global:countstr += 1;
        if ($global:countstr -gt 15)
                $global:count = 0
        break;
        Start-Sleep -Seconds 1
        while($global:restart)
        $OutEvent.Name |
            ForEach-Object {Unregister-Event -SourceIdentifier $_}
        Write-Host "Process finished"
        Naravno prepravi wallet, pool i -g parametar
        Zatim isto tu napravi Start.cmd fajl i stavi u njega :
        Kod:
        setx GPU_FORCE_64BIT_PTR 0
        setx GPU_MAX_HEAP_SIZE 100
        setx GPU_USE_SYNC_OBJECTS 1
        setx GPU_MAX_ALLOC_PERCENT 100
        setx GPU_SINGLE_ALLOC_PERCENT 100
        :rr
        cd C:\ZECMiner
        PowerShell.exe .\monitor_restart.ps1
        TIMEOUT 5
        goto :rr
        Pre nego li pokreneš majning sa Start fajlom odradi sledeće:
        Klikni Start pa u Search upiši PowerShell zatim na Windows PowerShell desnim klikom Run as administrator pa u terminal koji se pojavi upiši:
        Set-ExecutionPolicy RemoteSigned
        i posle Enter
        Sad pokreni Start.cmd
        Ako imate starije kartice uklonite -k zec zec iz prvog fajla.
        VELIKO HVALA!
        Bice odradjeno.
        Sent from my 6045K using Tapatalk
      3. #1503
        Member
        Na forumu od
        Jun 2016
        Lokacija
        Kruševac
        Poruka
        2.087
      4. Moja mašina
        • CPU: Intel g3260 i Noctua NH-D14
        • MoBo: Asrock pro btc
        • RAM: Kingston 8gb
        • VGA: Palit gtx 1080 Game rock
        • MON: Samsung 26 inch
        • HDD: WD 500gb+WD 160gb+ssd samsung 860 evo 250gb
        • Case: Raidmax Monster II i Super Flower Leadex 2000w Platinium
        • SND: Genius gx sw-g2.1 1250 gaming edition
        • OS: Win 8.1
        • INET: Modemska veza
      5. Hvala na odgovoru
      6. #1504
        Member
        Na forumu od
        Nov 2014
        Lokacija
        Futog
        Poruka
        825
      7. Moja mašina
        • CPU: AMD FX8350 CM SEIDON 240M
        • MoBo: MSI 990FXA-GD80
        • RAM: 2x Kingston HyperX BEAST 8GB 2133Mhz
        • VGA: MSI R9 390 Gaming 8G
        • MON: Asus VX279H & Samsung SyncMaster 2223nw
        • HDD: Seagate Barracuda 1TB & Samsung 850 Evo 500GB
        • OPT: LG
        • Case: CM Storm STRYKER & SilverStone 600W ST60F-ES
        • SND: Genius GX GAMING 2.1
        • OS: Windows 10
        • INET: Kablovska
        • Ostalo: CAT B25 Logitech G502 Logitech G510 Logitech G330
      8. Citat Citiram korisnika: Gpumanijak Pogledaj poruku
        pa sta da pokaze u odnosu na 390x, realno 390x je u svakom smislu jaca od nje, bile to igre, bio to eth ili zec.... meni je na eth kopala msi 390x oko 36 mhs.. Msi 390x je zver, ima odlicne hladnjake... dok ne izadju rx 490, onda ih sve menjam za rx 490
        Iskreno kod nas je manje vise sve jedno koliko kartica troši jer imamo jeftinu struju naspram evrope, imam kuci r9 390 bas tu MSI zver sto pominjes u desktopu i gura stock 31-32mhs, a sredjene rx480 bez ikakvog silovanja daju 30mhs, moze da ide jos par mhs gore.
        E sad stavi na papir da moje dve rx480 trose manje struje nego jedna r9 390 u desktopu da ne poredim tek sa tvojom X verzijom. Znaci treba ti vise para za napajanje itd.
        Slazem se da su kartice zver i to dokazuje da stock 390 gure vise od sredjene 480 8gb nitro, ali uvek postoje i drugi faktori
      9. #1505
        Member
        Na forumu od
        Mar 2016
        Poruka
        138
      10. Moja mašina
        • CPU: i7-7700k + Noctua NH-D15
        • MoBo: MSI Z270 GAMING M7
        • RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15
        • VGA: ICHILL GEFORCE GTX 1080 X4
        • MON: ASUS MG279Q Black 27" IPS 144 Hz
        • HDD: SSD 850 EVO 2.5" SATA III 500GB+WD Black 3TB
        • OPT: LG BH16NS55 Blu-Ray
        • Case: NZXT H440 WHITE
        • SND: M-Audio Audiophile 192/Yamaha NS 2000 monitor
        • OS: Windows 10 PRO version 1703
      11. re:Prisic
        Slazem se ja druze sa tobom oko potrosnje struje, imam ja i 480 rigove, nego kazem da 390x nisu lose za zcash....A sto se tice struje, ne cimam se oko toga mnogo, jer koristim industrijsku struju... 2 din je nocu, 6.7 din danju, nema nikakvih zona...
        Menjao Gpumanijak : 03.11.2016. u 14:18
      12. #1506
        Member Avatar korisnika taxi011
        Na forumu od
        Sep 2007
        Lokacija
        Beograd
        Poruka
        147
        evo i kineza napravise bolju varijantu
        resetuje miner svakih 30 min ....e sad pucao on ili ne baš me briga sad radi punom parom ne kopa samo 25 sec na svakih 30 min
        evo mog foldera promenite walleti workera u start bat i startujte preko autorestart bat
        http://www.mediafire.com/file/sjeezw...avi_genoil.rar
        zaboravih da napomenem ko ima novije karte nek ubaci i dva zeca
        Menjao taxi011 : 03.11.2016. u 14:27
      13. #1507
        Member Avatar korisnika goldi
        Na forumu od
        Dec 2010
        Lokacija
        Backstage
        Poruka
        7.992
        Citat Citiram korisnika: dzonikg28 Pogledaj poruku
        Kazes pocetnici ne znaju podesiti..ja majnujem 3 godine ...imam skoro sve vrste AMD kartica od 270x,280x 390x ,rx470 ,rx480 ..imam i win 7 i win 8.1 i win 10 i gle cuda puca svuda kako god da ga podesis..a nisam bas pocetnik sa racunarima sa obzirom da sam prvi racunar dobio jos 1986 godine tj pre 30 godina..nikad mi se nije desilo da tipa majner za ETH pukne ili oni prethodni sto sam koristio za druge coine ...majner je budjav ,ne optimizovan (ove kartice 390x,470 i 480 prakticno rade bez okretanja ventilatora sto znaci da verovatno neko ima majner koji izvlaci 3 puta vise) ..a diff na ETHu je pao duplo znaci da su i mnoge velike farme presle na ZEc a to sigurno nisu sa ovim genoilom vec sigurno imaju neki bolji koji nije za public.
        To sto tebi radi dobro je cista sreca jer i meni na jednom radi bez pucanja al zato na svim ostalim i sa istim podesavanjima i istim windowsom i istim karticama puca ko lud.
        Ocito nisi jos savladao gradivo
        Ja sam podesio druze samo u protekla 24h preko 100 kartica, znaci nema tu srece nikakve samo znanje pratili su i mene problemi sa pucanjem, restartovanjem, ali sve sam sredio. najvise na pucanje utice internet konekcija i extenderi zbog pada napona.
        USB extenderi i stabilan net + skripta svaki rig radi...
      14. #1508
        Na forumu od
        Aug 2002
        Lokacija
        КШ
        Poruka
        5.836
        Samo da javnem da mi "ruska skripta" ne obavlja posao kako treba. Naime, ona se pobuni u samom startu kada se genoil.exe startuje i u tom trenutku prikaže sve hash nule... i osle nastavi da drnda.
        Značajno poboljšanje sam dobio reinstalacijom drajvera tako što sam skinuo 16.10.3 i stavio 16.9.2 i sada imam oko 165sol/s ili čega već (grafe su mi na difoltu msi rx 470 8gb) ali sam stavio 4 zec-a jer sam našao da -z zec zec opslužuje 4GB RAMa gradfe dok -z zec zec zec zec opslužuje/popunjava 8GB RAMa- ko ima grafe sa 8GB)....
        Za sada RA DIIIIII kao DOXaa li sam za svaki slučaj napičio :loop komadnu...
        evo mog .bat fajla:
        Kod:
        :loop
        genoil.exe -k zec zec zec zec -c zec.suprnova.cc:2142 -u neogeo.neogeo1 -p xnxx.com -i 20 -w 64 -P 0 -f 2 -z 0
        goto loop
        (all match except passw)
        P.S. Prešao sam sa win10x64->win7x64
        Menjao neogeo : 03.11.2016. u 15:54
      15. #1509
        Member Avatar korisnika dusko94
        Na forumu od
        Nov 2008
        Lokacija
        Apatin
        Poruka
        88
      16. Moja mašina
        • CPU: I3 2100
        • MoBo: Gigabyte Z77 D3H
        • RAM: Kingston 2x2 DDR3 1333
        • VGA: EVGA GTX460 1 GB FPB
        • MON: LG W2234S-PF
        • HDD: Hitachi HDP725050GLA360 500 GB
        • OPT: LG LightScribe
        • Case: Cooler Master Elite 332 ; Chiftec 500 W
        • OS: Windows 7 Ultimate 64 bit SP1
        • INET: DSL
      17. Imam bas cudan problem sa sapphire 7970 kartom. Naime na ETH mi daje bukvalno isto kao i 280x karte. A ovde imam problem:
        Click image for larger version.
        Neko ima/imao slicno?
      18. #1510
        Member Avatar korisnika Stormbringer_bg
        Na forumu od
        Sep 2000
        Lokacija
        Blok 30
        Poruka
        3.466
      19. Moja mašina
        • CPU: I7-3770K oc 4.50 GHz & LC-CC 120
        • MoBo: MSI Z77 MPower
        • RAM: GSkill Sniper 2x8 GB ddr3 2400 MHz, CL11, 2T, 1.65 V, DC
        • VGA: Sapphire Nitro+ SE RX580 8 GB
        • MON: 27" HP Envy 27s
        • HDD: Samsung 840 PRO 512 GB & WD Black 2 TB & WD Red 3x3 TB
        • OPT: LG DVD-RW GH24NSD1 Sata
        • Case: Cooler Master V750 W & Thermaltake Urban T31
        • SND: Integralac / Logitech X-530
        • OS: Windows 10 Pro
        • INET: Kablovska
      20. Promeni takt gpu i mem.
      21. #1511
        Na forumu od
        Nov 2008
        Lokacija
        Apatin
        Poruka
        88
      22. Moja mašina
        • CPU: I3 2100
        • MON: LG W2234S-PF
        • INET: DSL
      23. Probao sam, 1020/1000; 1000/1000 ; 1040/1000 i nikako da uspem. U gpu-z pokaze da je promenuo takt ali nema razlike..
      24. #1512
        Na forumu od
        Sep 2007
        Lokacija
        Beograd
        Poruka
        147
        Citat Citiram korisnika: neogeo Pogledaj poruku
        evo mog .bat fajla:
        Kod:
        :loop
        goto loop
        jesi li probao kinesku skriptu mozda je bolja stavio sam jednu ili dve poruke pre tebe link
      25. #1513
        Member Avatar korisnika cacanin
        Na forumu od
        Nov 2006
        Lokacija
        Cacak
        Poruka
        4.262
      26. Moja mašina
        • CPU: Intel Q6600 GO 2.4 mhz
        • MoBo: Asus maximus formula
        • RAM: Kingston 2x2GB 800mhz
        • VGA: PowerColor 7870 x2
        • MON: Samsung 223bw
        • HDD: WD 2x320GB stripe
        • OPT: 2xAsus DRW-2014L1T
        • Case: Chieftec BH-01B-B-B / CM 650w
        • SND: Supreme FXII
        • OS: Windows 7
        • LAP: HP ProBook 4310s
        • TV: LG42LH3000
        • INET: DSL
      27. Citat Citiram korisnika: f1k1 Pogledaj poruku
        Nvidia kopa sve u 16 od samog starta.
        Ovaj lik je juce imao 500 sad je na 825 da li mislis da on kopa sa genoil-om.
        Ne, kopa sa minerom koji je platio 120 BTCa.
        Послато са SM-N9005 уз помоћ Тапатока
      28. #1514
        Member Avatar korisnika toogood
        Na forumu od
        Nov 2008
        Poruka
        4.196
      29. Moja mašina
        • CPU: Intel i5 3350P
        • MoBo: Asus B75M-A
        • RAM: DDR3 8GB
        • VGA: AMD Dualx 7950
        • MON: 22'' Asus
        • HDD: 320 GB Samsung SATA
        • OPT: /
        • Case: Thermaltake
        • SND: Interna
        • OS: win7 ultimate
        • LAP: Toshiba Satellite SP10
        • TV: Sony Bravia 40" v serija
        • INET: Kablovska
        • Ostalo: PS3, IAMM NTR81 media center, Amiko Alien 8900 sattelite receiver
      30. Citat Citiram korisnika: cacanin Pogledaj poruku
        i otplatio ga za pola dana
      31. #1515
        Member
        Na forumu od
        Aug 2016
        Poruka
        1.307
        nije 120 btc nego je 1200 btc
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
