»RSS Benchmark sajt
      Strana 10 od 30 PrvaPrva ... 6789101112131420 ... PoslednjaPoslednja
      Prikazani rezultati od 136 do 150 od ukupno 436
      Tema: Microsoft's Surface Phone Vesti,glasine,zvanicno,nezvanicno...
      1. #136
        Member
        Na forumu od
        May 2006
        Lokacija
        Pančevo
        Poruka
        1.414
      2. Moja mašina
        • CPU: AMD Athlon X4@ 3.8 GHz stock cooler
        • MoBo: ASUS A68HM-K
        • RAM: 16 GB DDR3 @2400 Mhz
        • VGA: AMD Radeon RX 560 4GB
        • MON: Samsung S22350 povrzan sa HDMI konekcijom
        • HDD: SSD M.2 SATA3 240GB Kingston 550/330MB/s i HDD Toshiba DT01ACA100 1TB 3.5" , Ekserni Maxtor 500 GB
        • OPT: ASUS
        • Case: No name
        • SND: DTS
        • OS: Windows 10 Pro
        • INET: DSL
        • Ostalo: NOKIA 5 DUAL SIM Kingston DataTraveler Ultimate G3 64GB USB 3.0 Read 150MB/s, Write 70MB/s
      3. Kaby Lake is the next generation of CPUs from Intel. Right now we're in the Skylake generation. You'll still see quite a few laptops from the previous Broadwell and Haswell series on sale, but they are officially past-it.
        Here are all the details you need to know on the upcoming Intel Kaby Lake CPU revolution.
        Cut to the chase
        What is it? Intel's 7th-generation Core processor
        When is it out? Before the end of 2016
        What will it cost? Likely similar to Intel's current Skylake processors
        Intel Kaby Lake release date
        Kaby Lake is on our doorstep. Intel CEO Brian Krzanich confirmed on July 22 that Kaby Lake chipsets have made their way to PC builders.
        Three Kaby Lake CPU models have already been leaked, though a handful of laptop-grade parts were officially revealed at the IFA trade show in Berlin, Germany.
        The Core i7-7700K is the leaked desktop CPU, unlocked for overclocking as indicated by the discrete "K" moniker. This tells us the Kaby Lake naming convention will remain similar: they are "7" series CPUs, to Skylake's gen 6, Broadwell's gen 5 and so on.
        The i7-7700K is a quad-core hyper-threaded CPU, and benchmarks leaked all the way back in March suggest it's clocked at 3.6GHz with a 4.2GHz turbo boost. Of course, that may change by the time the chipset is actually used.
        The CPU was leaked in the SiSoft benchmark result database, but unfortunately the results published are actually significantly worse than those of the i7-6700K, so don't tell us anything about Kaby Lake's performance. A downgrade upgrade? Let's hope not.
        Next up is the Core i7-7500U, leaked alongside the i7-7700K. This is the sort of CPU we might end up seeing in a high-end ultrabook. It's a relatively high performance chipset, but still belongs to the "U" ultra-low voltage family.
        It has two cores, four threads, and is clocked at 2.7GHz with a 2.9GHz turbo. Some of you might turn your noses up at dual-core laptop chipsets, but they're pretty important.
        On the mobile front, the higher end Core m5 and m7 mobile chips of yesteryear will be integrated into the Y-series Core i family. These include the Core m3-7Y30, the Core i5-7Y54 and the Core i7-7Y75, which will be used in top-end laptops with fanless and convertible designs to complement the more power-hungry U-series processors.
        http://www.techradar.com/news/comput...e-date-1325782
      4. #137
        Member Avatar korisnika Enemoon
        Na forumu od
        Mar 2016
        Lokacija
        Ar
        Poruka
        1.278
      5. Moja mašina
      6. Surface Phone stiže uz skener otiska prstiju
        Malo se trenutno zna o potezima Microsoft-ovog mobilnog odeljenja, a glasine ukazuju na razne vrste promena, uključujući odbacivanje Lumia brenda i dolazak flagship Surface Phone telefona. Što se tiče novog modela, veruje se da Microsoft želi da ga opremi najnovijim hardverom, uključujući najnoviji procesor kao i nove tehnologije koje bi mu donele prednost u odnosu na konkurenciju.
        Jedna od tehnologija koju bi novi telefon mogao da usvoji je i skener otiska prstiju, a nedavni patent koji je kompanija zaštitila ukazuje na to da se na takvoj funkciji radi iza zatvorenih vrata u Microsoft-u. Microsoft je uložio dosta u biometriju i Windows Hello je živi dokaz za to, ali sa debijem Surface Phone telefona to bi sve moglo otići korak dalje.
        Iako su skeneri otiska prstiju obično ugrađeni u Home taster, kao što je to slučaj kod većine iOS i Android uređaja, Microsoft bi mogao da ga ugradi direktno na ekran. Ovo je tehnologija za koju se veruje da je i Apple zainteresovan, a ljudi upoznati sa situacijom govore da bi iPhone za sledeću godinu mogao da dođe sa potpuno novim dizajnom koji bi imao skener otiska prstiju u ekranu.
        http://www.benchmark.rs/vesti/surfac..._prstiju-67265
      7. #138
        Member Avatar korisnika Dark Magician
        Na forumu od
        Jan 2011
        Poruka
        9.726
      8. Moja mašina
        • CPU: Intel i5-4670K@4.0, CM 212 EVO
        • MoBo: Gigabyte G1.Sniper Z87
        • RAM: Kingston 8GB 1600MHz
        • VGA: ASUS STRIX Radeon R7 370
        • MON: Dell P2317H
        • HDD: Samsung 840 EVO 250GB, WD 320GB, WD 1TB
        • OPT: Pioneer 216D
        • Case: Fractal Design R4 Black Pearl (window), LC Power X Type LC7500 (500W)
        • SND: X-Fi LME49720, ATH-M30x
        • OS: Windows 10 Pro 64-bit
        • TV: LG 42LM620s
        • INET: Kablovska
        • Ostalo: Logitech G9, TP-Link 1043ND
      9. Znate šta je fenomenalna funkcija koja bi mogla jednog dana da bude ako je čitač otiska prsta na ekranu?
        Dodirneš ekran otključa se i čim dignete prste, odmah se zaključa.
        It’s all in the mastering! - Steve Hoffman
      10. #139
        Member
        Na forumu od
        May 2006
        Lokacija
        Pančevo
        Poruka
        1.414
      11. Moja mašina
        • OPT: ASUS
        • Case: No name
        • SND: DTS
        • INET: DSL
      12. Could Microsoft’s Rumored Surface Phone Kill the iPhone?
        Microsoft Corporation once ran an ad tagged “don’t fight“. The ad shows iPhone users and Samsung users fighting over who has the best smartphone – people with Windows Phones were unfazed and they simply asked iOS and Android users to “Switch, don’t fight”.
        Of course, iOS and Android users didn’t switch to Windows Mobile after that ad, but the Surface Phone might give them a compelling reason to switch now.
        Microsoft’s mobile platform currently stands at a distant third behind Apple’s iPhone and Google’s Android devices. Hence, the Surface Phone will not find it easy to corner market share for Microsoft in a market dominated by Apple’s iPhone and Google’s Android-powered smartphones. This piece explores the singular feature that could give the Microsoft Phone an edge over rivals.
        Microsoft’s Surface Phone could convince iPhone and Android users to switch
        The tech industry has been abuzz with rumors that the Surface Phone will be outfitted with support for Win32 apps. In essence, the Phone will be able to run legacy Windows program that people run on their PCs.
        If Microsoft actually fortifies the Surface Phone to run Win32 apps, you can reasonably expect iPhone and Android devices to be at a marked disadvantage. Microsoft is planning to get a foothold in the smartphone industry and the Surface Phone could thrust Windows Mobile into the limelight.
        Latest tech news suggests that the firm might unveil the much-awaited Surface Phone in March 2017. The Surface team has awed the tech industry with innovative devices such as the Surface Book and Surface Pro; hence, many people expect the Surface Phone to be a stunner.
        Interestingly, a comparison of the rumored specs of the Surface Phone and the specs of Apple’s latest iPhone 7 suggests that the Surface Phone is a game changer.
        However, superior hardware won’t necessarily give the Surface Phone an edge over iPhones and Android devices. Microsoft needs to ensure that the Surface Phone runs Win32 apps if it is serious about overtaking Apple in smartphone race.
        Here’s how Win32 might have an edge over iOS and Android
        To start with, the Surface Phone’s ability to run Win32 apps will solve the apps chicken-egg problem for Windows mobile. The Windows Mobile OS has not been able to garner market share because there aren’t enough apps for the platform.
        The number of Windows Mobile apps pales in comparison to the volume of apps available in the Android and iOS ecosystems. On the other hand, developers do not have much incentive to build apps for Windows Mobile because of the low number of users.
        Hence, the Surface Phone will have a suite of ready-made apps if it can run Win32 legacy apps. Developers won’t need to create new Win32 apps for the Surface Phone. They will only need to use Microsoft’s Desktop Bridge to port desktop apps to the Universal Windows Platform.
        Secondly, the availability of Microsoft Win32 apps on the Surface Phone will encourage Android and iOS users to buy the Surface Phone. Most Android users own a Windows PC and very few of them use the Chromebook for desktop computing.
        Hence, many people (especially Android users) will love the ability to have portable desktop programs on their smartphones. The Surface Phone might not replace the laptop (that’s the work of the Surface Pro) but users will love the rest of mind that from being able to access Win32 apps on the go using their smartphone. Source: nerdsmagazine
        http://lodtech.com/could-microsofts-...l-the-iphone/?
        E ovo bi zaista bila velika prednost nad iOS i Android platformama,ako ovo uspeju da odrade i urade dobar maketing za 2 godine imacemo tri ozbijna igraca,a ne kao sada dva i jednu kornjacu koja se vuce i pritom umire.GO Win32
        Menjao kjager : 19.09.2016. u 20:55
      13. #140
        Moderator Avatar korisnika yooyo
        Na forumu od
        Jun 2005
        Lokacija
        Beograd, London
        Poruka
        10.864
      14. Moja mašina
        • CPU: i7-4790
        • MoBo: ASUS
        • RAM: 16GB
        • VGA: NVidia GeForce 770GTX
        • MON: Dell U2716D - 27" (2560x1440)
        • HDD: Samsung Evo 840 (500GB) + 2TB HDD
        • SND: Integrisana
        • OS: Centos 7
        • LAP: Dell XPS 15
        • INET: DSL
      15. Znate koliko klincu kome su mama i tata kupili ajfon znači mogućnost pokretanja win32 aplikacija na telefonu? Nimalo. U stvari 99% korisnika ne mari za to. Onih 1% nisu vredni tolike investicije.
        pro’ gram mer (n.) - An organism that converts caffeine into code.
      16. #141
        Na forumu od
        Mar 2016
        Lokacija
        Ar
        Poruka
        1.278
      17. Moja mašina
      18. pa jeste,tu si u pravu
      19. #142
        Na forumu od
        Jan 2011
        Poruka
        9.726
      20. Moja mašina
        • MON: Dell P2317H
        • OPT: Pioneer 216D
        • TV: LG 42LM620s
        • INET: Kablovska
      21. Ali je meka za enterprise, umesto računara i telefona, uzmu jedan uređaj.
      22. #143
        Member
        Na forumu od
        May 2006
        Lokacija
        Pančevo
        Poruka
        1.414
      23. Moja mašina
        • OPT: ASUS
        • Case: No name
        • SND: DTS
        • INET: DSL
      24. Citat Citiram korisnika: yooyo Pogledaj poruku
        Potpuno si upravu,koliko sam skapirao iz raznih tvojih i tudjih postova ti si ozbiljan programer.Zar ti kao programer ne bih vole da se pojavi takav uredjaj pa nek je i 1% gde ti spadas ako sam dobro skapirao profesiju ja svakako ne.Posto sam kuvar koji obozava IT i kome je to hobi.Opet voleo bih da vidim takav telefon/Ne znam mozda sam u zabludi ali mislim da MS i cilja na tih 1% ozbiljnog poslovnog sveta pa ce se mozda vremenom to prosiriti.
      25. #144
        Na forumu od
        Jun 2005
        Lokacija
        Beograd, London
        Poruka
        10.864
      26. Moja mašina
        • CPU: i7-4790
        • MoBo: ASUS
        • RAM: 16GB
        • SND: Integrisana
        • OS: Centos 7
        • LAP: Dell XPS 15
        • INET: DSL
      27. To je slab hw za moje potrebe. Poslovnim ljudima treba da pokažu prezentaciju ili katalog, da pogledaju ugovor, odgovore na mail, itd. Stvarno, ne vidim da bilo kome treba win32 na telefonu. Čak i u continuum modu, to je i dalje slabo za ozbiljniji rad. Bilo koji ultrabook završava posao bolje od continuuma, a još je i jeftiniji.
        Menjao yooyo : 19.09.2016. u 22:07
      28. #145
        Member Avatar korisnika Miskonius
        Na forumu od
        Jul 2011
        Lokacija
        Zajecar
        Poruka
        2.044
      29. Moja mašina
        • CPU: i7 4770k@ 4.5GHz & CM Z600+ Enermax Magma Push&Pull
        • MoBo: Asus Z87 Gryphon
        • RAM: Kingston HyperX 2133Mhz 2x8Gb
        • VGA: Sapphire 290x Tri-X@ 1150GPU & 1600Vram
        • MON: Shimian QH270-IPSMS 2560x1440p 27″@ 120Hz
        • HDD: Intel SSD 520 Series 240GB, Samsung F3 SpinPoint 1TB
        • OPT: Neki Asus
        • Case: Cooler Master Haf-XB Evo
        • OS: Windows 8.1
        • INET: DSL
        • Ostalo: Keyboard Logitech G11, Mionix Naos 7000, Logitech Gamepad F510, Kingston HyperX Cloud II Headset, Lo
      30. Citat Citiram korisnika: yooyo Pogledaj poruku
        Naravno, kako da ne. Windows drži 90% desktop tržišta i ti misliš da će samo šačica njih biti zainteresovana da pokreće win32 aplikacije na mobilnom??? Pod uslovom da je ovo sve tačno naravno.
        Elem evo novina:
        http://wccftech.com/hp-elite-x3-out-of-stock-us/
        Sent from mTalk
      31. #146
        Newcomer Avatar korisnika Evindzer
        Na forumu od
        May 2015
        Poruka
        236
        Tačno, ali ovo im je najverovatnije jedini način da ostanu u igri, budući da su svi dosadašnji pokušaji bili promašaji (uprkos tome što ima nas koji volimo i koristimo WP/W10M).
        Sad je jedino pitanje mogu li u bliskoj budućnosti izvesti to - a ako i mogu, opet će morati da se strpe godinu - dve pre nego što budu mogli da se nadaju opipljivom procentu tržišta, a taj procenat bi uglavnom bio otet od Androida, što opet potkrepljuje tvoju konstataciju.
        Menjao Evindzer : 19.09.2016. u 22:12
      32. #147
        Na forumu od
        Jun 2005
        Lokacija
        Beograd, London
        Poruka
        10.864
      33. Moja mašina
        • CPU: i7-4790
        • MoBo: ASUS
        • RAM: 16GB
        • SND: Integrisana
        • OS: Centos 7
        • LAP: Dell XPS 15
        • INET: DSL
      34. Dok ne objave koliko su komada prodali, ova vest nema smisla. Možda su prodali oba, a možda milion. Obzirom da se pravi brojevi kriju, mislim da je istina bliža broju 2, nego milionu.
      35. #148
        Member
        Na forumu od
        May 2006
        Lokacija
        Pančevo
        Poruka
        1.414
      36. Moja mašina
        • OPT: ASUS
        • Case: No name
        • SND: DTS
        • INET: DSL
      37. Citat Citiram korisnika: yooyo Pogledaj poruku
        Ok,kapiram te sta pricas,ali me zanimalo generalno kao inovacija zar ti ne bi bilo "drago" da se tako nesto pojavi.Meni bi ali opet,kuvar,cim trepce i ima veze sa IT meni zanimljivo,bas me zato i zanima misljenje profesionalca.
      38. #149
        Na forumu od
        Jun 2005
        Lokacija
        Beograd, London
        Poruka
        10.864
      39. Moja mašina
        • CPU: i7-4790
        • MoBo: ASUS
        • RAM: 16GB
        • SND: Integrisana
        • OS: Centos 7
        • LAP: Dell XPS 15
        • INET: DSL
      40. Pa i ne. Prave Frankenštajnovo čudovište od telefona kome funkcije telefona ne rade kako treba, ali zato može da pokrene neki exe koji je bez tastature i miša neupotrebljiv.
      41. #150
        Na forumu od
        Jan 2011
        Poruka
        9.726
      42. Moja mašina
        • MON: Dell P2317H
        • OPT: Pioneer 216D
        • TV: LG 42LM620s
        • INET: Kablovska
      43. Ne znamo ni šta će biti tačno. Ali znamo da neće raditi funkcije telefona kad se pojavi?
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
