[VLT] Veltor ∀ : For All
Space
LINK sa bitcointalk foruma: LINK
Uvodna priča:
Due to my current studies, I am attempting to build an alternative blockchain network.
Focusing on network stability, efficiency and long term scaleability as well as documenting the setup and the execution of the whole project.
Additionally I am looking to implement something like a Lightning Network, solving the so called Lightning Network’s Failure Mode. That would also provide viable transaction confidentiality without bloating the blockchain.
This also completely eliminates the drawbacks of longer block time.
Longer block time, I argue provides greater stability and efficiency.
I have a few other ideas that could make good use of longer block time as well.
Source:
https://github.com/veltor/veltor
Algo: Thor's Riddle
(Shavite, Skein, Shabal and Streebog-512/Gost)
Block time: 30min[/center]
Windows Wallet:
https://github.com/veltor/veltor-windows
Block Explorer:
http://blocks.veltor.org
IRC chat:
http://webchat.freenode.net/?channels=veltor
Nodes:
Add the following in your Veltor.conf file:
Kod:
addnode=46.105.114.185
addnode=45.32.236.94
addnode=47.88.188.91
addnode=52.42.180.141
addnode=52.90.105.10
addnode=78.94.32.195
addnode=31.23.56.187
addnode=105.101.197.77
addnode=69.136.139.85
addnode=77.40.94.103
addnode=176.4.124.158
addnode=104.197.130.224
addnode=122.129.142.14
addnode=46.61.10.219
addnode=77.40.115.238
addnode=69.165.217.147
addnode=50.35.92.164
addnode=153.34.108.154
addnode=69.136.137.41
addnode=69.136.136.253
addnode=87.117.13.118
addnode=109.81.209.89
addnode=178.234.16.18
addnode=80.236.18.96
addnode=192.99.35.133
addnode=193.198.102.32
addnode=52.59.129.232
addnode=193.198.102.33
addnode=161.53.40.94
addnode=67.229.124.20
addnode=109.242.209.0
addnode=5.157.115.132
addnode=81.17.16.170
addnode=77.105.4.66
addnode=178.122.103.99
addnode=62.1.82.87
addnode=65.0.122.205
addnode=94.23.33.122
addnode=24.219.193.98
addnode=109.241.110.41
addnode=109.93.227.72
addnode=70.73.232.69
addnode=200.96.226.76
addnode=188.235.23.148
addnode=90.189.117.123
addnode=2.87.125.33
addnode=5.141.223.112
addnode=68.230.70.125
If you don't have one, just create one.
OR run
Kod:
addnode <node> add
In the command one by one.
Block reward:
650∀ to block 336
350∀ to block 672
100∀ to block 1344
50∀ to block 2688
25∀ to block 5376
15∀ to block 10752
10∀ to block 21504
8∀ to block 43008
4∀ to block 86016
2∀ to block 172032
1∀ to block 344064
Pools:
https://veltor.suprnova.cc
http://yiimp.ccminer.org
http://zpool.ca
https://www2.coinmine.pl/vlt/
CPU Miners:
https://github.com/ocminer/cpuminer-veltor use "-a sib"
cpuminer-opt: https://bitcointalk.org/index.php?topic=1326803.0
GPU Miner (NVIDIA):
https://github.com/ocminer/ccminer-veltor
use "-a sib"
CCminer by Tpruvot:
http://ccminer.org/preview/ccminer-rel1.8.2-veltor-x64.7z
Exchange:
https://www.cryptorex.com/trade/VLT/BTC (trade at own risk!!)
Happy mining!
J.V.
Koliko vidim, ovo ATI ne može da kopa?
I kakvi su rezultati koliko iskopa GTx 1060 ili 1070 karta za 24h?
Moze AMD samo se placa miner :)
Ne moze da se izmeri, stalno varia diff, blok je sa 350 pao na 100 itd. Recimo sa 32KH/s imas 32 koina dnevno. Ja sam nesto na brzaka iskopao 2000 i sad se prebacio na buđav lebac, nek stoji.
Evo i koliko sta kopa. (zanemari suprnova statistiku, u tom trenutku je brljavila)
Dok srede AMD Miner, reward ce biti 1. :d
Uglavnom preskacem ove coine gde prednost imaju early mineri, i naravno sve na tacni servirano pre samog launch-a. Za sat vremena sa 2 gpu-a izrudari isto sto i ja za 3 meseca i sa 50 gpu-a. :)
Može i ATI sa sgminerom, ali jako slabo daje, tipa 10 puta manje daje 380tka od GTX 970. Ovo je za sad pravi Nvidia coin.
zaboravio si xre :p
Ima miner brzi za NV a i za AMD dalekooo brzi, ja nisam nista spominjao jer ne znam jel pametno kupit isti
380 --- 6Mhs
RX480 --- 20Mhs
NV 1070 --- 12Mhs
obican SGminer na 380 daje sramotno malo 15KHs , ili ja nisam nesto dobro podesio
Inace Tahiti lose radi sa ovim algom samo 3Mhs, private miner
Jel vredi uopste rudariti nesto sto nije ethash sa tristoosamdesetkama?
Kako mislis pokreli, pa daj TX id, pokrenu topic na bitcoin forumu, reddit, postuj ovde nemoj tako da se predajes.... ima oni to da vrate ako nije greska
Ja imam 375 veltor-a tamo i njih ne zalim stoje na berzi za prodaju :)
Postuj ovde teme ako si pokrenuo na forumima da se ukljucimo
Pa sad sam ispitao, pricam sa njima. Ono sto se desilo u stvari je da je neko promjenio moj pass, pri tome mi je dosao mail da potvrdim promjenu. Niti je mail ko otvarao niti je promjena potvrdjena, sve se desilo prije sat, a citav dan sam pred kompom, samo otisao na tren. Znaci nit mi je ko uhakao mail, nit je sa ostalih berzi sta nestalo. Vidim da je neko povukao 0.17BTC na neku adresu, a ono sto je bilo na buy je ostalo. Kao nisam imao 2FA, nego samo sifru, to im je prica.
5.149.249.12
1LAdJDHwSMLFeBpEvQfG8FxZurStf4FtLe
c548fabae967043f9b5ea2fb7ed74e45a513dff5ab1b149b7846ef351584fbed
Pa ne znam, da nemas neki remote trojan na PC-u, da li ti je mail sa ukljucenim 2FA??
dosta je da udju u mail i omoguce forwarding istog
Moguce da i manjcnica nije sigurna, ako kradu logicno je da ne krenu da kradu odma dok ne skupe klijente, mada sve je moguce
Mada je kod mene i login history zeznut:
23/08/16 16:13 127.255.255.255
5.149.249.12
Opet ih javno isto pitaj na BCT-u, ta privatna prepiska nikud ne vodi.
Evo napisao sam na VLT topic-u, ajde nisam puno izgubio da lupam glavu, cisto da upozorim druge.
Jesam hvala, evo na VLT su dodali u prvi post i moje upozorenje.
Ne mora da znaci da kradu, moguce da je neko nasao neki exploit kako da zameni sifre bez verifikacije, sto nema smisla, ja sam na te shit berze uglavnom samo slao shitcoin-e pa se bas i nisam brinuo
