»RSS Benchmark sajt
      Strana 70 od 70 PrvaPrva ... 20606667686970
      Prikazani rezultati od 1.036 do 1.050 od ukupno 1050
      Tema: Ethereum Classic (ETC)
      1. #1036
        Member Avatar korisnika marko_ns
        Na forumu od
        Feb 2012
        Poruka
        3.478
      2. Moja mašina
        • CPU: Intel Core i5-760 4.0Ghz / Mega Shadow Deluxe + Be Quiet! Fan Silent Wings Pure USC 120mm
        • MoBo: Asus P7P55D-E Evo
        • RAM: Kingston HyperX DDR3 2x8GB 1600MHz / OC 1800Mhz
        • VGA: Gigabyte Windforce OC GTX1060 6GB
        • MON: Samsung SA550
        • HDD: OCZ Vertex 2 60GB / Samsung 840 EVO 250GB / Samsung F4 2TB / WD Green WD30EZRX 3TB / WD Green WD30
        • OPT: Samsung DVD-RW
        • Case: Corsair Graphite Series 600T Black
        • SND: X-fi Xtreme Music / Logitech Z-5500
        • OS: Windows 7 Ultimate 64bit SP1
        • TV: LG 55UB850V
        • INET: Kablovska
      3. Što mi se razlikuje količina u Ethermine app i kad otvorim gastracker iz app?
      4. #1037
        Member Avatar korisnika markosvaba
        Na forumu od
        Jul 2008
        Lokacija
        Beograd-Miljakovac
        Poruka
        629
      5. Moja mašina
        • CPU: Intel t5800 @2.0
        • RAM: 4gb
        • VGA: Ati 3650
        • MON: Samsung t220
        • HDD: Seagate 250GB SATA II 8mb + WD 250 SATA II 16mb
        • SND: Kinez neki od 10€, Altec vs 4121
        • OS: Xp Sp2, Win 7 32bit
        • LAP: Acer extensa 5630g..25mn
        • INET: DSL
        • Ostalo: Logitech g5+ Internet edition Pro+ Altec Lansing VS 4121
      6. Jel dobio neko calisto od airdropa? Imam nalog na classicetherwallet ali jos nista nisam dobio.
      7. #1038
        Member Avatar korisnika CaptainCrash
        Na forumu od
        Aug 2012
        Lokacija
        Ananas...na dnu mora
        Poruka
        879
      8. Moja mašina
        • CPU: Intel Core i3 2350M @ 2.30GHz Sandy Bridge 32nm
        • MoBo: Medion E6228 (SOCKET 0)
        • RAM: 8.00GB Dual-Channel DDR3 @ 669MHz (9-9-9-24)
        • VGA: Intel HD Graphics 3000
        • MON: 15,6" Generic PnP Monitor 1366x768@60Hz
        • HDD: Seagate ST950032 5AS SCSI Disk Device
        • OPT: CDDVDW SN-208BB
        • Case: MEDION
        • SND: Realtek High Definition Audio
        • OS: Windows 8.1 x64 Enterprise
        • LAP: MEDION E6228
        • TV: 32LG5000
        • INET: Kablovska
      9. Zasto uvek ETC stoji u top 5 i evo koliko se izrudari sa 6x 1070 i to danima iznad 0.5-0.6 a situacija u praksi je drugacija,mnogo drugacija...max do 0.4 !!!
        http://prntscr.com/j28sdv
      10. #1039
        Member Avatar korisnika Balaburin
        Na forumu od
        Nov 2015
        Lokacija
        Beograd
        Poruka
        200
      11. Moja mašina
        • CPU: i3 6100, CM Nepton 140xl
        • MoBo: AsRock z170 Extreme 4
        • RAM: Corsair Vengance LPX 16Gb
        • VGA: Asus Dual GTX 1060 3Gb
        • MON: Benq 24
        • HDD: SSD 250, HDD 640
        • Case: MS Black Widow, EVGA G3 750w
        • OS: Prozor desetka
        • Ostalo: Delidujem procesore na kilo, kontakt PM
      12. evo koliko meni kopa zadnjih mesec dana
        hashrate 184 +-1,2
        Click image for larger version.
        Trying Is The First Step to Failure
      13. #1040
        Na forumu od
        Aug 2012
        Lokacija
        Poruka
        879
      14. Moja mašina
        • Case: MEDION
        • LAP: MEDION E6228
        • TV: 32LG5000
        • INET: Kablovska
      15. Citat Citiram korisnika: Balaburin Pogledaj poruku
        hashrate 184 +-1,2
        Koji pool koristis?
        Imas vise rigova koje si usmerio na njega tj ETC ?
        Koje kartice imas?
        Prosek oko 11 ETC mesecno,sto mu izadje oko 0.36-37 manje vise...to je onako kako sam i ja gledao na WTM i crypto c0inz ali ovo gde sam gledao nema veze sa mozgom...stalno se osvezava i menja statstika ali jako slabo i opet stoji iznad 0.6 ETC...svasta
        Menjao CaptainCrash : 07.04.2018. u 23:03
      16. #1041
        Na forumu od
        Feb 2012
        Poruka
        3.478
      17. Moja mašina
        • TV: LG 55UB850V
        • INET: Kablovska
      18. A kapitan kes, dal si realan?
        Ima covek jedan rig sa 6 x RX580 ili 6 x 1070 po hashrateu vidis valjda.
        Kopa na ethermine vidis po izgledu poola.
        W2m je jedno besmisleno njesra da ti kazem.
        Poenta je da rig radi stabilno i zaboravi na prodaju dok ne bude neki drastican rast, ili prodaj rig.
      19. #1042
        Member
        Na forumu od
        Oct 2013
        Poruka
        42
        Imam problem sa etc isplatama na polo adresu.
        Sastoji se iz toga da isplate nestizu a sve je uredno majner je sa ok adresom adresa na polu je ok.
        Probao sam i etc.ethermine i nanopool i jedan i drugi mi isplacuju ali na adresu koja umesto mojih malih slova u adresi ima velika i po etc exploreru vidim da je etc zaglavljen tj ta adresa nepostoji
        vec je to moja adresa sa malim karakterima. Kad pratim statistiku pula i ubacim svoju adresu najnormalnije imam pregled na oba pulla.
        Koristio sam ih i ranije i isplacivali su mi etc normalno ovo je problem u zadnjih 7 dana bar kod mene.
        Ako neko ima slicno iskustvo sta da radim tiket sam poslao na etc.ethermine moram i na nano. 7.5 etc je zaglavljeno na toj adresi koja je moja samo sa velikim slovima .
        Hvala svima ako neko ima ideju sta raditi molim da me kontaktira.
      20. #1043
        Member
        Na forumu od
        Jun 2016
        Lokacija
        Kruševac
        Poruka
        2.087
      21. Moja mašina
        • CPU: Intel g3260 i Noctua NH-D14
        • MoBo: Asrock pro btc
        • RAM: Kingston 8gb
        • VGA: Palit gtx 1080 Game rock
        • MON: Samsung 26 inch
        • HDD: WD 500gb+WD 160gb+ssd samsung 860 evo 250gb
        • Case: Raidmax Monster II i Super Flower Leadex 2000w Platinium
        • SND: Genius gx sw-g2.1 1250 gaming edition
        • OS: Win 8.1
        • INET: Modemska veza
      22. Polo je bio down jutros nista ti ne preostaje nego da opet pises tiket.
      23. #1044
        Member Avatar korisnika demios
        Na forumu od
        Dec 2003
        Lokacija
        Dortjol
        Poruka
        5.036
      24. Moja mašina
        • CPU: i7 4790K @4800MHz bez IHS-a, na vodi
        • MoBo: Asus Z87I Pro
        • RAM: 2x8GB Team Group Vulcan 2400MHz CL11
        • VGA: Gigabyte GTX 980ti G1 na vodi
        • MON: Acer 29" 21:9 IPS
        • HDD: Samsung 500GB 850 EVO + 2TB Seagate
        • Case: Bitfenix Phenom + Silverstone Strider Plus 1000W
        • SND: Delta integrale
        • OS: Win 10
        • INET: Kablovska
      25. ideja je zaobilaziti polo u shirokom luku.
      26. #1045
        Member
        Na forumu od
        Oct 2013
        Poruka
        42
        Momci vi ocigledno nerazumete o cemu govorim ili necitate. Nije do pola vec do etc blokcaina ili kako vec. Adresa koju koristim je stara i vec sam isplacivan na nju u prethodim godinama. Probao sam nano i ethermine pulove i oba su isplatila etc nigde etc stoji zarobljen. Problem je sto adresa sa kojom imam pregled na pulu kad dodje do isplate umesto malih dobije velike karaktere i kao takva nije adresa pola. U majneru je normalana adresa ista sa pola kao i ista sa kojim imam pregleda na pulovima ali kad dodje do isplate pojavljuje se neka nova adresa sa par velikih slova i nedolazi do isplate. Ovo je moj problem ali moze biti i nekog drugog pa vam navodim kao primer da imate u vidu a mozda neko ima i neku ideju za resenje.
        Hvala svima
      27. #1046
        Member Avatar korisnika kzs12
        Na forumu od
        Jan 2009
        Poruka
        2.169
      28. Moja mašina
        • CPU: Intel i5 2500k cooled by hyper 212+
        • MoBo: MSI P67A-GD65 B3
        • RAM: 4GB DDR3 1600mhz Exelram Black Shark
        • VGA: Asus 660ti DirectCUII OC
        • MON: LG L222WS 22'' + DELL 2312 HM 23''
        • HDD: 360gb seagate sata II+ Sasmsung F2 1.5tb+ Intel 335 SSD 250gb
        • OPT: LG DVD/RW
        • Case: Cheafteck 600W 80P
        • INET: Kablovska
      29. Nema veze sa velikim slovima.... I meni su velika pa sve uredno stize. Verovatno je do njih trenutno problem.
      30. #1047
        Na forumu od
        Nov 2015
        Lokacija
        Beograd
        Poruka
        200
      31. Moja mašina
        • MON: Benq 24
      32. #1048
        Member
        Na forumu od
        Oct 2013
        Poruka
        570
        Ethereum Classic (ETC) Developers Deny 51% Attack, Double Spend
        Cryptocurrency, Ethereum Classic (ETC)–In a bizarre twist for the story developing around Ethereum Classic, developers for the ETC token are now making the claim that the blockchain has not experienced a 51 percent attack, in addition to denying the presence of a double spend.
        As reported earlier in the day by EWN, the Coinbase team released a revealing post on the state of Ethereum Classic, making the claim that the coin had undergone a “deep chain reorganization.”
        The twitter post expanded on the issue, saying
        “On 1/5/2019, Coinbase detected a deep chain reorganization of the Ethereum Classic blockchain that included a double spend.”
        Coinbase
        @coinbase
        On 1/5/2019, Coinbase detected a deep chain reorganization of the Ethereum Classic blockchain that included a double spend. In order to protect customer funds, we immediately paused movements of these funds on the ETC blockchain. Read more here: https://blog.coinbase.com/ethereum-c...d-33be13ce32de
        2,134
        8:53 PM - Jan 7, 2019
        Twitter Ads info and privacy
        Ethereum Classic (ETC) is currently being 51% attacked
        On 1/5/2019, Coinbase detected a deep reorg of the Ethereum Classic blockchain that included a double spend. In order to protect customer…
        blog.coinbase.com
        https://ethereumworldnews.com/ethere...velopers-2019/
      33. #1049
        Member Avatar korisnika Bojan.zex
        Na forumu od
        Dec 2009
        Lokacija
        Knjazevac
        Poruka
        4.520
      34. Moja mašina
        • CPU: Intel I5 3470
        • MoBo: SAPPHIRE P67 Pure Black Hydra
        • RAM: Crucial Balistix Sport 4Gb
        • VGA: Sapphire 7950 Dual X
        • MON: Samsung SyncMaster BX2231 LED
        • HDD: Kingstone Hyper X 120Gb + WD Caviar Black 640 Gb
        • OPT: Asus DVD-RW
        • Case: Frontier licno modovao sad bolje nema, i SilverStone ST60F 600W
        • OS: Win 7x64
        • INET: Wifi
        • Ostalo: Logitech Wawe tastatura, Razer Death Adder 1800Dpi
      35. Bitno da se nesto desava...
        izmenicu ti zivot , izgorecu ti SONY kiselinom !!!!!
      36. #1050
        Member Avatar korisnika dr1pac
        Na forumu od
        Jan 2006
        Lokacija
        Petrovaradin
        Poruka
        2.337
      37. Moja mašina
        • CPU: AMD A10 5800K @ Seidon 120M
        • MoBo: ASRock FM2A85X-ITX
        • RAM: 2x4gb Kingston HyperX
        • VGA: Asus R9 280X-DC2T-3GD5
        • MON: Samsung 225BW
        • HDD: Kingston V300 128GB SSD, Hitachi 750GB, Samsung F3 1TB
        • Case: Fractal Design Node 304 & Corsair HX620W
        • SND: Steelseries 5H V2
        • OS: 7 x64
        • TV: Lg 37LG3000
        • INET: DSL
        • Ostalo: Logitech G510, A4Tech V7 Bloody
      38. Reklama, bato...
        Samsung 63 cm + Sony 33 cm, CRT, oba ravni ekrani
        Ko hoce da ih popravlja, reciklira, nosi u vikendicu, gadja ljude sa terase, sta god.
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
