»RSS Benchmark sajt
      Strana 2 od 70 PrvaPrva 1234561252 ... PoslednjaPoslednja
      Prikazani rezultati od 16 do 30 od ukupno 1050
      Tema: Ethereum Classic (ETC)
      1. #16
        Member
        Na forumu od
        May 2012
        Lokacija
        Zajecar
        Poruka
        89
        Citat Citiram korisnika: Stormbringer_bg Pogledaj poruku
        Da li se nekom desava da masine kopaju, sve regularno, ali da pool ne detektuje shareove?
        Meni je danas kopao na http://pool.ethereumclassic.com/ i sve nule...
        Usput koji pool radi kako treba?
        Menjao Gh0st7niper : 24.07.2016. u 20:15
      2. #17
        Member
        Na forumu od
        Jan 2014
        Poruka
        271
        epool.io radi kako treba
        ovo sam nasao na reddit-u za ethereumclassic.com:
        http://pool.ethereumclassic.com/ is a pool owned by EthereumClassic project that is supposed to serve as a backup for a http://ethc.epool.io/ which is the main Classic pool. Unlike epool, automatic distributions are disabled on this pool. It mines to a secure offline wallet, from where it will make manual distributions to all miners approximately once per week. So, your ETC is safe, but if you want to receive daily payments, please use http://ethc.epool.io/ instead
      3. #18
        Member Avatar korisnika [SAJ]ber Kurajber
        Na forumu od
        Apr 2004
        Lokacija
        BGD, Zarkovo
        Poruka
        15.407
      4. Moja mašina
        • CPU: Ryzen 1700 @3.9GHz - Noctua NH-D15 SE
        • MoBo: Asrock x370 Killer SLI
        • RAM: 4x8GB G-skill Trident Z 3200MHz cl14 @3066 cl14
        • VGA: Asus Strix 1080TI OC
        • MON: 40" Samsung LE40C530
        • HDD: Samsung Evo 850 M.2 500GB, Samsung F3 1TB, Samsung F4 2TB
        • Case: Corsair 600T, Seasonic 760XP2
        • SND: Logitech G51 / Sennheiser HD 515
        • OS: Win 10 64bit
        • LAP: Asus E403N
        • TV: Samsung LE40C530, 49" Grundig VLE6621, Samsung 55NU7402
        • INET: Kablovska
        • Ostalo: G15, MX518.
      5. Znaci kopate nedelju dana za dz i nadate se da ce vam isplatiti a za to vreme oni rade ko zna sta s vasim novcicima
        Sent from my GT-I9300 using Tapatalk
        Onome kome ima svrhe objasnjavati, nema potrebe. Onome kome ima potrebe objasnjavati, nema svrhe jer su ograniceni - "Ja"
      6. #19
        Newcomer
        Na forumu od
        Jan 2016
        Poruka
        149
        pa nista cekamo vesti sutra od ovih upornih da vidimo dal ce im dati neki koin ili nece ako bude ta isplata sutra
        a mozda im zabaguje pool ili se desi neki ddos pa odloze isplatu za prekosutra
        Menjao standalone : 24.07.2016. u 23:07
      7. #20
        Newcomer
        Na forumu od
        Jul 2016
        Lokacija
        BGD
        Poruka
        148
        a uz to i nemas ideju koliko si iskopao, kakvi majstori.
      8. #21
        Banned
        Na forumu od
        Dec 2001
        Lokacija
        Novi Sad
        Poruka
        13.382
      9. Moja mašina
        • CPU: i5 4570 & Alpenfoehn Brocken cooler
        • MoBo: Asus z87-a
        • RAM: Kingston 2x 8Gb 2400Mhz
        • VGA: HD4600 + MSI 1070 + 290x
        • MON: Samsung C530 + Acer 22inc
        • HDD: Samsung evo 250Gb + Samsung 2TB
        • OPT: NEC 5240
        • Case: CM Trooper, Seasonic SS-750KM3
        • SND: integrusa
        • OS: Win 10 x64
        • INET: Kablovska
        • Ostalo: Pinnacle PCTV
      10. Pa kad vam se ne svidjaju nedovrseni pool-vi kopajte solo.... pool isplacuje OK vec pise da zbog moguceg hard fork-a i napada poolovi da bi se osigurali traze 520 konformacija to je ~3 sata, isto je bilo kad je krenuo da se kopa eth cekalo se koliko bese 1000+ confirmacija pa se kako se mreza stabilizovala smanjivalo
        mreza je inace nestabilna jer nasrcu veliki mineri, ddos napad vitalikovih zaelota, manji poolovi koji pokusavaju da profitiraju na manipulaciji berzi i trzista...
        a sto se tice slanja sa drugih menajcnica verovatno moze jer polonix iz dobijene transakcije moze da izvuce i saldo pre forka ako je postojao, to sve zavisi od menajcnice koliko leze ethri, problem je jedino taj sto menjacnica moze tajno da proda etc onih koji nisu svesni da je isti aktivan na polonix-u ali to bi se videlo na ETC exploreru
      11. #22
        Member Avatar korisnika shaolin_RS
        Na forumu od
        Jan 2006
        Poruka
        1.152
      12. Moja mašina
        • CPU: Ryzen 2400G / LC-CC-120
        • MoBo: MSI B350M MORTAR
        • RAM: 2x8GB ddr4 3000mhz Corsair VENGANCE CL15 RED LED
        • VGA: INT. VEGA 11
        • MON: HP Pavilion 32"
        • HDD: 480GB SSD Corsair LE + Samsung F3 SpinPoint 1TB 32mb
        • OPT: Asus SATA DVD-RW
        • Case: MS CUBE/CM 550W MWE BRONZE
        • SND: INT
        • OS: Windows 10
        • LAP: HP 550 NA947ea
        • TV: Panasonic 42" c2e
        • INET: Kablovska
      13. Citat Citiram korisnika: Space Pogledaj poruku
        Sta da koristim za nvidia kartice, da li se zna kako rade 1060/1070/1080?
        ubuntu sta drugo sve je to vec vidjeno na 750ti ubedljivo najmocnija kartica za mining koja je ikada izasla sto se tice perf/wat ali trebas da znas sa njom. Ovde je malo lakse nisi ogranicen sa memorijom kartica i ne moras da se bahces sa undervoltom no da bi na tim derivatima izvukao maksimum i bios moras da menjas. Modifikovanje biosa nije lako to ostavi za kasnije potrazi neki program za kontrolu ventova na linuxu slicno afterburneru jedva sam ga nasao pre toga instaliraj drajver a onda trebas da kompajliras eth miner tu sam zapeo i odustao malo mi je falilo. Imas resurse iskoristi ih potrudi se sta drugo da ti kazem.
      14. #23
        Banned
        Na forumu od
        Dec 2001
        Lokacija
        Novi Sad
        Poruka
        13.382
      15. Moja mašina
        • MoBo: Asus z87-a
        • OPT: NEC 5240
        • SND: integrusa
        • OS: Win 10 x64
        • INET: Kablovska
      16. #24
        Member
        Na forumu od
        Jan 2014
        Poruka
        271
        epool upravo isplatio sve sto je iskopano.
        4x270x i 4x380 za 15 sati kopanja 12 etc
      17. #25
        Member
        Na forumu od
        Oct 2009
        Poruka
        450
        Meni Poloniex nije dao etc nakon prebacivanja eth-a juče
      18. #26
        Member
        Na forumu od
        Jan 2014
        Poruka
        271
        mozes da dobijes etc samo za eth koji je iskopan pre forka
      19. #27
        Member
        Na forumu od
        Dec 2013
        Lokacija
        sremska mitovica
        Poruka
        941
      20. Moja mašina
        • CPU: celeron e3400
        • MoBo: msi g41m 23
        • RAM: 2 gb ddr3
        • VGA: radeon 5870 sapphire
        • OS: 64bit 7
      21. meni uredno kopa i dalje na epool,bar u majneru
        neocitava mi na pulu,nit sta stize
      22. #28
        Member Avatar korisnika B-ZiGER
        Na forumu od
        Aug 2007
        Lokacija
        U budućnosti
        Poruka
        2.350
      23. Moja mašina
        • CPU: i5 6500@4.50Ghz@Alpenföhn® Brocken
        • MoBo: GIGABYTE GA-Z170-HD3@Non K OC Bios
        • RAM: 16gb DDR3 @ 1866
        • VGA: MSi 1080 Ti Lightning !!!
        • MON: Benq 27'' 2760H & Hisense 65'' 4k
        • HDD: SSD Samsung 840 EVO120gb & 2TB & 1.5tb & Wd1tb & 4TB WD
        • Case: MASTERCASE PRO 5/1250W CHIEFTEC POWER SMART
        • SND: Integrusa & Microlab
        • OS: Win 8.1 PRO x64bit
        • TV: VOX 50'' & HISENSE 65'' 4k
        • INET: DSL
        • Ostalo: CMK750&R8A BloodY,Afterglow,Logi-K400,BB KEYONE,PS4 za bleju.
      24. Citat Citiram korisnika: zeljko Pogledaj poruku
        Ja sam se prebacio izgleda odlično za sada mnogo bolji od http://ethc.epool.io/#/
      25. #29
        Member
        Na forumu od
        Oct 2009
        Poruka
        450
        Citat Citiram korisnika: Choby Pogledaj poruku
        Iskopao sam ih sve pre forka, jedino što su sve vreme bili u pool-u, tj nisu mi bili isplaćeni. Pretpostavljam da zbog toga nisam dobio ništa
      26. #30
        Newcomer
        Na forumu od
        Jul 2016
        Lokacija
        BGD
        Poruka
        148
        da li neko zna da li je ovaj epool.io zavrsio sa isplatama za danas ili jos isplacuju? jer meni nisu isplatili a vidim da su otkljucali blokove.
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
