»RSS Benchmark sajt
      Strana 50 od 51 PrvaPrva ... 40464748495051 PoslednjaPoslednja
      Prikazani rezultati od 736 do 750 od ukupno 752
      Tema: Windows mobile 10 INSIDER buildovi
      1. #736
        Banned
        Na forumu od
        Dec 2007
        Lokacija
        Eurasia
        Poruka
        11.769
      2. Moja mašina
        • CPU: AMD FX 6300 > LC-CC-120
        • MoBo: Gigabyte 990XA-UD3
        • RAM: Kingston HyperX Fury (2 x 4GB) 1866MHz
        • VGA: MSI Radeon HD 7850
        • MON: Samsung SyncMaster 2233
        • HDD: Transcend 370s 256GB, WD10EZRZ 1TB
        • OPT: Sony Optiarc 5240S
        • Case: MS Black Widow ::: Thermaltake Toughpower XT 675W
        • SND: Creative Audigy 2 (SB0400)
        • OS: Windows 10 / Ubuntu Gnome 17.10
        • INET: DSL
        • Ostalo: Zune HD <3 + Kindle 4gen + Lumia 950 + Nokia 5
      3. 15235 fast
        LOL skoro nisam video ovoliki update, da skoro 1GB zauzima.
        https://blogs.windows.com/windowsexp...aVG1rwa3D0P.97
        Sent from Mumia 950
      4. #737
        Member
        Na forumu od
        Oct 2015
        Poruka
        218
        Toliko toga za PC, za Mobile slabo... Jos ne resavaju Edge *****i...
        Sent from mTalk
      5. #738
        Banned
        Na forumu od
        Dec 2007
        Lokacija
        Eurasia
        Poruka
        11.769
      6. Moja mašina
        • INET: DSL
      7. #739
        Banned
        Na forumu od
        Dec 2007
        Lokacija
        Eurasia
        Poruka
        11.769
      8. Moja mašina
        • INET: DSL
      9. 15240 fast
        Emoji 5.0
        Click image for larger version.
        Chinese Lunar Calendar
        General changes, improvements, and fixes for Mobile
        We fixed the issue where trying to update Windows Store apps saved to your SD card resulted in an 8007000B error. Apps installed on SD cards should update without any issue.
        We fixed an issue where there was no icon shown for Windows Update for either new notifications or on the settings page under Settings > System > Notifications & actions.
        Known issues for Mobile
        Occasionally, Narrator speaks phrases in English rather than the chosen non-English language.
        There is a problem with the HP Elite X3 with wired docks where the portrait orientation setting is lost when the external display is disconnected and reconnected. A workaround for this is to reboot the phone after tapping the “OK” button instead of disconnecting and reconnecting. This workaround must be performed every time you connect to an external display you want to use with Continuum in portrait orientation.
        When installing or updating a Windows Store app, you may see error 80070057. As a workaround, you can get the latest app by uninstalling the older version of the app from your device and reinstall latest version from Store.
        https://blogs.windows.com/windowsexp...CaRPhTSQHyj.97
      10. #740
        Banned
        Na forumu od
        Dec 2007
        Lokacija
        Eurasia
        Poruka
        11.769
      11. Moja mašina
        • INET: DSL
      12. 15240 dostupan i na slow ringu
        http://windowscentral.com/windows-10...-ring-insiders
        Sent from Lumia (Espana - Prostituta) 950
      13. #741
        Banned
        Na forumu od
        Dec 2007
        Lokacija
        Eurasia
        Poruka
        11.769
      14. Moja mašina
        • INET: DSL
      15. 15245 fast
        This build also includes all the improvements from KB4034674.
        We fixed an issue where the MTP service would sometimes crash when you disconnected your phone while a file transfer is in progress.
        We fixed a spin loop that was occasionally triggered by deleting a VPN profile.
        We fixed an issue where apps which call into the firewall (such as Microsoft Edge) have the potential of becoming deadlocked and the app hangs until you reboot your phone.
        We fixed an issue in the routing engine used by apps like Maps where the initial direction was always set to North which could result in unnecessary route segments.
        We fixed an issue where Silverlight apps that use GPS would either not start or crash.
        We fixed an issue where a non-default Messaging app (e.g. Skype) would crash with an Access Denied error when changing Download messages settings.
        We fixed an issue where the new Privacy Consent popup would block loading of apps which used the activity detection and pedometer sensors.
        We fixed an issue where turning on/off Reset Protection could cause the phone to reboot.
        https://blogs.windows.com/windowsexp...sI33r3tMULA.97
      16. #742
        Banned
        Na forumu od
        Dec 2007
        Lokacija
        Eurasia
        Poruka
        11.769
      17. Moja mašina
        • INET: DSL
      18. 15250 fast
        Two factor Authentication: We are excited to announce that we’ve introduced a two factor authentication unlock mechanism for Windows 10 Mobile. With two factor unlock, an enterprise can enforce an additional security layer to their sensitive data via an MDM policy. Once two factor unlock is enabled, a phone user will have to enter a numeric pin followed by an enterprise-defined factor to unlock the phone. An example of an enterprise-defined factor is a companion device such as an NFC tag which can be used to unlock a phone using our Companion Device Framework sample app and documentation.
        AppLocker Improvements: A number of customers have provided feedback on the warning prompts for apps that are blocked by enterprise policies. We’ve improved the UX and updated the MDM SyncML scripts associated with the policies. Application restrictions can be configured by either the ApplicationManagement CSP or AppLocker CSP.
        VPN Improvements: In the modern corporate workplace, mobility is mainstream and secure access to corporate data via VPN has become the norm. We are bringing a range of improvements and features that enhance the reliability of VPN on Windows 10 Mobile. The key updates to our VPN capability are:
        Lots of reliability improvements for VPN connectivity in Windows 10 Mobile.
        IKEv2 Sleep and Power Enhancements.
        VPN completes all pending actions before sleep and disconnects.
        Automatic reconnection on resume.
        Force tunneled improvements for UWP platform.
        Proxy improvements for UWP VPN profile.
        Enabling MMS usage when VPN is connected.
        We fixed a regression that was introduced in build 15245 where the fingerprint reader on the HP Elite X3 did not turn on the screen. You needed to turn on the screen before you could use Windows Hello.
        We fixed some issues where the Maps app navigation would start navigating a route and after performing a reroute, would present a list of possible routes instead of adjusting to the current route.
        We also improved map-matching particularly for routes using ferries.
        We fixed an issue where an app using the routing engine (e.g. Maps) would timeout on providing the route if suspended for more than 30 seconds.
        We fixed an issue where tiles on the Start screen would occasionally be blank.
        We fixed an issue where a VPN profile that was created via the VPN Management API would always be a dial-up profile.
        We fixed an issue with the MDM policy used to control Build Flighting by Mobile Enterprise.
        We fixed a couple of navigation issues when changing from highway to highway (occasionally, signposts were copied from the original highway to the destination highway) and highway to non-highway (erroneous instruction to “enter highway”).
        We fixed a rare issue where the user’s call history was shown as corrupt after an upgrade.
        https://blogs.windows.com/windowsexp...-15250-mobile/
        Drugari sta je ovo, samo ja ovde ostavljam changelogove jeste li zivi ?!
      19. #743
        Member Avatar korisnika Gimp suit
        Na forumu od
        Jan 2015
        Lokacija
        Beograd
        Poruka
        535
        Ja pratim temu
        čevabčiči, grls ar najljepše in d vrrld
      20. #744
        Member Avatar korisnika m@c|-|oR
        Na forumu od
        May 2014
        Lokacija
        Niš - Smederevo
        Poruka
        360
      21. Moja mašina
      22. I ja pratim tvoj lik i delo
        Iskreno ne čitam najpažljivije CL-ove, ali mi tvoji postovi redovno budu indikacija za traženje novog apdejta.
      23. #745
        Banned
        Na forumu od
        Dec 2007
        Lokacija
        Eurasia
        Poruka
        11.769
      24. Moja mašina
        • INET: DSL
      25. Sad mi je lakse
      26. #746
        Banned
        Na forumu od
        Dec 2007
        Lokacija
        Eurasia
        Poruka
        11.769
      27. Moja mašina
        • INET: DSL
      28. 15252 fast
        This build includes all the improvements from KB4038788.
        In preparation for the release of the Windows 10 Fall Creators Update, the product version number has been updated to 1709 just like PC.
        We fixed an issue where, on powering the screen off/on, high demand for CPU could cause several apps to crash. Background processing of photos is an example of high CPU demand. In a photo shoot session, you may have seen the Camera app crash.
        We fixed an issue with the Messaging app where conversation text was displayed incorrectly. Thanks to our Insiders that quickly highlighted this issue.
        https://blogs.windows.com/windowsexp...52-mobile/amp/
        1709 dolazi i za mobile
      29. #747
        Newcomer Avatar korisnika Hej_Joe
        Na forumu od
        Dec 2016
        Poruka
        56
      30. Moja mašina
        • CPU: Quad core Intel Core2 Quad Q6600 @2.40 GHz
        • MoBo: ASUSTeK Maximus Formula (LGA775)
        • RAM: 6GB DDR 2
        • VGA: AMD/ATI Radeon HD 6670
        • MON: ASSUS VW195D 19'' /Philips TV(7109)
        • Case: Chieftech/Chieftech550
        • OS: Linux/Windows 10
        • LAP: Toshiba Satellite C660-11Q
        • TV: Philips smart 3D/43 (7109)
        • INET: Kablovska
      31. Prebacio L550 na insider-fast, odmah glatko prosao update Outlook.
        Sent from mTalk
      32. #748
        Newcomers
        Na forumu od
        Oct 2017
        Lokacija
        Požarevac
        Poruka
        7
        На инсајдеру бржи начин сам, неће да ми скине српске тастатуре, јел има неко тај проблем? Лумиа 640
      33. #749
        Banned
        Na forumu od
        Dec 2007
        Lokacija
        Eurasia
        Poruka
        11.769
      34. Moja mašina
        • INET: DSL
      35. Click image for larger version.
        15254.1 fast+slow ovo je rtm build... uskoro i za sve u toku meseca , pojavio se skoro na build feed'u.
        Evo i link https://www.windowslatest.com/2017/1...now-available/
        Windows 10 Mobile Fall Creators Update is not a major upgrade as Microsoft is no longer developing its mobile platform. Earlier this week Microsoft’s Joe Belfiore confirmed that Windows 10 Mobile is no longer the company’s focus and it will only receive bugs. On the other hand, the future of Windows 10 Mobile Insider Program remains to be seen.
        Menjao dejan87dex : 12.10.2017. u 09:25
      36. #750
        Member
        Na forumu od
        Oct 2015
        Poruka
        218
        Iako sam ocekivao da dignu ruke od platforme, i iako najavljuju mesecima, bio sam tuzan kad su izdali saopstenje. Dve godine me savrseno sluzio, vala koristicu ga dok god mi rade aplikacije. Jedino je ****** sto ce i developeri da dignu ruke od aplikacija.
        Sent from mTalk
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
