Koliko je sve ovo u € onda?
Standard version with 3GB RAM and 32GB of storage: 2000 yuan (~$306)
High version with 3GB RAM and 64GB of storage: 2300 yuan (~$352)
Ceramic Exclusive version with 4GB RAM and 128GB of storage: 2700 yuan (~$413)
Verovatno ne.. Previse je to rano da se tako lako uzme u njihovim radnjama. Za 2,3 meseca mozda.Hoće li moći ovo čudo da se kupi u Pekingu u radnji ili samo online od 01. Marta? Drugarica mi dolazi 5og pa ne znam da li će biti telefona do tada...
There are some differences in the build materials, though — the first two are elegant sandwiches of metal and Gorilla Glass 4.0, while the Exclusive version employs ceramics and glass.
As far as pricing is concerned, here's what the Xiaomi Mi 5 will cost you (if you find a way to get one). The Standard version costs 1999 yuan (~$306), the High one will set you back 2,299 yuan (~$352), while the top-end Exclusive one will set you back 2699 yuan (~$413). Of course, these are the prices for mainland China, so you will most probably have to shell out a little bit more if you want to get one.
Još softver da srede i mogu da ih uzmem u obzir. Ako kameru ne odrade dobro, džabe sve, svako će pre uzeti polovan/nov G4 sa odličnom kamerom (mislim na ljude kojima ja kamera bitna stavka).
Xiaomi has announced that the high-end version of the Mi 5, with 128GB storage, Snapdragon 820, and 4GB of RAM, with cost RMB 2,699 in China. That comes out to an astounding $354 ($410 including 17 percent local taxes), about half the retail price of this year's flagships from other vendors.
The price of the 64GB is RMB 2299 ($350 (again including taxes)), and the base 32GB variant with 3GB of RAM will cost just RMB 1999 ($300). The 32GB model also has a lower-clocked 1.8GHz Snapdragon 820, with the 64GB and 128GB variants offering a 2.15GHz SoC.
