-Both the Galaxy S7 and Galaxy S7 edge will offer microSD slots (compatible with cards up to 200GB) and possess IP67 dust- and water-resistance certifications, this person said.
-Further details about the two devices, tipped to feature largely the same design as the S6 generation, were also revealed to VentureBeat. Whereas last year’s pair of flagships had the same 5.1-inch display size, this year only the flat S7 variant will retain that screen diagonal. The S7 edge was said to offer a larger, curved display measuring 5.5 inches.
Resolution will supposedly remain the same across both Super AMOLED screens, at 1440 x 2560 quad HD. One alleged difference this year is the inclusion of always-on display (AOD) functionality, enabling a glanceable screen (with the ability to show downloaded content), which is said to consume about one percent of the battery per hour.
-Speaking of batteries, the packs are set to address at least one criticism with 2015’s power implementation. While neither handset will bring back the ability for end users to replace batteries, both models are receiving a capacity bump: to 3000mAh and 3600mAh for the S7 and S7 edge, respectively (up from 2550mAh and 2600mAh).
Wireless charging time was revealed to be 2 hours for S7 and 2.2 hours for S7 edge.
-Finally, in a move that’s bound to cause some marketing headaches, the main camera sensor is supposedly “just” 12 megapixels, down from the 16 megapixels found in the S6 generation. But resolution is not everything, of course, and the module — coupled with an f/1.7 lens aperture (compared to f/1.9 on S6) — was tipped as being especially capable in low light situations.
Another upside, from some points of view, is that the rear camera lens should now be flush with the backside of the device, eliminating the sometimes-maligned “S6 hump.” The front-facing selfie cam was said to remain unchanged, at least concerning its five-megapixel resolution.
