»RSS Benchmark sajt
      Strana 1 od 6 12345 ... PoslednjaPoslednja
      Prikazani rezultati od 1 do 15 od ukupno 85
      Tema: Termalne paste za CPU, šta praksa pokazuje
      1. #1
        Member
        Na forumu od
        Mar 2008
        Lokacija
        Beograd
        Poruka
        122
      2. Moja mašina
        • CPU: Intel i7 4790K 5.0Ghz, CM Nepton 240M
        • MoBo: Asus Z97-A
        • RAM: 2 x 8GB DDR3 HyperX Savage 2400Mhz
        • VGA: Zotac AMP! Edition GTX 770
        • MON: Samsung 24 HDTV
        • HDD: SSD 256GB Samsung 850 EVO + WD HDD 3TB
        • OPT: Samsung DWR 224BD
        • Case: Cooler Master 690 III, EVGA SuperNova G2 750W
        • SND: Crystal Sound, Mercurry 2.1
        • OS: Win 8.1
        • LAP: Asus N55SF
        • TV: Samsung 40, 32, 28, 24 incha i LG 39 incha
        • INET: Kablovska
        • Ostalo: Netgear R6250 AC1600 Wifi Router USB 3.0, Dreambox HD800se
      3. Termalne paste za CPU, šta praksa pokazuje
        Thermal paste is a very important compound; it improves the conduction of heat from the CPU to the heat sink, so that none of the heat generated by the computer remains trapped within it. Thermal paste that’s dry or otherwise insufficient won’t adequately conduct thermal energy, meaning that the CPU’s temperature will be higher than it should. In general, thermal paste is very cheap and is available at a broad range of prices and quality. Here, we’ll talk about the best brands of thermal paste on the market. This document will be updated each time a new type of thermal paste comes on the market.
        Types of thermal paste
        With ceramic components: This type of thermal paste is usually made of quartz sand (silicon oxide) and/or zinc oxide in additional to other components and is usually white. One example of this kind of paste is the Arctic Silver Ceramique 2, which is made mainly of quartz sand.
        With metallic components: These are made of aluminum and/or silver, yield better results than ceramic pastes, are more expensive, and usually are silver or dark grey. An example is the famous Arctic Silver 5, which is made almost exclusively of silver, aluminum oxide, zinc oxide, and ceramic particles.
        Diamond: Made of diamond dust and/or carbon fiber, these are usually more expensive and effective than the kinds we already discussed. An example of this kind of paste is the Artic Cooling MX-4, which is made of carbon particles and other components. Another example is the IC diamond 7, which is made generally of diamond dust. Both of these achieve a 2- to 3-degree difference compared to the Arctic Silver 5.
        Liquid metal: Thermal pastes made with liquid metal are usually more expensive and effective than those previously mentioned. They’re made almost entirely of gallium and (an important note) can’t be used on aluminum; if you put liquid metal on an aluminum heat sink, next day there won’t be a heat sink. It’s also important to remember that liquid metals also conduct electricity, so one mistake and we may end up ruining our computer. These kinds of thermal paste are very good, but they’re for a very specialized consumer–usually overclockers or enthusiasts seeking the best performance possible.
        Classification, from worst to best.
        Basic thermal pastes (Office, navigation, PCs family)Cooler Master IC Value V1Artic Silver Ceramique 2
        Medium thermal pastes (Gaming, professional, good margin for overclocking)
        Artic Cooling MX-4Noctua NT-H1
        Advanced Thermal Pasta (Extreme Overclock; not recommended for normal use)
        Gelid GC ExtremeAntec Formula 7IC Diamond 7Coollaboratory Liquid Ultra
      4. #2
        Member Avatar korisnika CountMike
        Na forumu od
        Jul 2012
        Lokacija
        Beograd. Toronto
        Poruka
        5.550
      5. Moja mašina
        • CPU: Ryzen R7 2700X, CM Nepton 140XL
        • MoBo: Asus PRIME X470 PRO
        • RAM: 2x8GB Kingston Predator 3600MHz
        • VGA: Ga Rx 460 OC 2GB.
        • MON: BenQ 28" + 2x Samsung 2494
        • HDD: Samsung 960Evo, 250GB, SP V70 240GB, WD Blue 2TB,WD Blue 1TB
        • OPT: DVD
        • Case: Chieftek Dragon (customized)
        • SND: On Board
        • OS: Win 10 Pro, W7 Ult., Linux Mint
      6. U svakoj kategorii je takođe vrlo važna finoća emulzije, što finije čestice to je veća površina prijananja.
      7. #3
        Member
        Na forumu od
        Mar 2008
        Lokacija
        Beograd
        Poruka
        122
      8. Moja mašina
        • MoBo: Asus Z97-A
        • OS: Win 8.1
        • LAP: Asus N55SF
        • INET: Kablovska
      9. Jos jedan koristan link gde ima opisi i rezultati 39 pasta
        http://www.tomshardware.com/reviews/...k,3616-17.html
      10. #4
        Member
        Na forumu od
        Oct 2007
        Lokacija
        Beograd
        Poruka
        5.149
      11. Moja mašina
        • CPU: AMD Athlon 64 X2 Dual Core 6400+ + LC-CC-120
        • MoBo: Asus M2N-SLI
        • RAM: Kingston 2x2GB DDR2 800MHz
        • VGA: MSI GTX 1060 GAMING X 6G
        • MON: Samsung SyncMaster 940BW (1440x900)
        • HDD: Samsung 850 EVO 250GB + 2xWD RED 3TB
        • OPT: NEC DVD/RW ND-4571A
        • Case: Chieftec BG-01B + Thermaltake Smart SE 730W (SPS-730M)
        • SND: Audio Adapter C-Media CMI8738/C3DX Audio Device / Genius SW 5.1 3.600W
        • OS: Windows 7 Ultimate (64-bit)
        • TV: Sony 55X8509C
        • INET: Kablovska
        • Ostalo: A4tech Bloody V7, Redragon Devarajas
      12. Koja pasta je najbolja koja se može trenutno naći kod nas?
        Treba mi za vremešni procesor iz "Moja mašina".
        I koliko dugo neiskorišćena pasta može da stoji?
      13. #5
        Member Avatar korisnika Kasa5033
        Na forumu od
        Aug 2013
        Lokacija
        Prijepolje-Beograd
        Poruka
        2.907
      14. Moja mašina
        • CPU: Intel i7-8700K Delid ( OC pending)
        • MoBo: ASUS Maximus X Hero
        • RAM: Corsair Vengence LPX 2x8GB 3000MHz CL 15
        • VGA: MSI GTX 1080 Gaming X ( ASUS HD 7970 DC II TOP rezerva )
        • MON: Dell P2414H
        • HDD: Samsun 840 EVO 1TB + 2x WD Blue 1 TB 7200 Rpm 64 MB Cashe
        • Case: Thermaltake Core V51/ Cooler Master V700 700W 80+ Gold
        • SND: Supreme FX, Hyper X Cloud I, Logitech Z333
        • OS: Win 10 Pro 64 bit
        • LAP: Trazi se novi ...
        • TV: Neki LG 32"
        • INET: Kablovska
        • Ostalo: Phobya G Charger 360mm V2, Alphacool VP655T+HF Top, Phobya Balancer 250 Black, Magicool 240mm G2 Sli
      15. MX-4 ili Noctua NT-H1 ce da rade psosao i vise nego dobro
        Sapphire R9 290 Tri-X 1250/1620 +200mV +50% power (3DMark Firestrike graphics score 14,421) [ MSI 9600GT 512MB GDDR3 650/756 ]
      16. #6
        Banned
        Na forumu od
        Jul 2014
        Poruka
        2.409
      17. Moja mašina
        • CPU: Neispitano
        • MoBo: Neispitano
        • RAM: Neispitano
        • VGA: Neispitano
        • MON: Sta ce mi
        • HDD: Losi Sektori
        • OPT: Samo Plextor
        • OS: Sta
      18. Da odgovorim na drugo pitanje.
        Mx-4 mi stoji neotvorena oko 6 meseci,mislim da ne gubi svojstvo.
        Noctua NT-H1 mi je otvorena vise od jedne godine.Kad je nanesem na proc deluje kao i prvog dana.Medjutim,kad je kuler stisne i izvrti samo jedno dizanje sistema od nule raspada se kad skinem kuler.Temp. su ok,ali hebem li ga,valjda je izgubila svojstvo.
      19. #7
        Na forumu od
        Aug 2013
        Lokacija
        Prijepolje-Beograd
        Poruka
        2.907
      20. Moja mašina
        • MON: Dell P2414H
        • TV: Neki LG 32"
        • INET: Kablovska
      21. Kod mene je Noctua stoji otvorena, pa dve i po godine i dobra je kao i prvog dana. Stajala je uvek u fioci na tamnom i hladnom mestu. Stavljao sam je skoro kada sam radio remont loop-a i i nema nikakve razlike, kao i prvog dana.
      22. #8
        Member Avatar korisnika umart
        Na forumu od
        Nov 2013
        Lokacija
        Beograd
        Poruka
        6.079
      23. Moja mašina
        • CPU: i7 4770,CM Seidon 120v
        • MoBo: AsRock z97x Killer
        • RAM: PNY 1600 cl7, 8gb
        • VGA: Powercolor 290 PCS+
        • MON: Quanmax q24
        • HDD: Crucial m500 240gb,buljuk raznih diskova po rekovima
        • OPT: LG DVDRW
        • Case: Anidees AI-6 windowed, Raidmax 850AE
        • SND: Line6 UX2 usb,Focusrite Saffire PRO24 firewire,M Audio BX5D2,Akg K240Mk.II
        • OS: Windows 10
        • INET: Kablovska
        • Ostalo: EVGA Torq x5
      24. kako je izgubila svojstvo,kad su temperature okej?sta treba da radi?
      25. #9
        Banned
        Na forumu od
        Jul 2014
        Poruka
        2.409
      26. Moja mašina
        • CPU: Neispitano
        • MoBo: Neispitano
        • RAM: Neispitano
        • VGA: Neispitano
        • MON: Sta ce mi
        • HDD: Losi Sektori
        • OPT: Samo Plextor
        • OS: Sta
      27. Mozda je kineska Noctua u spricu
      28. #10
        Member Avatar korisnika Bobi4ever
        Na forumu od
        Aug 2011
        Lokacija
        Beli grad
        Poruka
        991
      29. Moja mašina
        • CPU: Phenom II X6 1605T @ 3.7Ghz NH-D14
        • MoBo: Asus M4A88T-V EVO
        • RAM: Kingston HyperX 2x2GB DDR3 1600Mhz
        • VGA: ASUS HD7870-DC2-2GD5-V2 @1150/5200MHz
        • MON: Samsung LE32D550
        • HDD: WD Caviar blue 320GB 7k 16MB
        • OPT: Ko to jos koristi?
        • Case: NZXT Hades Inferno modded, TT Smart M850W
        • SND: Altec Lansing 621, Medusa NX
        • OS: BIOS :P
        • INET: Kablovska
        • Ostalo: A4Tech x7 , Roccat Sense, SpeedLink DarkSky, Logitech C270 iPod 3 8GB.
      30. Citat Citiram korisnika: umart Pogledaj poruku
        Da kuva kafu.
      31. #11
        Member Avatar korisnika Stormbringer_NS
        Na forumu od
        Mar 2008
        Lokacija
        Novi Sad
        Poruka
        430
      32. Moja mašina
        • CPU: Intel i5 4690k @ 4.5 ghz, Megahalems
        • MoBo: ASUS Z97 Pro Gamer
        • RAM: 16 GB Kingston HyperX Savage 1600 @2133 mhz
        • VGA: Gigabyte GTX 950 Xtreme Gaming
        • MON: LG 24"
        • HDD: SSD Patriot Blast 240GB, WD 6400 AAKS + WD 5000 AAKS, WD RED 1 TB & WD Green 1TB
        • OPT: Sony Optiarc DVD-RW
        • Case: Antec P180B, 4x noctua NFS12, Corsair HX620
        • SND: Supreme FX II, Altec Lansing AVS300 2.1
        • INET: Kablovska
        • Ostalo: Noctua case Cooling (Silent system)
      33. Nikada nisam imao problem sa pastama da izgube svojstva ako su bile dobro zatvorene u špricu. Imam AS5 i OCZ freeze i obe imaju ista svojsta kao kad sam ih kupio pre par godina. Koliko ja znam pasta gubi svojstva tek kad se osuši - posle nekog vremena u kontaktu sa vazduhom, pa tada postane toplotni izolator a ne provodnik
      34. #12
        Member Avatar korisnika Pega
        Na forumu od
        Apr 2006
        Lokacija
        Beograd, Lion
        Poruka
        1.514
      35. Moja mašina
        • CPU: X5650@4.7GHz (1.35V) on H2O
        • MoBo: Rampage III Extreme
        • RAM: Corsair 24GB@2000MHz
        • VGA: 2 x MSi GTX 480 Hydrogen@800/2000
        • MON: Viewsonic VX2260wm
        • HDD: Ima gi raznih
        • OPT: LaCie eksterni DVD-RW
        • Case: Primochill Wet Bench + Corsair HX850
        • SND: ESI Maya44, Marantz PM6005, KEF Q300, Cambridge Audio Sonata CD30, Akai AP-100C & Sansui SR-222mk2
        • OS: Win 10 Pro x64
        • LAP: HP EliteBook 820 G3 FHD IPS
        • TV: neki JVC (šatro)
        • INET: DSL
        • Ostalo: Sony NEX 3N :: Olympus OM-4Ti
      36. ^Vidiš da ekipa pominje paste iz druge klase. Ne mož` Noctua da pridismra AS-u i OCZ-u..
      37. #13
        Na forumu od
        Mar 2008
        Lokacija
        Novi Sad
        Poruka
        430
      38. Moja mašina
        • MON: LG 24"
        • INET: Kablovska
      39. Citat Citiram korisnika: Pega Pogledaj poruku
        Haha, jeste - to je skoro kao da porediš pastu za zube i ozbiljne termalne paste Vidi se ko je old school ovde na forumu lol
        Menjao Stormbringer_NS : 08.04.2016. u 21:40
      40. #14
        Na forumu od
        Apr 2006
        Lokacija
        Beograd, Lion
        Poruka
        1.514
      41. Moja mašina
        • INET: DSL
      42. Citat Citiram korisnika: Stormbringer_NS Pogledaj poruku
        Haha, jeste - to je kao da porediš pastu za zube i ozbiljne termalne paste Vidi se ko je old school ovde na forumu lol
        Bravo, majstore! Pasta za zube, hehehee
        Sent from my SM-N9002 using Tapatalk
      43. #15
        Banned
        Na forumu od
        Jun 2013
        Poruka
        746
      44. Moja mašina
        • CPU: FX 6100 Zambezi 4,2 Ghz
        • MoBo: Asus M5A78L-M LX V2 bios 1701
        • RAM: Patriot Signiture 2x4Gb 1600Mhz
        • VGA: SAPPHIRE R9 270X DualX2GB-OC
        • HDD: Samsung SpinPoint F3 500Gb+ 1Tb F3 Samsung
        • Case: BLUEBERRY CN-872BK-OP,PSU CoolerMaster GX Lite 600W
        • OS: Windows 10 pro
      45. nemanja123, Za Athlon 6400 predlazu Noctua pastu, kao kada bi Ficu (Zastavu 750) vozili na raketno gorivo, ocigledno da ima puno p..S.....nj. , ko bi normalan i pismen kupio pastu koja je skuplja od procesora ??? Razumem ja i godine i pubertet ali..., kupi neku chinez pastu ( predlog gd 900 MkI dodje oko 1 Eur !g i to je preskupo za taj CPU )
        Uzgred imao sam svasta od pasti ali best for buck su kinezi i to bas ta gd900 Thermal Conductivity: >4.8 w/m-k ( 6 w)
        Menjao dovlagenja : 08.04.2016. u 23:11
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
