»RSS Benchmark sajt
      Strana 8 od 17 PrvaPrva ... 456789101112 ... PoslednjaPoslednja
      Prikazani rezultati od 106 do 120 od ukupno 252
      Tema: Mali vodič vodenih hladjenja (CLC)
      1. #106
        Banned
        Na forumu od
        Nov 2007
        Poruka
        2.218
      2. Moja mašina
        • CPU: i7-8086K | EK-Supremacy EVO
        • MoBo: Asus ROG Strix Z370-E
        • RAM: G.SKILL Trident Z 4000 16GB
        • VGA: GTX 1070 FE | EK-FC1070GTX
        • MON: AOC Q3279VWF
        • HDD: Samsung 970 EVO M.2 500GB
        • Case: Fractal Design Define R6 TG
      3. Ti SP120L ventovi su i onako krš, stavi druge ili vrati kuler.
      4. #107
        OC Guru Avatar korisnika PCBeast
        Na forumu od
        Nov 2006
        Lokacija
        Skyrim
        Poruka
        6.947
      5. Moja mašina
        • CPU: Intel 8700K@5.2 Ghz/ Swiftech XT/MCP655,Danger Dan Triple Xtreme x2
        • MoBo: Asus Maximus X Hero
        • RAM: G.Skill 3866 Mhz
        • VGA: GeForce® RTX 2080 SUPER™ GAMING OC
        • MON: Dell S3220DGF
        • HDD: Samsung 850 Evo 512/Western Digital VelociRaptor/Hitachi 2TB/Samsung 1TBx2/Samsung 850 Pro
        • OPT: Liteon
        • Case: CM COSMOS II 25th Anniversary Edition/CM Stacker 832 Black Edition/Enermax Revolution 1050w
        • SND: Creative Titanium HD
        • OS: Windows 10 Pro/Windows 7 Ultimate 64 bit
        • LAP: Apple MacBook Pro, Apple Ipad Air 2
        • TV: Samsung UE40D5000
        • INET: Kablovska
        • Ostalo: Logitech MX Revolution/G9/Logitech QuickCam 4000 Pro ,Logitech RumblePad 2 Double Vibration
      6. Ja sam mislio da ce to malo duze da potraje
        Koje druge? Prvo cu ipak da podmazem pa da vidim kako se onda ponasa.
      7. #108
        Member Avatar korisnika Xepoj87
        Na forumu od
        Dec 2009
        Lokacija
        Beograd
        Poruka
        1.189
      8. Moja mašina
        • CPU: i7 6700K @4.6Ghz, Noctua NH-D15
        • MoBo: Gigabyte z270x Gaming K5
        • RAM: 16GB 3000Mhz Kingston HyperX Predator
        • VGA: MSI RTX 2080 SUPER Gaming X Trio
        • MON: LG 55B8PLA
        • HDD: 250GB 960 EVO m.2 + 256GB 850 PRO + 500GB 860 EVO m.2 + WD Gold 2TB + WD Black 750GB
        • Case: Cooler Master COSMOS 1000
        • SND: Creative SB Z / Logitech Z-5500 / B&O H9i
        • OS: Windows 10 Professional
        • TV: LG 55B8PLA
        • INET: Kablovska
        • Ostalo: Mis: Logitech G900 Podloga: Razer Vespula Tastatura: Logitech K800
      9. Citat Citiram korisnika: KOLOS Pogledaj poruku
        Hvala na preporuci, ali do 150e me samo zanima da najbolje hladi, nije mi bitno da li je mozda precenjen.
        Jeus li ti bolji od h115i?
        Rekose drugi da se ne uzimaju clc, jel to znaci da kratko traju, da treba praviti custom? Ili je to malo preuvelicano?
        Imam 4 Noctua kulera i jos toliko CM silent, najmanji je problem zameniti kulere, ako je preglasno.
        Sent from my SM-G935F
      10. #109
        Banned
        Na forumu od
        Nov 2007
        Poruka
        2.218
      11. Moja mašina
        • MON: AOC Q3279VWF
      12. @PCBeast
        Ove: http://www.merlinhardver.hu/webaruha...50039-ww/62656
        @Xepoj87
        Bolji je H115i od ova dva, ali ne duplo bolji koliko je skuplji.
        Niko nije rekao da se ne uzimaju, rade ono čemu su i namenjeni i to odlično, samo su malo precenjeni.
        Rok trajanja je lutrija, mogu i godinama da služe. Bitno je samo da ne procure, ali to je stvarno baš retko da bi brinuo zbog toga.
        Kada vrisne pumpa, možeš da ga baciš. Ventilatore je bar lako promeniti.
        Jesi li siguran da možeš da smestiš 280mm radijator u kućište? Dimenzije su 140mm x 312mm x 26mm bez ventilatora.
        Sa ventilatorima je potreban slobodan prostor da smestiš kvadar 32cm x 14cm x 5cm.
        Menjao KOLOS : 30.12.2016. u 18:28
      13. #110
        Member Avatar korisnika Erik011
        Na forumu od
        Aug 2012
        Lokacija
        Beograd
        Poruka
        3.122
      14. Moja mašina
        • CPU: Ryzen 3900X | EK-Magnitude blok
        • MoBo: Aorus X570-I Pro WiFi
        • RAM: 2x16GB 4000MHz CL19
        • VGA: GTX 1080Ti Aorus | EKWB vodeni blok
        • MON: LG 27GL850-B i Dell P2414H
        • HDD: Samsung EVO 970 500gb | Crucial P1 1TB | WD Red 4TB x2
        • OPT: Samo naocare, drugu optiku ne posedujem.
        • Case: Phanteks Entho Shift | Corsair SFX 600W platinum
        • SND: Integrusa ftw.
        • OS: win 10 Pro
        • LAP: ASUS Zenbook 14"
        • INET: Kablovska
        • Ostalo: Mnogo radijatora, pumpi i vode.
      15. Nemoj ML-ove jos uvek. Iako su sjajni po perf/noise odnosu ogromni su problemi sa QC. Svaki treci izgleda radi kako treba
        Heroj sve sto se tice CLC-ova sam objasnio u prvim postovima, tako da ako te zanima uzmi procitaj sve ti je tu, prednosti i mane.
        @PCBeast
        Pazi da ne useres garanciju podmazivanjem. Corsair i kvalitet nemaju veze, corsair ne proizvodi nista od toga. Samo lepe nalepnice. Zapravo ML-ovi su prvi ventovi koje su oni projektovali, napokon zaposlili inzinjera.
        Voli dugačke šetnje po plaži, tunjevinu i custom vodena hlađenja.
      16. #111
        Banned
        Na forumu od
        Nov 2007
        Poruka
        2.218
      17. Moja mašina
        • MON: AOC Q3279VWF
      18. Citat Citiram korisnika: Erik011 Pogledaj poruku
        To nisam znao. Šteta, a odlični ventilatori. Samo što su ML LED preskupi, ali zato ovi basic nisu.
      19. #112
        Na forumu od
        Nov 2006
        Lokacija
        Skyrim
        Poruka
        6.947
      20. Moja mašina
        • OPT: Liteon
        • INET: Kablovska
      21. @KOLOS
        Brate da dajem 30 evra za jedan vent ne bih a gde je jedan tu su dva a to fakticki dodje na cenu pola od citavog sistema.
        @Erik011
        Nismo ni pominjali ko je OEM, valjda su bar oni napredniji korisnici upuceni ko je pravi proizvodjac a ko samo brendira ili lepi nalepnice kako ti kazes.
        Poenta je da sam ja ocekivao da ce to da odradi duze vreme bez greske a ne za ovako kratko da se pokvari i da sada urla.
        P.S. Videcu kako se skida vent, da li imaju one biksne. Kod CM-a samo iscupas i vratis, nista specijalno.
      22. #113
        Banned
        Na forumu od
        Nov 2007
        Poruka
        2.218
      23. Moja mašina
        • MON: AOC Q3279VWF
      24. Ma ne, ono je Twin Pack 30e.
      25. #114
        Na forumu od
        Aug 2012
        Lokacija
        Beograd
        Poruka
        3.122
      26. Moja mašina
        • OS: win 10 Pro
        • INET: Kablovska
      27. Sleeve lezaj, sta da ti kazem.
        I kad radi, ne radi ni za k..
        @Kolos
        Ja cekam lude ruse da mi posalju 3 sample-a vec pola godine. Znaci na kraju cu ih kupim da testiram... I basic su bre skupi, za 15e ide eloop.
      28. #115
        Banned
        Na forumu od
        Nov 2007
        Poruka
        2.218
      29. Moja mašina
        • MON: AOC Q3279VWF
      30. Pa toliko su i Vardar, to je cena danas, bez 15e po komadu ne može da se kupi ništa kvalitetno.
      31. #116
        Na forumu od
        Aug 2012
        Lokacija
        Beograd
        Poruka
        3.122
      32. Moja mašina
        • OS: win 10 Pro
        • INET: Kablovska
      33. 15e je ok. Ali ovi su 30e
        Edit: slep sam vidim da su 30e double pack sada. S tim da idu valjda bez gumiranih coskova i u sivoj boji :-/
      34. #117
        Banned
        Na forumu od
        Nov 2007
        Poruka
        2.218
      35. Moja mašina
        • MON: AOC Q3279VWF
      36. Da, performanse su iste. ML PRO LED je stvarno preskup, preko 25e komad...a dva obična 30e.
      37. #118
        Na forumu od
        Aug 2012
        Lokacija
        Beograd
        Poruka
        3.122
      38. Moja mašina
        • OS: win 10 Pro
        • INET: Kablovska
      39. ML PRO je generalno preko 25e, nevezano za to dal je LED. Mnogo je lepsi sa crnim rotorom i coskovima gumiranim.
      40. #119
        Member Avatar korisnika Nekron
        Na forumu od
        Feb 2006
        Lokacija
        N. Beograd
        Poruka
        472
      41. Moja mašina
        • CPU: Ryzen 5 3600 NZXT x62
        • MoBo: MSI Tomahawk Max b450
        • RAM: Corsair Vengeance Pro RGB 16GB
        • VGA: Asus GTX 1070 O8G Strix
        • MON: DELL U2311H rev A02
        • HDD: SandDisk 240gb ssd Samsung 250 860 Evo
        • OPT: LG
        • Case: InWin 509, Cooler Master Pro 850W
        • SND: SoundBlaster Z
        • OS: Windows 10 x64
        • LAP: IBM T43
        • TV: Panasonic
        • INET: Bez interneta
      42. Koliko su realno bolje performanse vodenog aio hladjenja ako je blok 240 vs 12 (svi ostali elementi isti, pumpa, vent)
      43. #120
        Member Avatar korisnika sinisatodorovic
        Na forumu od
        May 2012
        Lokacija
        Šabac
        Poruka
        461
      44. Moja mašina
        • CPU: i7 860
        • MoBo: H55N USB3
        • RAM: 2X4 DDR3 1866
        • VGA: 7870 2GB
        • MON: MX239H
        • HDD: 840 evo 512gb
        • OPT: DVDRW
        • Case: Nzxt Manta
        • OS: win7
        • INET: Kablovska
      45. Imas gore sve sazvakano treba samo progutati!Ako je bas tesko, evo jos jednom radijator je taj koji svu sakupljenu toplotu u vodi treba da oslobodi, pa ti se samo kaze, sto veca povrsina koja oslobadja toplotu to manja temperatura!
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
