»RSS Benchmark sajt
      Strana 1589 od 1601 PrvaPrva ... 58910891489153915791585158615871588158915901591159215931599 ... PoslednjaPoslednja
      Prikazani rezultati od 23.821 do 23.835 od ukupno 24009
      Tema: Windows 10 (FAQ u drugom postu)
      1. #23821
        Member Avatar korisnika rida
        Na forumu od
        Aug 2007
        Poruka
        716
      2. Moja mašina
        • CPU: C2D E8400
        • MoBo: GIGABYTE GA-P35-DS3L
        • RAM: OCZ DDR2 PC-6400 Reaper 2x2GB Kit
        • VGA: EVGA e-GeForce 8600 GT
        • MON: Samsung 932GW
        • HDD: WESTERN DIGITAL Caviar WD4000AAKS
        • OPT: DVD RW Philips SPD2414T
        • Case: Chieftec DG-01BD-U
        • INET: DSL
        • Ostalo: miš, tastatura, zvučnici: Logitech
      3. Koja verzija Windows 10 Pro se pokazala kroz ove godine kao najbolja (stabilnost, performanse itd)? Nesto se igram sa jednim laptopom pa hocu da probam staviti i isključiti update
      4. #23822
        Member Avatar korisnika poolmaker
        Na forumu od
        Apr 2013
        Lokacija
        Sombor
        Poruka
        9.136
      5. Moja mašina
        • CPU: Intel i5-4690K
        • MoBo: Asus Z97M-PLUS
        • RAM: 2x4GB Kingston HyperX
        • MON: HP Pavilion 23xi
        • HDD: Samsung 850 EVO 250GB, HDD Western Digital 2TB
        • Case: Fractal Design Arc Mini, Seasonic M12II-520 EVO
        • SND: Microlab Solo 6C
        • OS: Windows 10 LTSC x64
      6. LTSC je najbliže tome, stavi ltsc 2019, isključi update skroz, installiraj programe i ostalo što ti treba. Na kraju posla napraviš sliku sistema sa ugradjenom win alatkom ili još bolje besplatnim macrium reflectom i to je to, imaš računar na koji duže vremena možeš računati.
      7. #23823
        Newcomers
        Na forumu od
        Sep 2019
        Poruka
        520
        Microsoft details the features being deprecated or removed in the Windows 10 May 2020 Update
        Companion Device Framework: The Companion Device Framework is no longer under active development.
        Microsoft Edge: The legacy version of Microsoft Edge is no longer being developed.
        Dynamic Disks: The Dynamic Disks feature is no longer being developed. This feature will be fully replaced by Storage Spaces in a future release.
        Cortana: Cortana has been updated and enhanced in the Windows 10 May 2020 Update. With these changes, some previously available consumer skills such as music, connected home, and other non-Microsoft skills are no longer available.
        Windows To Go: Windows To Go was announced as deprecated in Windows 10, version 1903 and is removed in this release.
        Mobile Plans and Messaging apps: Both apps are still supported, but are now distributed in a different way. OEMs can now include these apps in Windows images for cellular enabled devices. The apps are removed for non-cellular devices.
        https://www.onmsft.com/news/microsof...ay-2020-update
      8. #23824
        Na forumu od
        Aug 2007
        Poruka
        716
      9. Moja mašina
        • CPU: C2D E8400
        • INET: DSL
      10. Nista, napravicu onda tako. Ima li LTSC 2019 nekih problema u nekompatibilnosti sa nekim programima ili nesto slicno?
        Menjao rida : 29.05.2020. u 17:36
      11. #23825
        Member Avatar korisnika Marko_
        Na forumu od
        Apr 2008
        Lokacija
        Požega
        Poruka
        754
      12. Moja mašina
        • CPU: AMD Ryzen 5 1600 @3.9 LC-CC-120-ARGB PRO
        • MoBo: Gigabyte b450 Aorus M
        • RAM: 2x8gb Kingston Hyperx Fury 3000mhz RGB
        • VGA: Zotac AMP! 1060 6gb
        • MON: LG Flatron 2240s-pn
        • HDD: patriot burst 240gb ssd + 500GBAAKS WD + 250GBAAJS + 320GBAAJS
        • OPT: /
        • Case: MS Dark Shadow,2xjetflo(rakete), FSP Fortron HYPER-S 500W
        • SND: sonic gear EVO7
        • OS: Windows 10 64bit
        • LAP: lenovo g580 (i5-3230M , 8gb ddr3, gt710M, 1tb seagate)
        • TV: LG Flatron "22"
        • INET: DSL
      13. ode forza horizon 4 narodna, nece vise da radii...
        inace problem za ovu ikonicu nisam resio, cist je racunar. sad me nateralo da izvucem pravu ikonu "this pc" odnosno da nije vise shorcut..sa njom nemam problema a ako je shorcut kao do sada mrda je gde hoce posle svakog refresha...
      14. #23826
        Member Avatar korisnika ericm
        Na forumu od
        Jun 2011
        Lokacija
        nbgd
        Poruka
        3.634
      15. Moja mašina
        • CPU: 9900K @ 5Ghz + D15s --- 8700K @ 5Ghz + U12A
        • MoBo: Z390 Phantom --- Z370i Strix
        • RAM: Trident Z 32GB 3600Mhz --- Trident Z 16GB 4000Mhz
        • VGA: 2080 Duke OC --- 580 8GB Pulse
        • MON: Alienware AW3418DW --- Predator XB241H
        • HDD: 970evo 500GB --- 850evo 500GB + 960evo 250GB / Time Capsule 2TB
        • Case: H200i + EVGA T2 850W --- Metis Plus + SF600
        • SND: Bose Companion 3 / B&O H6 / Bose SoundLink mini --- Audioengine A2+
        • OS: Win 10 --- macOS + Win 10
        • INET: Kablovska
        • Ostalo: iKBC C87 black + EC2-B --- iKBC C87 white + EC2-A
      16. ^ prestala da radi nakon ovog 2004 apdejta?
        it just doesn't work
      17. #23827
        Na forumu od
        Apr 2008
        Lokacija
        Požega
        Poruka
        754
      18. Moja mašina
        • OPT: /
        • INET: DSL
      19. da. procitah u medjuvremenu da nisam jedini, tako da mislim da je do apdejta..
      20. #23828
        Member
        Na forumu od
        Oct 2013
        Poruka
        94
      21. Moja mašina
        • CPU: AMD X4 955, CM 212
        • MoBo: Asus M4A87TD
        • RAM: 8 GB Kingston Hyperx
        • VGA: GTX 560 ti
        • MON: LG 22'' FHD
        • HDD: crucial bx500 256 GB
        • OPT: LG
        • Case: Cooler Master 332
        • SND: altec lansing 251
        • OS: Windows 10
        • LAP: Dell 5521
        • INET: DSL
      22. Obrisao sam windows update uz pomoc StopWinUpdates programa sa ovog linka http://m.majorgeeks.com/files/detail...inupdates.html da li sad mogu da apdejtujem na 2004 verziju uz pomoc Upgrade Assistant app? Trenutno sam na 1909.
        Menjao Nikbos : 30.05.2020. u 11:21
      23. #23829
        Member Avatar korisnika Lanikor
        Na forumu od
        May 2016
        Poruka
        2.677
      24. Moja mašina
        • CPU: Intel i7 4700HQ 2.4 GHz (3.4 TurboBoost)
        • MoBo: Intel HM 86 Mobile Chipset
        • RAM: 16 GB (2 x 8 GB) DDR3L Samsung 1600 MHz
        • VGA: Intel HD 4600 + Nvidia GTX 850M 2 GB DDR3
        • MON: Full HD 1920x1080 15.6"
        • HDD: Intel 545s 256GB SSD + Hitachi HDD 1.5 TB 5400 rpm
        • OS: Windows 10 Pro 64 bit
        • LAP: ASUS N550JK
        • Ostalo: Xiaomi Mi Max 3
      25. Niko ne komentarise kako radi 2004 na HDD?
        Treba da pregazim neki laptop pa bih stavio 2004 odmah a nema SSD.
      26. #23830
        Member Avatar korisnika NevisStarShine
        Na forumu od
        Aug 2014
        Poruka
        1.692
        Citat Citiram korisnika: Lanikor Pogledaj poruku
        Ne može više Win 10 na HDD-u, jednostavno ne može. Posebno ne 2.5" 5400 RPM.
      27. #23831
        Member
        Na forumu od
        Oct 2013
        Poruka
        94
      28. Moja mašina
        • VGA: GTX 560 ti
        • MON: LG 22'' FHD
        • OPT: LG
        • OS: Windows 10
        • LAP: Dell 5521
        • INET: DSL
      29. Najavili su da će ovaj apdejt ubrzati search index i kompjutere koji imaju hdd.
      30. #23832
        Na forumu od
        May 2016
        Poruka
        2.677
      31. Moja mašina
        • LAP: ASUS N550JK
      32. @NevisStarShine
        znam i ja da to ne moze da bude nikad prijatno kao na SSD ali ovaj update je trebalo da donese znatno poboljsanje u odnosu na trenutni rad na HDD pa me zanima kako 2004ka radi.
      33. #23833
        Banned
        Na forumu od
        Feb 2018
        Poruka
        2.598
        ako baš mora odradi bench sa hdtune-om,reći će ti u megabajt gde počinje značajan pad performansi (uobičajeno na nekih 30tak posto diska) i tolika da bude početna sistemska particija.kad sve instaliraš,skini auslogics disk defrag (ima i portable verzija za džabe) i odradi 'defrag and optimize' i nadaj se najboljem.
      34. #23834
        Na forumu od
        May 2016
        Poruka
        2.677
      35. Moja mašina
        • LAP: ASUS N550JK
      36. Mora, to mi je backup laptop na kojem stoji Linux Mint XFCE ali buduci vlasnik zahteva Office i tu je kraj toj opciji. Svakako je dat savet da sto pre predje na SSD.
        Pustio sam da se skida ISO pa cu da ga izgustiram sutra.
      37. #23835
        Member
        Na forumu od
        Aug 2000
        Poruka
        2.152
        Stavi Oprekina 2004.172 lite +, pa ga kroz update digni na 264. Ja sam tako i na desku i na starom lapu, radi vrhunski.
      Tagovi ove teme
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
