»RSS Benchmark sajt
      Strana 1520 od 1529 PrvaPrva ... 5201020142014701510151615171518151915201521152215231524 ... PoslednjaPoslednja
      Prikazani rezultati od 22.786 do 22.800 od ukupno 22928
      Tema: Windows 10 (FAQ u drugom postu)
      1. #22786
        Member
        Na forumu od
        Aug 2012
        Poruka
        1.998
        Laptop ima licencu za win 7 kasnije prebacenu na win 10. Medjutim sve vise vidim kako mu je win 10 pretezak.
        Vidim pominjete ovde neke olaksane LTSC verzije...da li ce mi vaziti licenca ako predjem na njega?
      2. #22787
        Member Avatar korisnika sam633
        Na forumu od
        Nov 2011
        Poruka
        4.637
        Ne. Za LTSC važi samo VL kanal, tj. aktivacija.
        Igoritza:"Necu se ja vala ovde vise nikad registrovati."
      3. #22788
        Member
        Na forumu od
        Aug 2012
        Poruka
        465
      4. Moja mašina
        • CPU: AMD Ryzen R5 2600 3.4Ghz
        • MoBo: Asus Prime B350 Plus
        • RAM: Kingston HyperX Fury 2x8GB DDR4 2666Mhz
        • VGA: Asus GeForce GTX950
        • MON: Benq VZ2470
        • HDD: Kinston HyperX Savage 240GB | WD Blue 1TB + WD Blue 500GB
        • Case: MS Titan Pro | CHIEFTEC CTG-550C 550W A80 series
        • SND: Terratec Aureon 7.1 PCIe/ C-Media HDA
        • OS: Win 10 LTSC
      5. Nvidia releases hotfix driver to fix disappearing mouse cursor
        431.68-desktop-notebook-win10-64bit-international.hf.exe
      6. #22789
        Member Avatar korisnika ericm
        Na forumu od
        Jun 2011
        Lokacija
        nbgd
        Poruka
        3.325
      7. Moja mašina
        • CPU: 8700K @ 4.9Ghz + D15s + HC4 ---- 6700 + Pure Rock
        • MoBo: Z370i Strix ---- VIII Impact
        • RAM: TridentZ 2x8GB 4000Mhz ---- LPX 2x8GB 2666Mhz
        • VGA: 2080 Duke OC ---- 1660Ti Gaming X
        • MON: Alienware AW3418DW ---- Predator XB241H
        • HDD: 970evo 500GB + 960evo 250GB ---- 850evo 500GB / Time Capsule 2TB
        • Case: H200i + G2 650W ---- Metis Plus + SF600
        • SND: Bose Companion 3 / B&O H6 / Bose SoundLink mini ---- Audioengine A2+
        • OS: Win 10 + Win 7 ---- macOS + Win 10
        • INET: Kablovska
        • Ostalo: ikbc C87 + EC2-B ---- ikbc C87 + EC2-A
      8. ^ okaceno vec u nVidia forceware temi.
        it just doesn't work
      9. #22790
        Member Avatar korisnika Lanikor
        Na forumu od
        May 2016
        Poruka
        2.006
      10. Moja mašina
        • CPU: Intel i7 4700HQ 2.4 GHz (3.4 TurboBoost)
        • MoBo: Intel HM 86 Mobile Chipset
        • RAM: 16 GB (2 x 8 GB) DDR3L Samsung 1600 MHz
        • VGA: Intel HD 4600 + Nvidia GTX 850M 2 GB DDR3
        • MON: Full HD 1920x1080 15.6"
        • HDD: Intel 545s 256GB SSD + Hitachi HDD 1.5 TB 5400 rpm
        • OS: Windows 10 Pro 64 bit
        • LAP: ASUS N550JK
        • Ostalo: Xiaomi Mi Max 3
      11. Hvala za info, ne zalazim u tu temu tako da je dobro sto je okacio, imam 850m GTX na laptopu.
        Mis je opet nestao danas posle brisanja drajvera za mis tako da cu da probam sad clean install Nvidia drajvera.
        Sent from my MI MAX 3 using Tapatalk
      12. #22791
        Newcomers Avatar korisnika darko100
        Na forumu od
        Jun 2018
        Lokacija
        Svilajnac
        Poruka
        130
        Citat Citiram korisnika: darko100 Pogledaj poruku
        Ipak probacu prvo sa 8.1 ipak je to stariju hardver
        NIsam uspeo da pokrenem windows8.1 vratio na(morao sam da vracam sa gpt na mbr) 7-icu u radio sve ali je racunar ipak slab za nesto vide od 7 za win 10 ipak treba vise ram memorije makar od 6 do 8 gb ja imam samo 4 i mana je sto na toj ploci nema opcija da se poveca integrisana grafika deli samo 110 mb od 1696 mb i tu isto koci zbog grafike. Planiram jedan ssd od 120gb da ubacim moracu nasata 2 da nakacim posto nema sata 3 imam samo sata 0, 1, 2 i e sata. I ako uspem da nacem neki program za kontrolu intel integrisane deljene grafike.pa cu kasnije da probam ponovo da instaliram 10-tku. Imam graficku ali je nisam stavio jer je slabijih perfomansi nvidia ge forse 8400 gs 256 mb ddr2 slaijih perfomansi nego ova integrisana. I cisto jedno pitanje da li zna neko neki program za kontrolu intel integrisane grafike da povecam memoriju(jasno mi je da cu morati da dodam jos rama zbog toga).
        Menjao darko100 : 30.07.2019. u 19:05
      13. #22792
        Moderator Avatar korisnika PJ
        Na forumu od
        Sep 2000
        Lokacija
        Zemun
        Poruka
        6.992
        Imam problem da odradim Update W10 Pro. trenutno je 1803 i ne dozvoljava mi update zbog:
        https://support.microsoft.com/en-us/...ain-versions-o
        Spoiler:
        If you are trying to update to the Windows 10 May 2019 Feature Update (Windows 10, version 1903), you may encounter an update compatibility hold and receive the message, "Intel Rapid Storage Technology (Intel RST): The inbox storage driver iastora.sys doesn’t work on these systems and causes stability problems on Windows. Check with your software/driver provider for an updated version that runs on this version of Windows."
        Intel and Microsoft have found incompatibility issues with certain versions of the Intel® Rapid Storage Technology (Intel® RST) drivers and the Windows 10 May 2019 Update. If your device has an Intel® RST driver version between 15.1.0.1002 and 15.5.2.1053 installed, it cannot install the May 2019 Update.
        Versions 15.5.2.1054 or later are compatible, and a device that has these drivers installed can install the Windows 10 May 2019 Update. For affected devices, the recommended version is 15.9.6.1044.
        Pokušao sam da instaliram poslednju verziju Intel RST, ali tek onda vidim da ja uopšte nemam Intel RST u Device manager.
        Ukoliko ti se neki proizvod (ne)sviđa, podeli svoje mišljenje, ali ne pokušavaj da ubediš ostatak planete da živi u zabludi.
      14. #22793
        Na forumu od
        May 2016
        Poruka
        2.006
      15. Moja mašina
        • LAP: ASUS N550JK
      16. Da nemas slucajno neki Intel SSD? Kroz maglu se secam da je bilo nekih problema oko toga (moguce da gresim) pa te mozda to zeza. Azuriraj firmware za SSD ako imas Intel.
      17. #22794
        Member Avatar korisnika Sass Drake
        Na forumu od
        Jun 2009
        Lokacija
        Hypnos Control Room
        Poruka
        1.078
      18. Moja mašina
        • CPU: i5-6600K @ 4.1-4.4GHz, CM Hyper 212 EVO
        • MoBo: Asus Z170-A
        • RAM: 16GiB DDR4 3200MT/s 16-18-18-36 (2x Kingston HyperX Predator HX432C16PB3K2/16))
        • VGA: Gainward GeForce GTX 750 2GiB GDDR5 singleslot
        • MON: Dell P2414H
        • HDD: Samsung 850 EVO && WD2003FZEX-00Z4SA0 && Barracuda 7200.12 500418 ST3500418AS
        • OPT: LG SH-224DB
        • Case: CM Silencio 452 + Corsair VS550
        • SND: Integrisana Realtek ALC892
        • OS: Windows 10 Enterprise LTSC 2019 x64
        • LAP: Dell E6410 (i7-620M, 8GiB, NVS3100M, 320GB Win2019 x64)
        • INET: DSL
        • Ostalo: Samsung SM-G388F Galaxy Xcover 3 (Android v5.1.1)
      19. Citat Citiram korisnika: PJ Pogledaj poruku
        Spoiler:
        Skinuo si odavde? Koju imaš matičnu?
        https://downloadcenter.intel.com/dow...and-Driver?v=t
        There is no place like ::1
      20. #22795
        Member
        Na forumu od
        Apr 2013
        Poruka
        92
        Mozda sam preskocio u temi ali imam jedno pitanje posto nisam neki strucnjak za to:zasto mi komp vraca u sistem configuration sa normal startap na selective startap.Lepo cekiram normal,ugasim opet se vrati na selective.Ne bi mi bio problem al osetno brzde dize sistem na normal.Izvinjavam se unapre ako je bilo o tome i ako je pitanje laicko,ponavljam nisam bas neki it strucnjak
      21. #22796
        Na forumu od
        Sep 2000
        Lokacija
        Zemun
        Poruka
        6.992
        Citat Citiram korisnika: Sass Drake Pogledaj poruku
        Da, odatle sam skinuo.
        Imam HP 470 G4, Ploča je HP 8234, Kaby Lake. Socket 1356.
        CPU i7 7500U.
        SSD je San Disk X400 SD8SN8U 256GB.
      22. #22797
        Na forumu od
        May 2016
        Poruka
        2.006
      23. Moja mašina
        • LAP: ASUS N550JK
      24. Onda ne bih znao sta je problem.
        Sto se tice bug-a gde nema kursora nakon palenja laptopa, problem je resen azuriranjem drajvera za graficku (Nvidia).
      25. #22798
        Member Avatar korisnika terzazak
        Na forumu od
        Feb 2007
        Lokacija
        Niš
        Poruka
        1.485
      26. Moja mašina
        • CPU: AMD Phenom II 965, Xigmatek S1284
        • MoBo: GA-790FXT-UD5P
        • RAM: Geil GV34GB1600C8DC
        • VGA: Zotac 1060 3GB AMP
        • MON: Benq G2420HD
        • HDD: 850 EVO 500gb+WD640+1,5TB HD153WI
        • OPT: Samsung 222f/BEBE
        • Case: CM 690+Chieftec 750W-14cs
        • SND: Genius S1255 v2.1
        • OS: Win 10, Bitdefender
        • TV: LG 32LH3000
        • INET: Kablovska
        • Ostalo: Xiaomi Redmi 4 prime
      27. Citat Citiram korisnika: Kadi Pogledaj poruku
        Ako si rucno podesavao servise (onemogucio pokretanje nekog) ili neku od startup item(s) Win vraca na selektivni start.
        Prvo hopni, pa reci skoč
      28. #22799
        Member Avatar korisnika Qaxentius
        Na forumu od
        Oct 2016
        Lokacija
        Beograd
        Poruka
        199
        Braćo pomagajte: imam isti BSOD - Memory Management.
        Ne znam šta je u pitanju, HDD radi normalno ima 11 loših sektora (93% Health u Hard Disk Sentinel).
        Ne znam da li je možda do RAM memorije ? Ona radi normalno, zauzeće nikada nije blizu maksimuma od 4 GB.
        Jel ima neko savet ?
      29. #22800
        Na forumu od
        Nov 2011
        Poruka
        4.637
        Citat Citiram korisnika: Qaxentius Pogledaj poruku
        HDD radi normalno
      Tagovi ove teme
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
