owim
(Pretražio sam celu OC temu i nigde nisam našao OC G3258. Ukoliko postujem na pogrešnom mestu, molim moderatora da premesti.)
Hteo bih da kupim Pentium G3258 AE - Anniversary Edition (otključan množilac) i neku mATX ili mITX budžet ploču (npr. B85, H87 čipset) koja može da klokuje.
Čitao sam da i da nije potrebna dosta skuplja Z-ploča:
- Asus enables Haswell overclocking on non-Z-series motherboards (link).
- ASRock enables CPU overclocking on H87, B85 motherboards (link).
izvor: http://www.pcgamer.com/review/intel-pentium-anniversary-edition-g3258-review/
- Kakva su vaša G3258 OC iskustva? Koji ploču izabrati od navedenih?
- Šta mislite o Gigabyte GA-B85M-D3H ploči za OC? (Držim se budžet varijante, umesto Z-serije.)
- Navodno može da OC, ali ne i da koriguje voltažu, kao ni da uradi OC RAM-a (za to, navodno, treba Z-serija). Ako mi je ovo poslednje uopšte potrebno.
- Sa nekog foruma:
Nikad nisam OC ničega, vaše iskustvo bi dosta značilo. Hvala! :wave:
This chip is all about overclocking, and things change around completely when you start playing with the clockspeeds. And, for the record, I’m no serious overclocker—all I’ve done is stick a closed-loop liquid chiller on top and thrown the CPU multiplier up in the BIOS. The awesome little G3258 has done the rest.
From a starting point of 3.2GHz I was able to get the G3258 running at a completely stable, and relatively cool, 4.6GHz. That’s the same top clockspeed I’ve been able to get from our Core i7 4770K engineering sample.
With the Pentium Anniversary Edition then Intel has created a bargain gaming chip that will beget some seriously powerful budget gaming rigs. Pair this $75 processor up with a $50 B85 motherboard—with that chipset’s unofficial overclocking skills—and you’re well on your way to building a powerful little machine at a reasonable price.
You can reach clock speeds of 4.2 - 4.4Ghz on the stock air cooler, I know because I just did it.
- Sa nekog foruma:
GA-B85M-D3H is voltage locked at 1.2v, so overclocking past 4ghz is unlikely, and in my case the highest stable clock I can get is 3.7ghz
