Problem s premotavanjem videa, da li je zbog compressed headers-a (header stripping)?
Gadjan
Prvi put se srećem s ovim pa me interesuje gde je problem. Mislim viđao sam to i ranije ali kad je fajl koruptovan, a u ovom slučaju film je navodno ispravan i niko se nije žalio. A ne znam kako može da bude do mene kad koristim isto što i svi ostali, probao sam dva plejera, dva splitera i nekoliko dekodera. Znači play ide od starta ali pri premotavanju BS crashuje a MPC baferuje. Evo i MediaInfo. Inače imam drugi fajl, isto piše header stripping u MediaInfo-u ali radi normalno.
General
Unique ID : 205890432023000350663065331310701408076 (0x9AE50E094FE8EF5EA06EBBA0D9CD6F4C)
Format : Matroska
Format version : Version 2
File size : 13.1 GiB
Duration : 3h 9mn
Overall bit rate : 9 897 Kbps
Encoded date : UTC 2010-07-25 12:35:50
Writing application : mkvmerge v4.1.1 ('Bouncin' Back') built on Jul 3 2010 22:54:08
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 3h 9mn
Bit rate : 8 006 Kbps
Width : 1 280 pixels
Height : 544 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.480
Stream size : 10.3 GiB (79%)
Title : x264 @ 8006 Kbps
Writing library : x264 core 104 r1677 19df41a
Encoding settings : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=8006 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / aq=1:0.80 / nal_hrd=none
Language : English
Default : Yes
Forced : No
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Muxing mode : Header stripping
Codec ID : A_DTS
Duration : 3h 9mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 2.00 GiB (15%)
Title : DTS 5.1 @ 1.5 Mbps
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Format profile : Dolby Digital
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 3h 9mn
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Bit depth : 16 bits
Stream size : 261 MiB (2%)
Title : Commentary with Russell Crowe
Language : English
Default : No
Forced : No
Audio #3
Format : AC-3
Codec ID : A_AC3
Duration : 3h 9mn
Bit rate : 192 Kbps
Bit depth : 16 bits
Title : Commentary with Ridley Scott
Language : English
Default : No
Forced : No
Možda je bag u korišćenom muxeru. x264.exe obično ima taj problem kad sam kreira MKV fajl. Probaj da ga prepakuješ sa MKVMerge.
Radi kad se prepakuje ili odseče parče, zaboravio sam da napišem. Nego me interesuje gde je problem, da li u fajlu ili može biti do mene nešto. Da li header stripping može uzrokovati ovakav problem i da li MPC inače pušta bez problema fajlove s takvom kompresijom? Pošto nemam više komada da uporedim, vidim dosta je to redak slučaj, imam tonu filmova ali samo dva sa header strippingom, jedan radi drugi ne.
Takav problem se javlja kada mkv fajl ne sadrži indeks za pretragu (Cueing Data). Recimo, x264.exe kreira takav mkv fajl, bez indeksa.
E sad, u logu stoji da je fajl kreiran sa mkvmerge. Ja se ne sećam da li je mkvmerge nekada imao takav bag. A možda je fajl procesuiran nekim programom koji je zadržao podatak o programu koji je kreirao originalni fajl a pri tome stvorio problem. Uglavnom, Header Stripping ne bi trebao da bude uzrok problema.
Hvala ti. Onda me na trekeru prave ludim, a i nikom ne pada na pamet da proveri fajl :).
Prvo reko ok, ja se ne razumem ni ne znam šta je stripping... ali nema to očigledno veze. A i koristim poslednje verzije MPC-a, splitera, dekodera... da je fajl dobar to mora da radi.
Vidi, to možeš i sam da proveriš. Skini MKVToolnix 4.1.1 (ima na VideoHelp) i spakuj neki fajl sa njim. Po default-u ova verzija uključuje header stripping za AC3 audio. Ako bude problema sa motanjem onda je to bag u toj verziji MKVMerge-a. Sa druge strane, ako kompresuješ neki fajl sa x264.exe i on kreira mkv fajl videćeš jasne probleme i baferovanje u plejeru. Za to možeš da iskoristiš Simple x264 Launcher ako nećeš da se zezeaš sa komandnom linijom.
Ja sam probao i MKVMerge 4.1.1 i 6.9.1 i premotava bez baferovanja. Sa druge strane x264.exe verziju mkv-a MPC-BE baferuje i sa internim i sa LAV filterom. Naravno, kada se takav fajl prepakuje sa MKVMerge onda nema problema jer mkvmerge kreira indeks za pretraživanje.
Problem je do windowsa, fajl se premotava normalno na win7 u različitim plejerima, dok na xp-u zabada.
Sad mene zanima šta konkretno može da bude razlog?
Ko zna sta sve moze da bude, xp je dosta zastareo sistem. Mozda neka kombinacija nekih kodeka/filtera je bagovala (pricam napamet). A tvoja konfiguracija je dovoljno dobra da bi win 7 radio bez problema, pa ti predlazem da njega koristis :)
Nema to veze sa problemom ni konfiguracijom ni kodecima (inače možda je moja konfiguracija dovoljno dobra za win7 ali win7 nije dovoljno dobar za nju ;))
XP je možda zastareo kao sistem ali kodeci nisu zastareli već najsvežiji, apdejti izlaze redovno i sve radi savršeno. Koristim BS Player i MPC HC, probani najsvežiji CoreAVC, LAV Filters, ffdshow dekoderi kao i svi mogući rendereri, na različitim konfiguracijama sa XP-om. Dva terabajta video materijala imam i problem postoji samo sa jednim fajlom.
Mene interesuje koji je razlog da taj fajl ne radi. U čemu se on razlikuje od stotina drugih ripova. Kao i zašto ista kombinacija plejera, dekodera i renderera pušta fajl na win7 a na xp-u zabada.
E sad win 7 ne valja, u debeloj si manjini :p. Ne vidim razlog za koriscenje xp pored sedmice, jedino ako neki stari hardwer nema upotrebljive drajvere za sedmicu (zvucna, tv kartica). Ako sam dobro ispratio, kada provuces taj fajl kroz mkvmerge onda ti i na xp radi kako treba?
Nisam ali sad sam pogledao šta je to, koliko vidim to je softver za popravku fajlova? A evo sad sam ga ubacio i meteorit je pao :D.
Inače meni ne treba popravka fajla, to lako mogu da uradim, nije problem. Dovoljno je samo da remuxujem fajl, ubacim u mkvmerge i sačuvam novi fajl, znači bez ikakvog čačkanja dodavanja oduzimanja i rekompresovanja. I novi fajl će besprekorno raditi.
Mene zanima ko je zajebao stvar, gde tačno i u čemu je tačno problem u fajlu i u windowsu.
Ajde da zamislimo da XP i sedmica nisu bile na istom hardveru i da je to razlog?
Nema veze da li sam ubo, sledece sto sam primetio je da je koriscen high level 4.1 sto bi bio krupan zalogaj za slabiji hardver ...mozda ima veze?
...i na kraju, mozda keca neki .dll u samom xp?
Reklo bi se da je to Gladijator, ciji encode? Da proba jos neko.
Da, probao je ortak na svojoj sedmici i probao sam ja kod burazera. Svakako zbog drugih nekih stvari trebam da isprobam kod sebe da napravim dual boot da probam sedmicu pa ću videti i ovo, ali ko zna kad će to da bude, nemam vremena a treba svašta nešto da odradim pre tog pretumbavanja particija.
Mada ne verujem da hardver ima ikakve veze, svaki mogući rip 4.1 ili 5.1 radi perfektno i premotava se munjevito. Radi sve živo i preko cpu i cuda i dxva... a ovaj fajl neće.
Da, gladijator 720p EbP. Ko da proba kad svi koriste sedmice? :)
Imam ja XP na jednom miniITX ...intelov dual core je, 2GB RAM i neka slabija gma ...a imacu i taj encode pa cu ti preneti zapazanja.
Imam i ja četiri različita računara u kući sa xp-om i na svima ne radi :)
A i kako ćeš znati da je to baš isti taj encode? Imam ja i drugi EbP skinut sa drugog mesta, ista veličina isto sve samo taj radi i premotava. Naravno nisu u bit isti, imaju drugačiji md5 hash.
Ako ćeš već da se cimaš mogu ja da ti pustim na pm direktan link za taj encode sa mog clouda.
E da, zaboravih, md5: 8dc58c8f28e549b7e4cef763abc8974a ;)
Pa onda nista ne dokazujemo time sto cu i ja probavati. :D
...a kao sto sam provalio da se radi o Gladijatoru tako bih provalio i koji je tacno encode, ja pazljivo citam a ti si ostavio i unique ID ;)
Ja cu onda odustati a ti bi mogao, pod uslovom da si jos zainteresovan da otkrijes gde je zvrcka ...da uporedis mediainfo ta dva razlicita fajla.
Pa naravno da sam zainteresovan zato sam i otvorio temu i iscimao se ovoliko.
Inače nije bilo teško provaliti, audio komentar by Ridley Scott :) prva asocijacija je naravno gladijator a proveri se i runtime i onda si siguran :)
Dalje, unique id možeš da okačiš mačku o rep :) ta dva fajla imaju identičan id a nikako nisu isti. Jedan radi drugi ne. Takođe taj drugi koji radi, ako recimo probam da cross seedujem utorrent čekira i prepozna samo 8.32 GB dok bi preostalih 4.79 trebalo da se skine. Nemam više taj drugi ispravan fajl na hdd-u ali sećam se dobro da je tako bilo i da je unique id bio isti. Prošlo već godinu dana pa ću ga skinuti ponovo da se podsetim i da budem 1001% siguran.
Inače evo novi momenti, sad kad sam ubacio u mkvmerge da remuxujem primetim u logu sledeće:
Error in the Matroska file structure at position 8940845017. Resyncing to the next level 1 element.
Still resyncing at position 9048979569
i to resyncing traje i traje...
I kako sad to može da se smatra ispravnim fajlom? To što na win7 prividno radi ok i premotava to me ne interesuje.
Nema tu vise nejasnoca ako je unique ID isti. Radi se o identicnom encodeu. Greska je posledica torentovanja i ti imas nedostajuce komadice u tom problematicnom fajlu. Dokaz pronalazis tako sto ce i torrent za ispravni fajl do neke tacke uspesno hashovati neispravni fajl, zatim tako sto je nedostajuca kolicina podataka deljiva sa izabranim pieces size tokom kreiranja torrenta.
Scenario da do greske dodje je sledeci - reuploader nije skinuo 100% fajla/sadrzaja_foldera, kreirajuci torrent hashovao je takav nekompletan fajl i uploadovao ga i odatle ta mala razlika u tezini fajla.
Imam slično mišljenje, samo činjenice su obrnute, nisi dobro skapirao, pazi sad ovo :) :
Nije greška u torentovanju. Fajl koji ne radi na različitim XP mašinama i sa raznim dekoderima i plejerima, taj fajl je "ispravan", siduje se na uglednom trekeru i "radi" na win7 bar na prvi pogled, premotavanje je tečno.
Drugi fajl, skinut iz rar partova sa nekih host linkova (isti EbP encode, iste veličine a mislim i identičnog media info-a ali evo sad ga skidam da još jednom potvrdim, ali provereno različit md5), taj fajl radi lepo premotavanje i na xp-u. Njega na trekeru čekira samo do 60ak% jer nisu isti.
Svojevremeno sam prijavio originalni fajl kao neispravan, dao laičko objašnjenje šta ne radi i ponudio drugi ispravan fajl u zamenu. Report je stajao neko vreme dok nije opovrgnut i uklonjen, fajl je navodno ok :trust:.
Tada nisam znao da mkvmerge izbacuje greške u logu, verovatno nisam obratio pažnju. Skrenuli su mi pažnju da je verovatno header stripping uzrok, što nije slučaj jer imam još takvih fajlova koji rade bez problema.
Sada sam instalirao najnoviji mkvmerge i remuxovao opet, evo komplet log.
mkvmerge v7.8.0 ('River Man') 32bit built on Mar 27 2015 16:18:02
kax i am at 8979
'Z:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP.mkv': Using the demultiplexer for the format 'Matroska'.
create pack at 8979
'Z:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP.mkv' track 0: Using the output module for the format 'AVC/h.264'.
'Z:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP.mkv' track 1: Using the output module for the format 'DTS'.
'Z:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP.mkv' track 2: Using the output module for the format 'AC3'.
'Z:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP.mkv' track 3: Using the output module for the format 'AC3'.
'Z:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP.mkv' track 4: Using the output module for the format 'text subtitles'.
'Z:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP.mkv' track 5: Using the output module for the format 'text subtitles'.
'Z:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP.mkv' track 6: Using the output module for the format 'text subtitles'.
'Z:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP.mkv' track 7: Using the output module for the format 'text subtitles'.
'Z:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP.mkv' track 8: Using the output module for the format 'text subtitles'.
'Z:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP.mkv' track 9: Using the output module for the format 'text subtitles'.
'Z:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP.mkv' track 10: Using the output module for the format 'text subtitles'.
'Z:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP.mkv' track 11: Using the output module for the format 'text subtitles'.
'Z:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP.mkv' track 12: Using the output module for the format 'text subtitles'.
'Z:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP.mkv' track 13: Using the output module for the format 'text subtitles'.
'Z:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP.mkv' track 14: Using the output module for the format 'text subtitles'.
The file 'D:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP (1).mkv' has been opened for writing.
Z:\Gladiator.2000.Remastered.2in1.720p.BluRay.DTS x264-EbP.mkv: Error in the Matroska file structure at position 8940845017. Resyncing to the next level 1 element.
The last timecode processed before the error was encountered was 01:52:50.681000000.
Still resyncing at position 9002850582.
Still resyncing at position 9065416562.
Still resyncing at position 9127907474.
Still resyncing at position 9190422995.
Still resyncing at position 9252905885.
Still resyncing at position 9314372129.
Still resyncing at position 9376352714.
Still resyncing at position 9438971501.
Still resyncing at position 9500500756.
Still resyncing at position 9562616680.
Still resyncing at position 9625258739.
Still resyncing at position 9687936392.
Still resyncing at position 9750298385.
Still resyncing at position 9812906142.
Still resyncing at position 9875440967.
Still resyncing at position 9938099914.
Still resyncing at position 10000602024.
Still resyncing at position 10063296947.
Still resyncing at position 10125800775.
Still resyncing at position 10188462620.
Still resyncing at position 10250853571.
Still resyncing at position 10313502746.
Still resyncing at position 10376182293.
Still resyncing at position 10438820992.
Still resyncing at position 10501442921.
Still resyncing at position 10564101140.
Still resyncing at position 10626629273.
Still resyncing at position 10689243198.
Still resyncing at position 10751916476.
Still resyncing at position 10814581115.
Still resyncing at position 10877166388.
Still resyncing at position 10939837498.
Still resyncing at position 11002411212.
Still resyncing at position 11064977081.
Still resyncing at position 11127576790.
Still resyncing at position 11190137833.
Still resyncing at position 11252735715.
Still resyncing at position 11315412452.
Still resyncing at position 11378045649.
Still resyncing at position 11440707698.
Still resyncing at position 11503401079.
Still resyncing at position 11565988843.
Still resyncing at position 11628479959.
Still resyncing at position 11691096639.
Still resyncing at position 11753720908.
Still resyncing at position 11816323266.
Still resyncing at position 11878962140.
Still resyncing at position 11941649211.
Still resyncing at position 12004240991.
Still resyncing at position 12066920597.
Still resyncing at position 12129543918.
Still resyncing at position 12192241006.
Still resyncing at position 12254895659.
Still resyncing at position 12317575525.
Still resyncing at position 12380196639.
Still resyncing at position 12442809443.
Still resyncing at position 12505330614.
Still resyncing at position 12567995782.
Still resyncing at position 12630640877.
Still resyncing at position 12693296949.
Still resyncing at position 12755904471.
Still resyncing at position 12818488200.
Still resyncing at position 12881110027.
Still resyncing at position 12944138197.
Still resyncing at position 13007144919.
Still resyncing at position 13070050857.
Still resyncing at position 13133054282.
Still resyncing at position 13196007706.
Still resyncing at position 13258985039.
Still resyncing at position 13322003199.
Still resyncing at position 13385001048.
Still resyncing at position 13448015625.
Still resyncing at position 13510840937.
Still resyncing at position 13573834279.
Still resyncing at position 13636681901.
Still resyncing at position 13699741614.
Still resyncing at position 13762774434.
Still resyncing at position 13825780777.
Still resyncing at position 13888747970.
Still resyncing at position 13951771801.
Still resyncing at position 14014714148.
Still resyncing at position 14077743338.
Resync failed: no valid Matroska level 1 element found.
The cue entries (the index) are being written...
Muxing took 16 minutes 36 seconds.
Dobijeni fajl radi i premotava se uredno ali samo prva dva sata, dalje ne radi. Moguće da je tako bilo i prvobitno kad sam svojevremeno remuxovao i seckao parčiće (koji su radili) za probu, samo nisam premotao poslednju trećinu pa nisam tada primetio...
Ništa dok se ne skine onaj drugi koji mislim da je besprekoran.
Da još samo napomenem da originalni fajl ne radi premotavanje uopšte, niti na jednoj poziciji. Samo mogu da ga pustim da ide play od početka.
Ako su tacni svi tvoji opisi onda je tacna i moja konstatacija.
Osnovnu gresku pravis na mestu gde fajl sa "uglednog trakera" smatras ispravnim a onaj iz .rar partova neispravnim. Situacija je obrnuta sto pokazuju i plejeri na oba OS.
Jedini referentni tracker za ovaj fajl je HDB i evo ja tipujem da se cheksum fajla iz rar partova podudara sa onim za fajl sa HDB.
I ako sam za sve to u pravu onda nije tacno da nisam dobro skapirao ...a ti ces moci da reuploaderu sa tog "uglednog trackera" prepricas scenario koji sam ti izlozio u prethodnom postu a on ce morati da prizna da je to tacno. Naravno, ako je tacno ono sto si na jednom mestu napisao da se za ta 2 fajla tezina razlikuje u "par bita" ...ako to nije tacno onda reuploader sa "uglednog trackera" nije kriv vec je za ovu gresku kriva fajl sistem greska ili bad sector na tvom hdd.
Ako hoces jos dokaza reci mi ime tog "uglednog trackera" ili mi posalji torrent fajl iz koga ces pobrisati svoj passkey a ja cu ga analizirati i uporediti sa orignalnim torrentom i obavestiti te o rezultatima. Naravno, ako umes da analiziras torrente a nisi na HDB mogu ja tebi da posaljem originalni torrent umanjen za passkey pa ti to sam uradi.
...I videces da ce zakljucak biti bas onaj koji sam izneo u prethodnom postu.
Izgleda da se rešenje nazire :) na dobrom smo putu. Pa aj ovako redom:
Prvo, hvala puno na pomoći ;). Drugo, što ne reče odmah da si na HDB, daj md5 checksum ako ima tamo i odmah ćemo rešiti misteriju. Ja imam md5 od oba fajla. A ako nemaju md5 valjda imaju nešto drugo (sha1 ?), tako da evo ja skidam drugi ispravan fajl valjda će skinuti noćas a da ne pukne (dešava se, prokleti cloud), ide 500-600 kbps, još i ne iskorišćava potpuno moj bedni 6 mbit wifi (a na telekomu i sbb-u gazi :) ne znam zašto).
Na ovo sam mislio da si obrnuo. Nije greška u torentovanju ni korupcija na hdd-u jer sam fajl skinuo dva puta sa trekera a i prolazi checksum proveru i sidujem ga (a ne radi mi). Inače nigde nisam napisao da im se težina razlikuje, iste su veličine, nego samo nisu u bit isti (imaju drugačiji md5). Taj drugi iz rar partova kolko se sećam radi i ima isti unique id ali se 40% ne podudara s onim sa trekera. Tj ne koliko se sećam nego imam zapisano, ali evo skidam ponovo da proverim da nisam lud :).
Zato sam i sačuvao fajlove da rešim jednom kad me ne bude mrzelo. Nije mi bitan film uopšte, svakako sam prešao na 1080p samo neću da me niko pravi ludim, bez obzira dal su gurui, stafferi, bogovi... ;)
Pogrešno si razumeo, ja lično smatram ispravnim fajl iz rar partova, samo nisam potpuno siguran. Ja sam laik i kad mi neki "autoritet" kaže da je nešto do mene, ok poštujem to ali i dalje sumnjam. Neka bude da je problem do mene, dok se ne dokaže suprotno. Ali ako je kod mene, onda hoću da znam po čemu je taj fajl drugačiji od svih drugih i zašto ne radi na xp-u. Takođe i ako fajl nije dobar, onda zašto tačno win7 uspeva da ga premotava.
Treker je inače PTP, nije nikakva tajna.
Da li si obratio paznju na ovo:
The Extended (Runtime: 2:50:56) and the Theatrical (Runtime: 2:34:58) Edition are both included
how do you choose which one to watch? i can't seem to figure it out.
1. Please install latest Haali Splitter, K-Lite Mega Codec + MPC on Windows OS.
2. Start the movie, right click on the Haali's icon in the systray
3. Select edition which yo want to watch.
4. Keep always extra files with the main movie.
5. If you will mux any Audio or Sub tracks in the movie, Editions won't work - only Defalt one will be playable
6. If you want to mux any audios or subs, please preserve the original version with Extra files in same directory to be able to see 2in1 Editions in the future.
7. Only Default Edition will be played on Hardware MKV Players.
I recommend the theatrical cut
Nema na HDB zapisa o md5 cheksum niti bilo kog drugog. I na PTP sam i sutra te informisem da li su fajlovi na oba trackera isti i samim tim ispravni.
Nema to veze s tim što je 2in1, radi šaltanje između bioskopske i produžene verzije. MPC lepo skonta i promeni runtime, ali čim premotaš bilo gde buffering ili hang/crash :).
A koliko se sećam na fajlu koji mi je radio sve je šljakalo.
Ali ja sam noob, i meni kad neko ko bi trebalo da zna mnogo više kaže da je kod mene problem onda uglavnom verujem. Tako je i nastala ova tema jer me zanima šta može da bude, nikakve logike nema.
Da sam odmah tada primetio one greške u logu prilikom remuxovanja, svega ovoga ne bi bilo...
Kako misliš da uporediš fajlove ako nemaju checksum? Nećeš valjda da skidaš oba?
Ako budeš skidao, sačuvaj obavezno checksume.
Da moj zakljucak iz posta #20 je 100% tacan, na PTP je postavljen nekompletan fajl!
1. dokaz je to sto sam skinuo originalni .mkv fajl sa HDB i pokusao cross seed na PTP a uTorrent 2.2.1:2503 je uspesno hashovao 63,4% fajla,
2. dokaz ces ti sklopiti uporedjujuci hash vrednosti PTP fajla i hash vrednosti originalnog fajla sa HDB a koje su:
CRC32: B487B887
MD5: 66EA5A770974EFBD880D1D800AFC324F
SHA-1: 2EBAA3D65F8DA66F1350C7B80D8CAA1CAF8257AE
Eto mozemo da sumiramo da compressed headers nisu razlog za otvaranje teme. ;)
Pa da, to je taj md5. Taj fajl sam bio skinuo iz rar partova. I noćas ga skidao ponovo s clouda da se podsetim i da proverim da sve radi, samo je puko download jer je taj cloud kršina.
Znači zaključak, ne samo da kod njih može neispravan fajl da se okači i da stoji dve godine, nego čak i kad se prijavi i objasni problem ni to nije dovoljno da neko zaista kompetentan proveri fajl. Ja se ne razumem pa razlog tražim na pogrešnim mestima (header stripping, "zastareli XP"...) ali mislim da za nekog ko se razume i zna šta radi to nije više od par minuta vremena.
Eto meteorit crashuje, mkvmerge brljavi i ne izmuxuje komplet video do kraja a stari dobri xp :) ne maskira problem nego lepo zakuca plejere :D
