D
Deleted member 9456
Guest
Kod:
General
Complete name : e:\Film\izlazz.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 205 MiB
Duration : 1h 0mn
Overall bit rate : 477 Kbps
Encoded date : UTC 2015-11-09 12:24:29
Tagged date : UTC 2015-11-09 12:24:29
Writing application : Hybrid 2015.10.21.1
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L3@Main
Codec ID : hvc1
Codec ID/Info : High Efficiency Video Coding
Duration : 1h 0mn
Bit rate : 282 Kbps
Maximum bit rate : 957 Kbps
Width : 840 pixels
Height : 478 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 24.670 fps
Minimum frame rate : 8.333 fps
Maximum frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.028
Stream size : 121 MiB (59%)
Title : [email protected]: 0.5.2-426-gc5ad4e4+dfsg5-1ppa1~trusty
Writing library : x265 1.8+1-5dcc9d3a928c400b:[Linux][GCC 4.8.4][64 bit] 8bit+10bit+12bit
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / cu-lossless / no-constrained-intra / no-fast-intra / no-open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=24 / scenecut=40 / rc-lookahead=20 / lookahead-slices=0 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / limit-refs=0 / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=0.30 / rdoq-level=0 / psy-rdoq=0.00 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / rc=crf / crf=28.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / ipratio=1.40 / pbratio=1.30
Encoded date : UTC 2015-11-09 12:24:26
Tagged date : UTC 2015-11-09 12:24:31
Color range : Limited
Matrix coefficients : BT.601
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : ac-3
Duration : 1h 0mn
Bit rate mode : Constant
Bit rate : 192 Kbps
Maximum bit rate : 203 Kbps
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 82.6 MiB (40%)
Title : ac3#audio:[email protected]: 0.5.2-426-gc5ad4e4+dfsg5-1ppa1~trusty
Encoded date : UTC 2015-11-09 12:24:30
