Key Lime Pie nikada neće izaći, to je bila radna verzija KitKat-a, a sledeća verzija će se zvati na M. Naravno da će biti i 32bit verzije zato što Google ne može sebi da priušti da nijedan aktuelni telefon ne dobije ažuriranje, ionako prihvatanje novih verzija androida ide izuzetno sporo, iako je izašao pre 9 meseci KitKat se nalazi na samo 8,5% uređaja
Pa ima veze, zato što i aplikacije moraju da budu rekompajlirane da bi mogle u potpunosti da iskoriste prednosti 64bitnog sistema, a pitanje je kojom će brzinom to ići, kada najpopularniji programi za desktop još uvek nemaju 64bit verzije a procesori i sistemi postoje više od decenije. Uz to, iz iskustva sa desktop računarima, ako imaš manje od 3gb rama potpuno je svejedno da li ćeš imati 32bit ili 64bit sistem, u realnom radu performanse će biti praktično iste, ali ne i lošije sa 64bit sistemom
Koja korist od 64-bitnog androida i aplikacija?
Ne da nije suludo uzeti ovako neki telefon nego je suludo čekati bilo šta...
Jos ce na kraju sve ispasti jedna velika prevara.
@MadZ we have arranged the shipping of a new unit (we are still investigating what happened), we will send you the new tracking number as soon as we get it by e-mail.
We're getting tape with our own logo, so we all can see if the box was opened before the package gets delivered.
+1Italijani su go..a veca od nas, na ebay-u niko ne zeli da im salje bilo sta, svuda su "Excluded".
Call quality, unfortunately, was one of the biggest sore spots for the OnePlus One. Volume in the earpiece is frustratingly weak and made callers on the other end sound muted, distant, and difficult to hear over even the most innocuous of ambient noise. Transmissions through the mic fared better, coming through more clearly, but still on the low side for volume. The headphone jack works fine for music, unlike in our initial hands on, but the OnePlus One couldn't route calls through a wired headset.
I also noticed a bug when it came to the phone's proximity sensor on calls. In most phones, taking the phone away from your face during or after a call will wake the screen from sleep. This almost never worked correctly in my tests, making it near impossible for me to end a call without fiddling with the Power button. Group texting worked fine with a number of iPhone and Android users, but the OnePlus one had some issues downloading pictures sent as MMS.
