A kad pokrenes direktno minerd bez .bat fajla jel ti ispada greska?
Tipa da ne moze port da otvori?
kad pokrenem direktno minered64 otvori se prozor i pise mi:HTTP request failed:failed connect to 127.0.0.1:9332
Samo u search-u kucaj %appdata%Kod mene nema "AppData..." Treba li da napravim te foldere ili? U novčaniku mi piše isto "Out of sync".
Kidence, hvl, zeznuh username... :]
To sada i meni izbacuje... Pffff
Ubacih conf fajl tu, pokrenem novčanik, međutim i dalje mi izbacuje da je "out of sync".
rpcuser=123
rpcpassword=1234567890qwertyuiop
rpcallowip=127.0.0.1
server=1
addnode=91.64.13.240
addnode=182.33.11.182:7788
addnode=113.116.201.74:7788
addnode=144.76.220.169:7788
addnode=77.20.120.102:7788
addnode=148.251.15.99:7788
addnode=54.201.249.50:7788
addnode=59.54.10.83:7788
addnode=149.241.29.95:7788
addnode=212.183.59.139:7788
addnode=223.18.194.128:7788
addnode=148.251.15.105:7788
addnode=83.215.164.206:7788
addnode=118.116.238.135:7788
addnode=31.41.219.110:7788
addnode=84.244.26.52:7788
addnode=144.76.185.239:7788
addnode=176.31.236.95:7788
addnode=14.118.110.69:7788
addnode=117.8.68.2:7788
addnode=186.212.61.43:7788
addnode=54.203.245.228:7788
addnode=183.69.196.80:7788
addnode=107.150.48.98:7788
addnode=109.205.247.161:7788
addnode=72.53.133.204:7788
addnode=117.81.217.11:7788
addnode=180.115.109.79:7788
addnode=93.183.175.25:7788
addnode=91.119.199.79:7788
addnode=50.152.178.147:7788
addnode=62.87.150.233:7788
addnode=23.92.80.37:7788
addnode=62.219.98.129:7788
addnode=113.120.128.107:7788
addnode=123.137.244.171:7788
addnode=148.251.3.83:7788
addnode=67.207.208.166:7788
addnode=114.94.15.137:7788
addnode=41.133.226.133:7788
addnode=213.21.14.174:7788
addnode=192.241.215.76:7788
addnode=219.136.252.5:7788
addnode=62.16.243.132:7788
addnode=62.210.162.235:7788
addnode=119.124.100.109:7788
addnode=46.9.148.112:7788
addnode=178.196.36.208:7788
addnode=37.143.201.89:7788
addnode=69.196.188.89:7788
addnode=188.32.108.230:7788
addnode=111.167.165.105:7788
addnode=90.188.237.17:7788
addnode=31.41.219.109:7788
addnode=198.211.124.181:7788
addnode=112.111.86.95:7788
addnode=118.124.54.189:7788
addnode=150.140.159.248:7788
addnode=162.243.235.192:7788
addnode=78.128.22.144:7788
addnode=182.32.195.170:7788
addnode=68.64.161.254:7788
addnode=199.188.178.180:7788
addnode=151.15.180.205:7788
addnode=121.230.85.79:7788
addnode=144.76.110.209:7788
addnode=141.48.30.99:7788
addnode=98.118.154.14:7788
addnode=87.113.166.62:7788
addnode=178.149.92.43:7788
addnode=113.2.235.63:7788
addnode=180.157.128.7:7788
Ja sam isto imao ovaj problem juce i nisam uspeo da ga resim nikako.
@Night
@ness
jel ste napravili bat fajl...ili ste samo pokrenuli minered64 direktno?
Koliko vidim vama nedostaje bat fajl za pokretanje...
Obratite paznju na razmake i na crtice....ako nisu na pravom mestu, onda samo trepne i ugasi se...isto se desava i ako se ne pozove pravi exe fajl....znaci minerd64 pa ostatak....
minerd64 -a qubit -o stratum+tcp://q2c.cpu-pool.net:3470 -u night_slayer.slayer -p radnik
probao sam i sa minerd64.exe i sa minerd64-generic i isto... jel ima neko predlog ??
da li postoje neki lokalni fajlovi u roamingu ili bilo gde koje minerd.exe napravi ? da li dolazi do promene u registrima ? hocu sve da izbrisem, reboot-ujem ruter i sve od pocetka...
Probaj da dodas jos jedan razmak posle qubit...
