»RSS Benchmark sajt
      Strana 6 od 7 PrvaPrva ... 234567 PoslednjaPoslednja
      Prikazani rezultati od 76 do 90 od ukupno 96
      Tema: Ltc & Btc Cold Wallet
      1. #76
        Member Avatar korisnika ledio
        Na forumu od
        Oct 2007
        Lokacija
        Novi Sad
        Poruka
        749
      2. Moja mašina
        • CPU: 3770 h2o @4.2
        • MoBo: Asus Formula V
        • RAM: 4x4gb Kingston 1600
        • VGA: 7950 CF on Komodo Swiftech
        • MON: Dell 2414P
        • HDD: Transcend 128gb + 2x1tb raid1
        • OPT: externi lg dvdrw
        • Case: lc power 971B - Infiltrator+CM V1000
        • SND: onboard
        • OS: 8.1 pro 64bit
        • TV: LG 42lw620
        • INET: DSL
        • Ostalo: g110,mx400,g930,g25 :) 7x12 push/pull radijatori
      3. Blago tebi
        "You have two ears and only one mouth for a reason"
      4. #77
        Member Avatar korisnika nesic1
        Na forumu od
        Aug 2008
        Lokacija
        Jagodina
        Poruka
        7.221
      5. Moja mašina
        • CPU: fx8350
        • MoBo: ga 971a ud3p
        • RAM: 8gb
        • VGA: porercolod dragon 480 8gb
        • MON: Samsung 940n
        • HDD: 1tb
        • OPT: koj ce mi
        • Case: Astec 2880W Server Power Supply Module IBM + raidmax 735W
      6. ja sam pricao dvojici najboljih drugova ali bili su u fazonu
        ostalima i ne pominjem
        Menjao nesic1 : 11.01.2014. u 03:06
      7. #78
        Member Avatar korisnika shoma
        Na forumu od
        Sep 2006
        Lokacija
        RS, Banja Luka
        Poruka
        3.335
      8. Moja mašina
        • CPU: Intel i5 6600K Cooler Master Hyper 212 Evo
        • MoBo: ASUS Z170-A
        • RAM: 8GB Kingston HyperX Fury 2666MHz
        • VGA: Sapphire Dual-X R9 280X OC Edition
        • MON: Asus VX239H
        • HDD: Samsung EVO 850 250GB, WD Caviar SATAII 250GB ; WD Blue 1TB; WD Green 1TB
        • Case: MS Black Widow; TT SPS-730M
        • SND: X-Fi Titanium / Genius SW-HF 5.1 5050
        • OS: Xubuntu 18.04 x64; W7 x64 Pro
        • LAP: HP 8470p on Kubuntu
        • INET: DSL
        • Ostalo: Logitech LX8, Xiaomi Mi 9T
      9. Ti tvoji drugari su bas.... ovce
        Probacu ovaj multibit, valjda mi nece novcici ispariti iz walleta
      10. #79
        Member
        Na forumu od
        Mar 2003
        Lokacija
        BG
        Poruka
        2.862
      11. Moja mašina
        • CPU: Intel I3 2100
        • MoBo: Z77A-G45 Intel® Z77 Chipset Based
        • RAM: 2x4GB Patriot 1333MHz
        • VGA: Asus 280X
        • MON: Benq G2420HDB
        • HDD: SSD 128GB M4 Deluxe WD 640GB Black 2xWD Green 1TB,Seagate 3TB
        • OPT: LG
        • Case: Chieftec CX-01B-B-B * LC Power 600
        • SND: Genius SW-HF5.1 6000 * G35
        • OS: Win7pro x64
        • LAP: Asus Fonepad 7 Tablet
        • INET: DSL
        • Ostalo: Benq W600 X360,PS3,Wii
      12. Ček, ove se priča o zaštiti i šiframa sa xxxxx karaktera i ti onda posle svega toga skineš neki random wallet
      13. #80
        Newcomers
        Na forumu od
        Dec 2013
        Lokacija
        beograd
        Poruka
        103
      14. Moja mašina
        • MoBo: g31mxp
        • VGA: Gigabyte R9 280x
        • SND: audiofile 2496/ krk rockit 6
      15. ja sam enkriptovao ltc wallet,primio novcice pa uradio backup...jel moram sad sve ponovo po redu ili mi i dalje znaci dat fajl?
      16. #81
        Member Avatar korisnika [SAJ]ber Kurajber
        Na forumu od
        Apr 2004
        Lokacija
        BGD, Zarkovo
        Poruka
        15.970
      17. Moja mašina
        • CPU: Ryzen 1700 @3.9GHz - Noctua NH-D15 SE
        • MoBo: Asrock x370 Killer SLI
        • RAM: 4x8GB G-skill Trident Z 3200MHz cl14 @3066 cl14
        • VGA: Asus Strix 1080TI OC
        • MON: 40" Samsung LE40C530
        • HDD: Samsung Evo 850 M.2 500GB, Samsung F3 1TB, Samsung F4 2TB
        • Case: Corsair 600T, Seasonic 760XP2
        • SND: Logitech G51 / Sennheiser HD 515
        • OS: Win 10 64bit
        • LAP: Asus E403N
        • TV: Samsung LE40C530, 49" Grundig VLE6621, Samsung 55NU7402
        • INET: Kablovska
        • Ostalo: G15, MX518.
      18. Nisam najbolje razumeo sta si zeleo da pitas ali taj dat fajl ti je sve, tu su ti novcici. Taj wallet.dat je tvoja adresa na kojoj su novcici.
        Ljudi, nemojte da vam je tesko da skidate blockchain i da cekate i 2 dana ako treba samo cuvajte dat i sifru za enkripciju kao oci u glavi!
        Onome kome ima svrhe objasnjavati, nema potrebe. Onome kome ima potrebe objasnjavati, nema svrhe jer su ograniceni - "Ja"
      19. #82
        Na forumu od
        Oct 2007
        Lokacija
        Novi Sad
        Poruka
        749
      20. Moja mašina
        • MON: Dell 2414P
        • SND: onboard
        • OS: 8.1 pro 64bit
        • TV: LG 42lw620
        • INET: DSL
      21. Kako sam ja razumeo,taj walet softver tebi samo daje private key (dat fajl sa sifrom) koji u kombinaciji sa public key (ltc/btc adresa) pruza pristup sredstvima koja su u blockchainu.Znaci,dovoljno je jednom napraviti svoju adresu na wallet softveru,enkriptovati je i bekapovati na flesh.Kada se prekopira private key (dat fajl) na flesh,izbrise se sa kompa i restartuje wallet i on napravi novi prazan dat fajl koji nema nikakve veze sa tvojim novcicima.Dalje kada zelis da koristis novcice upalis komp sinhronizujes blockchain,otkacis lan kabl stavis sa flesa svoj private key izprebacujes sta treba,vratis mu net on to odradi i ponovo izbrises svoj dat fajl sa kompa.
        Definitivno bi trebalo da se napravi step by step uputstvo kako se to koristi u stiki.Ima puno nejasnoca oko waleta,recimo kada imas puno isplata (preko 100) sa walleta moze doci do out of date graske i sta onda?
        PS Napominjem da je ovo samo moje shvatanje kako to radi,nisam probao,guglao sam mnogo i i dalje nisam ubedjen da je to sigurica
        Menjao ledio : 28.02.2014. u 08:43
      22. #83
        Newcomers
        Na forumu od
        Dec 2013
        Lokacija
        beograd
        Poruka
        103
      23. Moja mašina
        • MoBo: g31mxp
      24. Citat Citiram korisnika: [SAJ]ber Kurajber Pogledaj poruku
        pitao sam da li9 je u redu napraviti dat. fajl nakon transakcija,ili mora da se uradi pre bilo kakve uplate/isplate..
      25. #84
        Banned Avatar korisnika genijalcin@23
        Na forumu od
        Jun 2003
        Lokacija
        BGD
        Poruka
        4.429
      26. Moja mašina
        • CPU: C2D e8400 @ 4 GHz / ThermalRight IFX-14, 2 x Scythe Slip Stream 120mm 500 rpm
        • MoBo: Gigabyte EP45-DS3R
        • RAM: G.Skill 2 x 2 GB Black series 950 MHz 4-4-4-12 @1.9V
        • VGA: BBA ATI Rade 4890...i budjavi ATI drajveri...
        • MON: BenQ 24" G2420HD
        • HDD: WD 640 GB AAKS, Seagate 320 GB
        • OPT: Pioneer 215D SATA
        • Case: GA / LC Prophecy 750W
        • SND: Audigy 2 ZS / Tannoy E11 / Logitech Z5500
        • INET: Kablovska
        • Ostalo: HP Compaq NC6220 / Samsung Pocket Imager
      27. ledio je na dobrom tragu.
        skine se nočanik, zatim se skine blockchain ceo. zatim se novčanik enrkiptuje, i NAKON ENKRIPCIJE se wallet.dat može uštekati na flesh ili gde već.
        svi novčići koji stignu na tu adresu biće dostupni kada recimo izvadite wallet.dat iz naftalina, ali tek NAKON što se blockchain apdejtuje.
        također, možete i recimo iz wallet.dat-a da izvučete private key i da ga zapišete na papir, i da ga stavite u sef. kasnije uz pomoć tog key-a (koji je vezan za 1 adresu) možete da te novčiće imporujete gde god poželite.
        Menjao genijalcin@23 : 28.02.2014. u 09:23
      28. #85
        Na forumu od
        Oct 2007
        Lokacija
        Novi Sad
        Poruka
        749
      29. Moja mašina
        • MON: Dell 2414P
        • SND: onboard
        • OS: 8.1 pro 64bit
        • TV: LG 42lw620
        • INET: DSL
      30. Jel mozes molim te da odradis step by step na vise nacina sa pojasnjenjem zasto-pored kako,mislim da 90% ljudi nije bas nacisto kako se koristi i na koje nacine wallet
      31. #86
        Na forumu od
        Jun 2003
        Lokacija
        BGD
        Poruka
        4.429
      32. Moja mašina
        • INET: Kablovska
      33. moze, cim nadjem malo vremena, postaviću ovde uputstvu za novčanik, step-by-step.
        sa sve slikicama.
      34. #87
        Member
        Na forumu od
        Mar 2003
        Poruka
        830
        Ja hteo ,al kažu ljudi da im je bolji jedan walet sa šifrom od 50 karaktera
      35. #88
        Member Avatar korisnika Uros Novakovic
        Na forumu od
        Oct 2009
        Lokacija
        Podgorica
        Poruka
        6.763
      36. Moja mašina
        • CPU: i5 4460 @ 3.2Ghz / CM Hyper 212
        • MoBo: Asus B85-Plus
        • RAM: Kingston 16GB DDR3 @ 1333Mhz
        • VGA: Asus r9 270x Direct CU II Top
        • MON: 2 X Dell UP2516D
        • HDD: OS [] Samsung EVO 250 :: DATA [] 2x500GB Hitachi
        • OPT: Pioneer DVDRW
        • Case: Arc Midi / Seasonic 660 KM
        • SND: Xonar DG / Sanyo DCX6000 / Marantz PM5005 / BW DM602 S3
        • OS: Win 10 64bit
        • LAP: Inspiron 3537 & Crucial M4 & 8 GB RAM
        • TV: LG 65EF 950V
        • INET: Kablovska
        • Ostalo: Scythe Kaze Master 5,25" Zowie FK1 Kingston HyperX Cloud II Synology 215j
      37. @shku
        Dozvoljavas li da postavim uputstvo koje si mi na p.m poslao?
        [WoT] - Grinelwald
      38. #89
        Member
        Na forumu od
        Mar 2003
        Poruka
        830
        Ma naravno
      39. #90
        Na forumu od
        Oct 2009
        Lokacija
        Podgorica
        Poruka
        6.763
      40. Moja mašina
        • OS: Win 10 64bit
        • TV: LG 65EF 950V
        • INET: Kablovska
      41. by @shku
        Spoiler:
        Cold wallet ti je nacin cuvanja novcica koji nema veze sa internetom.
        Kad skines novcanik,on predstavlja softwer za generisanje adresa i cuvanje tih adresa na jednom mestu,mislim da ima ogranicenje od 20 ili 50 adresa.Znaci sve adrese su dostupne kroz jedan novcanik,jeedna ili 20, novcanik sabira sve novcice i prikazuje ti konacno stanje novcica na njima
        E sad zamisli da imas 2000 novcica,totalno je suludo cuvati na jednom mestu,tj jednom novcaniku.Da ne bi pravio 20 novacanika recimo po 100 novcica,napravis cold wallet.
        Sta to znaci
        Svaka adresa koju ti imas na novcaniku ima svoj private key
        npr imas adresu LQPky4LvX67kyeTWcdSdaQRKetAYTRQqQY
        NJen private key je 6upTZav5wShW8Wpign8pXRdPvLiCakSyRqainEJuN2wqpMmegt N
        ako ja u moj novcanik dodam private key pojavice mi se nova adresa u novcaniku sa svim novcicima na njoj i sabrace mi moje novcice sa novcicima sa ove adrese
        Kako se pravi cold walet na najsigurniji nacin
        1 Skines novcanik na usb
        2 Instaliras win bez kacenja na net
        3 Instaliras novcanik sa usb/a
        4 generises u novcaniku recimo 20 adresa
        5 uzmes od svake adrese private key, u konzoli u nnovcaniku kucas dumpprivkey "tvoja adresa"
        6 sacuvas sve adrese i njihove private keyeve recimo u notped ili ih odma istampas ako imas stampac ili neki drugi nacin ako ti pada na pamet
        7 Formatiras racunar i usb.
        Sve adrese sa njihovim keyevima rasporedis na jedno ili vise mesta,ja moje recimo drzim u sefu na papiru u banci i deo u jednom fajlu,mozes ih drzati po knjigama,kod roditelja,rodbine,zakopane u njivi ...
        Adrese mozes koristiti da i dalje na njih dobijas novcice iako nisu vise ni na jednom novcaniku
        E kad ti zatreba odredjena kolicina novcica samo uzmes recimo neku adresu na kojoj znas da imas lupam 50 novcica,ukucas privaye key u novcanik i ti novcici ti se pojave u novcaniku importprivkey "private key"
        Na ovom linku mozes pogledati kolko imas novcica na nekoj adresi
        http://block-explorer.com/
        Ako mislis da ti ovo treba prvo isprobaj i dobro prouci,mozes i sa nekim shit coinom koji ima malu vrednost, trebalo bi sve da radi isto.
        [WoT] - Grinelwald
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
