Ja jedino cega se plasim je cena, mislim da ce biti recimo kao s5
Receno je vec nekakav laser ili tako nesto za bolje nocne slike.
Have you ever used a camera which covers your subject in a pattern of red light? That's infrared autofocus doing its thing, and we reckon the G3's camera will use an IR sensor to bolster its performance in low light conditions.
The infrared beam is used to more accurately judge the distance of subjects to the lens, allowing for sharper focusing and a clearer picture. It works especially well in darker conditions, in which smartphone cameras traditionally struggle.
The processor measures how long it takes for infrared beams to bounce back off the subject, allowing it to calculate the distance and adjust the focus accordingly.
While we can't guarantee that the G3 actually has an IR autofocus sensor, past leaks, coupled with the clues in the latest video, make it seem quite likely.
Ne zna se koji je lepši - crni ili beli
Ovaj zlatni mi je :smash:
G3 će većini biti prvi pik, pogotovo jer će Z2 biti puno skuplji !
Mislim da nece nego ce biti ista cijena kao i sa G2 kad se pojavio.
kao, na primer, ko?Još kada bi digli ruke od stavljanja logoa na prednju stranu.
Nexus, iPhone.kao, na primer, ko?
