»RSS Benchmark sajt
      Strana 4 od 102 PrvaPrva 123456781454 ... PoslednjaPoslednja
      Prikazani rezultati od 46 do 60 od ukupno 1518
      Tema: AMD Radeon R9 270/270x tema
      1. #46
        Member Avatar korisnika fingon82
        Na forumu od
        May 2009
        Lokacija
        KV
        Poruka
        5.880
      2. Moja mašina
        • CPU: i5 4670k
        • MoBo: MSI Z87 G45 Gaming
        • RAM: 16GB DDR3
        • VGA: MSI 1050Ti Gaming
        • MON: Asus MX279H
        • HDD: SSD+HDD+HDD
        • Case: CM Trooper
        • OS: W10
        • INET: Kablovska
        • Ostalo: CM QuickFire XT Brown, Logitech G9x
      3. Ne, nije mi to za stalno, samo za test. Jedna karta je moja a druga kumova.
      4. #47
        Member
        Na forumu od
        Jan 2013
        Lokacija
        Beograd,Borca
        Poruka
        152
      5. Moja mašina
        • CPU: Intel Pentium Dual core G2020,box
        • MoBo: Asus P8H61M LE R2.0
        • RAM: 4GB Patriot Signature 1333mhz
        • VGA: Asus Geforce GT 630
        • MON: Asus VW221
        • HDD: Maxtor 120GB
        • OPT: Samsung
        • Case: Lc power LC-420H-12
        • SND: Xonar Dg+philips lx 3900sa+pioneer se-m290
        • OS: Win 7 x64
        • LAP: Hp compaqnx5000
        • TV: LG 32LF2510
        • INET: Kablovska
        • Ostalo: Steelseries Sensei Raw,Steelseries qck+ Logitech G105 mw3
      6. Onda ok
      7. #48
        Member Avatar korisnika hiSSteria
        Na forumu od
        Oct 2012
        Lokacija
        Sremska Mitrovica
        Poruka
        43
      8. Moja mašina
        • CPU: Intel(R) Core(TM) i5-3570K CPU + Thermaltake Contac 21 @ 4.1GHz
        • MoBo: Asus P8Z77-V LX2
        • RAM: 16Gb Patriot Intel Extreme Masters @1866MHz
        • VGA: ASUS Radeon R9 290 DirectCU II
        • MON: 27" Achieva Shimian QH2700-IPSMP DP LED IPS 2560x1440
        • HDD: SanDisk Extreme SSD 120Gb, WD320Gb, WD 500Gb
        • Case: Thermaltake Urban T81 Full Tower + Raidmax RX-835AP 835W
        • SND: ASUS Xonar DG + Genius SW-HF5.1 6000 200W + Logitech G930 7.1 + Sony MDR-RF810R Wireless Headphones
        • OS: Windows 8.1 Pro 64-bit Build 7601 Service Pack 1
        • LAP: HP Probook 5730s 17'
        • TV: Panasonic VIERA TX-L42U3E
        • INET: DSL
        • Ostalo: Logitech Wave Corded & k360 Wireless Keyboard, Logitech G400, Logitech F710 Wireless Controller
      9. Jel ima neko problema sa flickerom na Dual-X kartici (kartica uzeta kod popularne online prodavnici, na akciji)?
        Flicker je kratkotrajan, možda delić sekunde, gotovo neprimetan, kao neki trzaj kompletne slike na ekranu, i dešava se isključivo na desktopu
        (nisam još primetio da se u nekoj igri desilo), i to bez nekog pravila, nekad na 15 min, nekad na mnogo duže, čak i par sati prođe.
        Čak se u komentarima na ITsvetu javio neki dečko, koji kaže da je već tri kartice zamenio, takođe i kablove je probao menjati, OS-ove, monitore, i uvek isto.
        Problem u drajverima možda, ili falična serija kartica (da to nije razlog zašto su tako jeftino išle na akciji)?
        Mislim, ne potresa me to previše, imam garanciju, naravno, ali opet iritira...
        Takođe, primetio sam neke čudne boje pri promeni rezolucije u fullscreen-u. Za momenat se pojave neke ljubičaste fleke i tačke, ili kompletno crven ekran.
        Opet, kažem, to je delić sekunde, gotovo neprimetno. Osim toga, kartica radi perfektno. Ne znam dal brinuti zbog tih pojava...
      10. #49
        Member Avatar korisnika GoranM
        Na forumu od
        Dec 2001
        Lokacija
        Srbija
        Poruka
        8.184
      11. Moja mašina
        • CPU: i5 4670K@4.2Ghz/NH-D14....3570K@default/BOX
        • MoBo: ASUS Z87-A....GA-Z77X-UD3H
        • RAM: 2x8GB Kingston DDR3 1600....2x8GB Kingston DDR3 1600
        • VGA: Gigabyte GTX 1070 G1 SLI ....Dell Quadro K5000
        • MON: 34" 1440p ...... 27" 1080p
        • HDD: SSD 120GB + HDD 1,5TB+2TB....250GB SSD, 1TB WD Black
        • OPT: LG DVD RW SATA.... LG DVD RW SATA
        • Case: CM Cosmos 1000 + LC 1000 Legion X2 v2.3....Chieftech 500W
        • SND: Logitech Z906 + DTS Connect "onboard"....on board
        • OS: Win 7 64.... Win 7 64 Pro
        • LAP: Fujitsu Pi 3560
        • TV: 32LD465
        • INET: Kablovska
        • Ostalo: Logitech G105+G402....Logitech KB250+MX512
      12. Septembra 2012 imao sam Sapphire 7950 Flex Dual-X i iste je brljotine imala. Resio sam ih vrlo jednostavno, vratio sam karticu, uzeo pare i kupio drugu. Iste probleme je jedan drug primetio sa jos 4-5 kartica iz te "serije". posle je stizalo jos 7950 Dual-X kartica i nisu imale probleme. Doticna firma jeste poznata po prodaji robe sumnjive ispravnosti.
      13. #50
        Na forumu od
        May 2009
        Lokacija
        KV
        Poruka
        5.880
      14. Moja mašina
        • CPU: i5 4670k
        • RAM: 16GB DDR3
        • MON: Asus MX279H
        • HDD: SSD+HDD+HDD
        • Case: CM Trooper
        • OS: W10
        • INET: Kablovska
      15. I ja sam taj flicker primetio, desi se po nekad, na pola sata-sat, obicno kad svitch-ujem izmedju programa/prozora, pretpostavljam da je do drajvera. Sto se boja tice, nikad se nisu menjale, gubile ili tome slicno.
      16. #51
        Member
        Na forumu od
        Jul 2012
        Poruka
        43
      17. Moja mašina
        • CPU: 4670K
        • MoBo: Gryphon Z87
        • RAM: 8 GB HyperX
        • VGA: 270X
        • MON: BenQ G2250
        • HDD: WD 1TB
        • OS: Windows 8.1
      18. Daj boze da je do drajvera , treba u sredu da mi stigne pa javljam utiske
      19. #52
        Na forumu od
        Dec 2001
        Lokacija
        Srbija
        Poruka
        8.184
      20. Moja mašina
        • TV: 32LD465
        • INET: Kablovska
      21. Problem sa treperenjem ekrana, citiram:
        Ko ima problema sa treperenjem ekrana sa novim ili starim drajverima a koristi AfterBurner, neka uradi sledece.
        C:\Program Files (x86)\MSI Afterburner\MSIAfterburner.cfg (standardna lokacija fajla, moze da varira od korisnika do korisnika)
        UnofficialOverclockingEULA = I
        UnofficialOverclockingMode = 2 da se promeni umesto 1 u 2
        AccessibilityCheckingPeriod = 0
        UnifiedMemoryUsageMonitoring = 1
        1 ili 2 menja ULPS podesavanja.
        Ukoliko se postavi UnofficialOverclockingMode na 1, tada je "Power Play" ukljucen i dozvoljava da GPU klok padne kada se graficka malo koristi, i to upravo stvara prloblem sa treperenjem ekrana.
        Ukoliko se postavi UnofficialOverclockingMode na 2, tada AF radi premoscavanje i gasi Power play ( ili ti ULPS-Ultra Low Power State) , i tada GPU klok ne pada , vec radi na zadatim podesavanjima sve vreme, cak i kada je u stanju mirovanja (IDLE)
        Ovo mora da se uradi nezavisno od podesavanja za ULPS u registru
      22. #53
        Member
        Na forumu od
        Feb 2013
        Poruka
        153
      23. Moja mašina
        • CPU: 7600k Noctua NH-U14S
        • MoBo: Maximus IX hero
        • RAM: G.skill V 3000Mhz cl15
        • VGA: Strix GTX 1070 OC
        • MON: Dell U2414H
        • HDD: 850evo Intel 330 WD black + blue
        • OPT: Samsung DVDRW
        • Case: Fractal design R4
        • SND: integrisana
        • OS: Win 10 osx 10.12.5
        • Ostalo: Seasonic platinum 750w
      24. Pozdrav svima, ja sam postovao na ITSvetu kako je napisao gore hiSSteria. Moram da napomenem da moja kartica nije Sapphire nego Asus OC verzija a postovao sam tamo,jer je bilo dosta ljudi koji su ostavili svoje komantare. Znaci posto i Sapphire ima iste simptome mozemo reci da je do drajvera Ili mozda do samog chipa u sta sumnjam. Ja sam problem resio sa programom Lucid virtu MVP 2.0 zadnja beta verzija. Za one koji ne znaju sta je, opcija u Biosu otkljucava mogucnost zajednickog rada graficke i integrisane graficke a program Lucid Virtu im omogucava da se ispomazu na pravi nacin. U mom slucaju to su Intel HD4000 i Asus R9 X270X. Opcija Virtual VSinc resava problem sa treperenjem ekrana. U mom slucaju je to ok sto se tice win 8.1 ali posto koristim i osx 10.9 tu imam problem, jer se osx ne moze podici sa ukljucenom opcijom za Lucid Virtu u samom biosu...
      25. #54
        Na forumu od
        Oct 2012
        Lokacija
        Sremska Mitrovica
        Poruka
        43
      26. Moja mašina
        • INET: DSL
      27. U vezi onog pojavljivanja čudnih boja pri promeni rezolucije, ili alt-tabovanju, snimio sam klip mobilnim, možda ću tako najbolje uspeti da objasnim šta se dešava.
        http://sdrv.ms/1iIeBqr
        Moram napomenuti da ovako mnogo dramatičnije izgleda nego uživo.
        E sad, ako je flicker do drajvera, do čega li je ovo, ja ne znam... Elem, nije me mrzelo, uradio sam screencapture, frejm po frejm, tu negde oko 14-15 sekunde sa klipa.
        To ovako ide:
        Click image for larger version.
ID:	127280Click image for larger version.
ID:	127281Click image for larger version.
ID:	127282Click image for larger version.
ID:	127283Click image for larger version.
        E sad, pošto je limit 5 slika po postu, samo od petog zamislite da idu isti frejmovi, ali unazad. Peti frejm je posebno veseo, pink noise!
        Da je ovo normalno, baš i nije... Da li se ovo još nekom dešava?
      28. #55
        Member
        Na forumu od
        Feb 2013
        Poruka
        153
      29. Moja mašina
        • MON: Dell U2414H
        • SND: integrisana
      30. Taj pink noise je sigurno do drajvera, kada bolje razmislim, kartica je novijeg datuma pa shodno tome toliko toga primecujemo, jer i sami ocekujemo da azdaja mora da bude savrsena. Bojim se da cemo malo pricekati na to savrsenstvo U mom slucaju sve tri kartice su imale taj pink noise ali ne toliko izrazen kao kod tebe. Prva je bila sa flikerom, noisom i pravila je neku vrstu duhova, ona je bila defektna 100%. Ali druge dve su potpuno identicne samo problem sa flikom i blagim pink noisom koji se lako koriguje. Probacu sutra ovu varijantu koju je GoranM naveo, mada mu to dodje kao tvikovanje, sto bas i ne volim da radim.
      31. #56
        Na forumu od
        May 2009
        Lokacija
        KV
        Poruka
        5.880
      32. Moja mašina
        • CPU: i5 4670k
        • RAM: 16GB DDR3
        • MON: Asus MX279H
        • HDD: SSD+HDD+HDD
        • Case: CM Trooper
        • OS: W10
        • INET: Kablovska
      33. WTF?? Sad ste me zbunili koji od vas ima Asusa a koji Safir
        na slikama meni lose izgleda, da je meni tako bilo vratio bih u roku od odmah. A koji su vam drajveri instalirani, beta 8 ili oni sto idu uz grafiku?
      34. #57
        Member
        Na forumu od
        Jul 2012
        Poruka
        43
      35. Moja mašina
        • CPU: 4670K
        • MoBo: Gryphon Z87
        • RAM: 8 GB HyperX
        • VGA: 270X
        • MON: BenQ G2250
        • HDD: WD 1TB
        • OS: Windows 8.1
      36. Citat Citiram korisnika: fingon82 Pogledaj poruku
        hissteria ima Sapphire , otaku ASUS
      37. #58
        Na forumu od
        Oct 2012
        Lokacija
        Sremska Mitrovica
        Poruka
        43
      38. Moja mašina
        • INET: DSL
      39. Dual-X je kod mene.
        Inače, drajveri su 13.11 Beta 8. Kontam, čim se to dešava sa svim karticama, čak i različitih proizvođača, mora biti do drajvera. Sačekaću još malo, ne bi trebalo dugo do sledeće bete, a dotle pogledati po netu...
        Mada, zasad nisam ništa našao da se ljudi žale na ove probleme, što me čudi...
      40. #59
        Banned
        Na forumu od
        Mar 2013
        Lokacija
        Beograd / Dorcol
        Poruka
        415
      41. Moja mašina
        • CPU: i5 4690k / i7 4790k
        • MoBo: asus maximus Vi hero / asus maximus vii formula
        • RAM: 2x4gb 2400mhz/ 2x8gb
        • VGA: msi gtx 670/ asus gtx 680 dc2
        • MON: Benq gl2450 / Dell s2340L hdmi
        • HDD: kingstone 128gb ssd + 1tb 7200 wd blue
        • OPT: Nema
        • Case: Chasar MK-1/ Cooler master storm stryker
        • OS: Windows 8.1
        • LAP: asus g53sx
        • TV: Samsung UE40ES5500 LED
        • Ostalo: LG G2
      42. Citat Citiram korisnika: fingon82 Pogledaj poruku
        Svi znamo šta je u pitanju, rebrand 78xx serije sa malo izmena, ali je bolje da serija ima svoju temu a da se o njoj ne piše u 78xx temi zbog preglednosti.
        270 obična još nije dostupna, ali jeste 270x (poboljšana 7870). Dobar test referentnog modela
        http://www.techpowerup.com/reviews/AMD/R9_270X/
        Danas mi je dopala šaka ova karta, Sapphire R9 270x Dual-X OC:
        http://www.sapphiretech.com/presenta...pid=2037&lid=1
        Atačment 126829
        drajveri su još beta koliko mogu da vidim, igrao sam se malo BF3 i SC2, kao i Skyrim. Nije prešla 63C sa 40% venta, meni lično skoro nečujna. Ako neko hoće da provrtim neki test, nek javi koji. Večeras ću da se igram sa OC-om da vidim koliko može, dok izvrtim testove. ASIC 75%
        Jedno pitanje ? Jel njoj zakljucan volt. ili treba tek da izadje msi afterbruner da prepozna nju?
      43. #60
        Member Avatar korisnika Bobi4ever
        Na forumu od
        Aug 2011
        Lokacija
        Beli grad
        Poruka
        990
      44. Moja mašina
        • CPU: Phenom II X6 1605T @ 3.7Ghz NH-D14
        • MoBo: Asus M4A88T-V EVO
        • RAM: Kingston HyperX 2x2GB DDR3 1600Mhz
        • VGA: ASUS HD7870-DC2-2GD5-V2 @1150/5200MHz
        • MON: Samsung LE32D550
        • HDD: WD Caviar blue 320GB 7k 16MB
        • OPT: Ko to jos koristi?
        • Case: NZXT Hades Inferno modded, TT Smart M850W
        • SND: Altec Lansing 621, Medusa NX
        • OS: BIOS :P
        • INET: Kablovska
        • Ostalo: A4Tech x7 , Roccat Sense, SpeedLink DarkSky, Logitech C270 iPod 3 8GB.
      45. Citat Citiram korisnika: hiSSteria Pogledaj poruku
        To ovako ide:
        Druze karta ti je ispravna, to je do drajvera, nemoj da brines.
        Meni se to desava sa 7770 kada igram recimo FM 12 i onda alt-tabujem u Windows. Nije situacija preko celog ekrana kao kod tebe vec samo u delu gde je taskbar i to se desi samo tad i na sekundu bukvalno.
        Kod tebe je hardcore, preko celog ekrana. Verujem da koristimo razlicite drajvere, pa je kod tebe situacija (preko celog ekrana) izrazenija nego kod mene (samo taskbar kad se alt-tabuje), a moze biti i da je u Win 8.1 izrazenije nego u Win 7 (kod mene).
        Uglavnom, karta je ispravna, probaj sa nekim drugim drajverom ako ti bas bode oci ili jednostavno volis da alt-tabujes tokom igranja.
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
