I sta bi sa prezentacijom i sa ovim telefonom?
Posto su svi sajtovi najavili za 4-ti Jul??
Ovo samo i jedino Sony moze ovako da usere. Znaci ne verujem. Pojavice im se telefon... kad ostali vec presisaju taj hardware kao i obicno.
I think the leaked images don't do it justice. It's like a smaller, but slightly thicker version of the Z Ultra. I think the aluminum frame makes it look much more premium than the Z. I've seen the press image, and I'm already throwing my money and my Z at the screen so I can trade for it I know it does look similar to the Z, but definitely not worse.
IMO, Honami will not be disappointing in the camera aspect. This product is being developed in collaboration with Sony's Imaging department (Cybershot, Alpha's, etc), so they'll load everything that they've got onto Honami.
It may be wedge shape,still flat on the back
So Honami has a nice pixel size advantage over the Lumia 1020
1.7 micron vs 1.12
Yea and honami sensor is better in low light even when it has the same pixel size as lumia 1020
Ovo je tacno ali samo u slucaju da i1 ima senzor koji su insajderi potvrdili, znaci 2/3'' a to je ista velicina kao iz 1020 (1/1.5'').
As ramu mentioned, I saw samples from Honami's camera (with beta software) on 4 ISO settings (100, 400, 800, 1600), before anything else, and I was given the green light to share my thoughts over it. From this point I must say the camera is promising, I can only confirm the following camera specs based on the EXIF data included: 20MP (5248x3936pixels), F2 lens, 5mm focal length. JPEG engine has less aggressive NR than XZ prior to the latter receiving a ported camera driver.
now based on the early sample image that I saw, full res output @ISO100 reveals lots of detail comparable (take note, not better or anything superior) with the old RX100 with minimal loss of detail at ISO400, though at ISO800 and 1600 the image is flooded with Luminance and chroma noise with visible color blotches plaguing the image but someof the small details that I've seen visible with the ISO400 sample are preserved, bokeh effect is virtually similar to 1020's. as you guys would know, I posted my thoughts on Honami's ISO1600 performance relative to RX100's on the previous page before I got my hands on the sample, but now I have to say that RX100 @ISO1600+ is virtually untouchable at any rate. I can't comment on how it fares against 1020, but think they'll be neck and neck when comparing their full resolution outputs. one more thing, the samples exhibited some corners softening but barrel distortion is handled pretty well (could be due to image processor just like how it's usually corrected on compact cameras).
Now compared with all smartphone cameras available 808/1020s aside, Honami's camera performance will wipe the competition including S4 zoom and the old Galaxy Camera IMHO. but I advice we keep our expectations low, 1020's biggest weapon is the oversampling, and I think Sony has nothing to counter against that, so the competition boils down on which camera delivers better per pixel detail at full resolution. and as of this moment, I'm not sure who's got the upper hand to be honest. besides the sample images that I've seen with my eyes are based on pre production software, so we can't rule out the possibility that the JPEG engine will be better.
now the question is can my post be trusted?, I'll leave that to you guys, as I don't have the means to prove the legibility of my post unless I'll be given again the greenlight to show you what I've seen and see things for yourself
SteadyShot is the trademarked name of the integrated image stabilisation technologies used in Sony video camcorders and DSLR cameras. Different versions of these technologies are known as Super SteadyShot (SSS), SteadyShot INSIDE (SSI) and Optical SteadyShot (OSS) in Sonys Cyber-shot and Alpha product families.
