MileInc
Cenjen
Imam problem sa SBB internetom preko mikrotika.
Dva interneta , dva glavna racunara i WiFi router su spojeni na miktorik, cilj je da koristim internet u load balancing failover modu. Sam balancing nije preterano bitan posto su oba interneta zadovoljavajuce brzine 10/1 i 16/1.
Pokusavam vec nekoliko dana da namestim bezuspesno.
Sa mikrotika preko SBB linka modu da pngam samo njihov gateway dok recimo 8.8.8.8 nece.
Probao sam da isljucim ADSL i podesim da SBB DHCP Client automatski postavi sve al onda mogu da otvorim samo www.sbb.rs i insta vise. :wall:
Nadam se da ce neko uociti pocetnicku gresku u mojim podesavanjima.
Internet preko ADSL-a lepo radi, ima samo zadrsku dok ne pokupi DNS podatke, dali to moze da se ubrza?
Podesavanja su sledeca:
Kod:
# may/05/2013 18:52:29 by RouterOS 5.25
/interface ethernet
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 mac-address=D4::C0 master-port=none mtu=1400 name=SBB speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 mac-address=D4::C1 master-port=none mtu=1400 name="wan2 link" speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 mac-address=D4::C2 master-port=ether5 mtu=1400 name=ether3 speed=1Gbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 mac-address=D4::C3 master-port=ether5 mtu=1400 name=ether4 speed=1Gbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 mac-address=D4::C4 master-port=none mtu=1400 name=ether5 speed=1Gbps
/ip pool
add name=pool1 ranges=192.168.1.9-192.168.1.99
/ip dhcp-server
add address-pool=pool1 authoritative=yes bootp-support=static disabled=no interface=ether5 lease-time=3d name=server1
/interface pppoe-client
add ac-name="" add-default-route=no allow=pap,chap,mschap1,mschap2 dial-on-demand=no disabled=no interface="wan2 link" max-mru=1400 max-mtu=1400 mrru=disabled name=ADSL password=*** profile=default-encryption service-name="" use-peer-dns=no user=***@pttnet
/ip address
add address=192.168.1.1/24 disabled=no interface=ether5 network=192.168.1.0
/ip dhcp-client
add add-default-route=no disabled=no interface=SBB use-peer-dns=no use-peer-ntp=yes
/ip dns
set allow-remote-requests=no cache-max-ttl=1w cache-size=4096KiB max-udp-packet-size=512 servers=8.8.4.4,8.8.8.8,4.2.2.1,4.2.2.5
/ip firewall mangle
add action=mark-connection chain=input disabled=no in-interface=ADSL new-connection-mark=adsl_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=SBB new-connection-mark=sbb_conn passthrough=yes
add action=mark-routing chain=output connection-mark=adsl_conn disabled=no new-routing-mark=to_ADSL passthrough=yes
add action=mark-routing chain=output connection-mark=sbb_conn disabled=no new-routing-mark=to_SBB passthrough=yes
add action=accept chain=prerouting disabled=no dst-address=192.168.1.0/24 in-interface=ether5
add action=mark-connection chain=prerouting comment=adsl disabled=no dst-address-type=!local in-interface=ether5 new-connection-mark=adsl_conn passthrough=yes per-connection-classifier=both-addresses:2/0
add action=mark-connection chain=prerouting comment=sbb disabled=no dst-address-type=!local in-interface=ether5 new-connection-mark=sbb_conn passthrough=yes per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=adsl_conn disabled=no in-interface=ether5 new-routing-mark=to_ADSL passthrough=yes
add action=mark-routing chain=prerouting connection-mark=sbb_conn disabled=no in-interface=ether5 new-routing-mark=to_SBB passthrough=yes
/ip firewall nat
add action=masquerade chain=srcnat disabled=no out-interface=SBB
add action=masquerade chain=srcnat disabled=no out-interface=ADSL
/ip route
add check-gateway=ping disabled=no dst-address=0.0.0.0/0 gateway=ADSL routing-mark=to_ADSL
add check-gateway=ping disabled=no dst-address=0.0.0.0/0 gateway=SBB routing-mark=to_SBB
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=ADSL
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=SBB
/system clock
set time-zone-name=Europe/Belgrade
/system ntp client
set enabled=yes mode=unicast primary-ntp=217.24.24.144 secondary-ntp=0.0.0.0
