O kom tacno konektoru pricaju? To je ovaj od 590mm (600mm). Da li je problem sa kablom, sa jednim ili oba konektora? Koji pravi problem, onaj u napajanju i u plocu? Da li je problem mozda do konektora ploce? Zasto se to desava? Sta je on mrdao i pritiskao rukom, konektor na napajanju ili u plocu sto je uboden? Problem se ispoljio zbog loseg pojedinacnog konektora ili su svi takvi...Moving on to the voltage readings, we find clear evidence of ATX connector issues. I would press down on it, and they would bounce around like a grasshopper on speed. Now, I'll play around with these connectors to get more stable readings, sure. But those readings have to stick when I take my hand away, and in this case it wasn't happening. I got 1.5%, 0.6%, and 1.1% this time.
Napomena: This feature currently requires accessing the site using the built-in Safari browser.
