3DMark (2013)
TheBear
http://www.futuremark.com/benchmarks/3dmark
The new 3DMark (2013) includes everything you need to benchmark your hardware.
With three all new tests you can bench everything from smartphones and tablets, to notebooks and home PCs, to the latest high-end, multi-GPU gaming desktops. And it's not just for Windows. With 3DMark you can compare your scores with Android and iOS devices too. It's the most powerful and flexible benchmark we've ever created.
The latest version of the world's most popular benchmark is simply called 3DMark to reflect its all-round versatility. Not only is this 3DMark the first in the series to offer cross-platform comparisons, it is also the first to test different Direct3D feature levels within one application.
DOWNLOAD:
http://www.techpowerup.com/downloads/2201/3DMark_v1.00.html
Asus GTX 680 @ 1200/1727 / i7 920 @4.0GHz
    611.3 KB · Pregleda: 194
GTX 680 dcIITop
Proc @4300 MHz
Memara @1600 MHz (ne znam zašto je vidi kao 667)
^dual channel.
Ne razumem se u ove testove ali mi se cini da je ovaj 3d mark veliko djubre.
Evo skorova, sve iz profila na tim klokovima, gpu drajveri matori 12.4.. a u pozadini wf sa 10 tabova, skype, aimp3, utorrent itd, ako utice ovo uopste.
    301.1 KB · Pregleda: 128
Bezobrazan onaj treći demo :p
    354.7 KB · Pregleda: 148
Evo jedna punokrvna AMD masina:
E zaebah se, navika od ddr2 memorije :D Ma program je veliko djubre, pogledaj sta mi pise za manufacturing process :d :d
Hehe.. AMD ruleZ, savladali 0 nm proces. I mene si zahebao - nije dual channel, nego double data rate:p.
Evo i mog rezultata...
    54.1 KB · Pregleda: 104
Evo i mog reza.
7950 1100MHz GPU, 1500Mhz memorija.
Nategnuta HD 7950 @ 1260/1790 MHz :)
Inace ja gledam samo poslednji Fire Strike test, ovo ostalo, prvi test je vise test procesora nego graficke, drugi je ok, al Fire Strike pokazuje pravu snagu DX11 karti.
Inace u poslednjem Fire Strike testu odlicno je skaliranje sa klokom, bar kod AMD-a, koliko procenata klokujes toliko se poveca GPU skor.
    528.9 KB · Pregleda: 118
Jel se to meni cini il FX-evi u ovom benchu fino pokazuju zube?
FX ovi daju znatno losi skor od intela :(
Pogledajte ovaj skor grafa je na manjim taktovima nego kod kolege THE bear a daje veci skor.
    895.9 KB · Pregleda: 84
Pa ja moj proc poredim sa 2500k i 3570k i medju tim takmacima se dobro pokazao. 2700k je drugi padez i nisu uopste za poredjenje
Ovo je djubre, pa moja konf baca bolji skor od medvedove u prvom testu a i onaj poslednji je zahtevan na neki vestacki nacin, sve ide u nekoliko fps a graficki izgleda kao bilo koja dx9 igra napucana efektima :d
6850 @ 840/1075
AMD FX-8350 @ 4 916 mhz
memorija 1600 mhz,iako ovde pise 1333 mhz...
    557.8 KB · Pregleda: 81
Lol ovo veze sa zivotom nema :D. Sa slabijom grafikom imas jaci gpu skor (skoro 100000 u prvom testu). Djubre od bencha
Ja samo gledam Fire Strike. Ovi drugi me ne zanimaju.
A i imam dva komada od te grafe, ako ti je to promaklo. A ovo sve pišem, pod uslovom da si na mene mislio.
Ma ok ali svi testovi uticu na konacan skor, sto automatski ovaj 3dmark baca na djubriste. Neki fiks mora uskoro da bude
Ne kapiram, kako misliš da svi utiču na konačan skor? Svaki test ima svoj skor.
Na kraju imas combined skor.
Da, ali to je onaj zadnji dio (combined) iz Fire Strike benchmark-a.
Ljudi nije test djubre, taj prvi test i nije predvidjen da se testira high end pc !
Fire Strike
For high performance Windows gaming PCs
Cloud Gate
For Windows notebooks and home PCs
Ice Storm
For Android, iOS and Windows mobile devices
Znaci samo Fire Strike je nama ovde bitan, nebitno dal se nekome svidja kako izgleda ili ne, on koristi DX11 i najnapredniji je benchmark koji je Futuremark napravio.
Ja sam to odmah primijetio kad sam upalio benchmark. Ne znam kako ljudi to nisu vidjeli. Ali, najviše 'kolje' onaj demo prije Fire Strike-a. :d
