»RSS Benchmark sajt
      Strana 9 od 897 PrvaPrva ... 56789101112131959109509 ... PoslednjaPoslednja
      Prikazani rezultati od 121 do 135 od ukupno 13448
      Tema: Bitcoin [BTC] (SHA-256)
      1. #121
        Member Avatar korisnika Rapture
        Na forumu od
        Aug 2008
        Lokacija
        Kg
        Poruka
        4.489
        Mirza na koliko cistis karte?
        Covid 19 - barely legal
      2. #122
        Member Avatar korisnika mirza82
        Na forumu od
        Oct 2007
        Lokacija
        Cuprija
        Poruka
        4.684
      3. Moja mašina
        • CPU: F82
        • MoBo: MPOWER
        • Case: M4
        • SND: AKRAPOVIC
        • INET: Bez interneta
      4. Nisam skoro, moraću ovih dana.
        "Nije znanje znanje znati, vec je znanje znanje dati!"
      5. #123
        Member Avatar korisnika ledio
        Na forumu od
        Oct 2007
        Lokacija
        Novi Sad
        Poruka
        749
      6. Moja mašina
        • CPU: 3770 h2o @4.2
        • MoBo: Asus Formula V
        • RAM: 4x4gb Kingston 1600
        • VGA: 7950 CF on Komodo Swiftech
        • MON: Dell 2414P
        • HDD: Transcend 128gb + 2x1tb raid1
        • OPT: externi lg dvdrw
        • Case: lc power 971B - Infiltrator+CM V1000
        • SND: onboard
        • OS: 8.1 pro 64bit
        • TV: LG 42lw620
        • INET: DSL
        • Ostalo: g110,mx400,g930,g25 :) 7x12 push/pull radijatori
      7. Kako konfigurisati vise racunara da rudare na istom nalogu?
        "You have two ears and only one mouth for a reason"
      8. #124
        Member Avatar korisnika DariusIII
        Na forumu od
        Dec 2006
        Lokacija
        Kovačica
        Poruka
        3.249
      9. Moja mašina
        • CPU: AMD Ryzen 5 2600 + Arctic Freezer 34 eSports
        • MoBo: MSI X470 Gaming Plus
        • RAM: 16GB DDR4 3200 MHz Ballistix SportLT
        • VGA: Saphire Radeon RX580 Pulse 8GB
        • MON: Dell SE2419HR
        • HDD: Silicon Power 512Gb m2.nvme + 3Tb Seagate Barracuda + 2TB WD
        • OPT: Lite-On iHAS122
        • Case: Bitfenix Merc Alpha + LCPower LC6650GP3 v2.3 650W
        • OS: Windows 10 Pro x64
        • TV: Samsung UE48H5273SSXZG
        • INET: DSL
        • Ostalo: Redragon K586-pro Brahma mechanical keyboard, Razer Naga Trinity , MGE Nova 1100VA UPS Xiaomi Mi A2
      10. Svakom računaru dodeliš jednog workera. Svi workeri su vezani za tvoj nalog.
        "Freedom is the right of all sentient beings"
      11. #125
        Member Avatar korisnika Chabex
        Na forumu od
        Nov 2006
        Lokacija
        Novi Sad
        Poruka
        1.966
      12. Moja mašina
        • CPU: Phenom II X4 980 4GHz, NB2600 - Thermalright HR2 Macho
        • MoBo: Asus M5A97 Pro
        • RAM: GSkill Ripjaws GBRL 2x4GB 1600 CL9@CL8
        • VGA: Sapphire Nitro 380X
        • MON: Samsung S23B350HS
        • HDD: Samsung F3 1TB, WD Green 1TB , Seagate 250GB Sata
        • OPT: Pioneer DVR-215DBK
        • Case: CM Centurion 590/ CM V850
        • SND: Audigy 2 / B&W DM602 / Musical Fidelity A1
        • OS: Win7 64
        • TV: Panasonic plazma 42S30E
        • INET: DSL
        • Ostalo: tastatura od 300 din za lupanje kada se iznerviram...
      13. Citat Citiram korisnika: mirza82 Pogledaj poruku
        Tri masine, jedna je moja iz potpisa koja radi 22/7.
        Druga je 4x6770 24/7. Na 850mzh 190Mh/s 1037mv.
        Treca je 2x7950 24/7. Na 1100mhz 540Mh/s 1037mv.
        Ukupno 2400Mh/s
        Dnevna zarada je 0.9btc (do skora 1btc ali porastao je dif).
        Lepu mašineriju imaš . Jedno (možda glupo) pitanje, jesi 6770-ke stavio na 2 napajanja ili na 1 jako? U stvari 1 napajanje i nema 4x6-pin konektora pa pretpostavljam da su na 2 napajanja..
        I da li neko zna, koliko mhs-a daje recimo 7850? U onoj tabeli nema za sve novije samo za 7970 i još neku slabiju...razmišljam koja je najisplativija od novijih.
      14. #126
        Member Avatar korisnika demios
        Na forumu od
        Dec 2003
        Lokacija
        Dortjol
        Poruka
        5.067
      15. Moja mašina
        • CPU: i7 4790K @4800MHz bez IHS-a, na vodi
        • MoBo: Asus Z87I Pro
        • RAM: 2x8GB Team Group Vulcan 2400MHz CL11
        • VGA: Gigabyte GTX 980ti G1 na vodi
        • MON: Acer 29" 21:9 IPS
        • HDD: Samsung 500GB 850 EVO + 2TB Seagate
        • Case: Bitfenix Phenom + Silverstone Strider Plus 1000W
        • SND: Delta integrale
        • OS: Win 10
        • INET: Kablovska
      16. mozesh i sam otprilike izrachunati klok za klok.
        koliko % manje shejdera ima u odnosu na 7870, toliko ce ti dati manje hash-a, i josh ako je nizi klok....ja bih rekao na 1100 kloku oko 360 mhash/s
        shto se tiche napajajna za 4x6770, drugar nikola koristi neke TT litepower 700w, a ja sam vozio na ocz zt 650w...dva konektora regularno, dva na molexe...isto tako vozim an istom napajanju dve 7950 bez problema...
        Menjao demios : 20.09.2012. u 13:06
      17. #127
        Na forumu od
        Oct 2007
        Lokacija
        Cuprija
        Poruka
        4.684
      18. Moja mašina
        • CPU: F82
        • MoBo: MPOWER
        • Case: M4
        • SND: AKRAPOVIC
      19. Citat Citiram korisnika: Chabex Pogledaj poruku
        ThermalTake 700w, sve cetri su na njega.
        7850 po tabeli daje 330mh/s na 1100mhz, ne pise na kom naponu radi.
      20. #128
        Na forumu od
        Aug 2008
        Lokacija
        Kg
        Poruka
        4.489
        Jel mogu za bitcoin da se stave 7950 + 7870? ili mora cf...
      21. #129
        Na forumu od
        Nov 2006
        Lokacija
        Novi Sad
        Poruka
        1.966
      22. Moja mašina
        • OS: Win7 64
        • INET: DSL
      23. E tako sam i ja mislio otprilike da je oko 350 al reko da proverim... otprilike računam šta bi bilo najisplativije . Al nezgodno je za posebnu mašinu, onda bih morao i dodatni hardver a to je skupo.
        @Rapture - e to je i mene zanimalo
        edit- a jel ima neka banka koja ne naplaćuje održavanje tekućeg računa ?
        Menjao Paradigma : 20.09.2012. u 14:22 Razlog: merge doube post
      24. #130
        Na forumu od
        Dec 2003
        Lokacija
        Dortjol
        Poruka
        5.067
      25. Moja mašina
        • OS: Win 10
        • INET: Kablovska
      26. mogu i razlichite karte, ne treba cf.
        skochio difikalti opet
      27. #131
        Member
        Na forumu od
        Sep 2001
        Lokacija
        Požarevac
        Poruka
        4.436
      28. Moja mašina
        • CPU: Intel® Core™ i5-4670K
        • MoBo: GIGABYTE GA-Z87X-D3H
        • RAM: 2x4GB DDR3 Geil Black Dragon
        • VGA: GeForce GTX760 MSI GAMING OC 2GB
        • MON: 23" Dell U2312HM LED IPS
        • HDD: HDD SATA3 1TB WD Red WD10EFRX
        • OPT: Samsung SATA
        • Case: Fractal Design Define R4 Black Pearl, Cooler Master V700
        • OS: Windows 8.1 x64
        • INET: DSL
      29. Svojevremeno volksbank. Raspitaj se kako je sada.
      30. #132
        Na forumu od
        Nov 2006
        Lokacija
        Novi Sad
        Poruka
        1.966
      31. Moja mašina
        • OS: Win7 64
        • INET: DSL
      32. Skočio? e *mjau**mjau**mjau*, tako sam i mislio ovih dana da će, poslednji put je 06.09. skočio. Za koliko? Nisam kući pa ne znam..
        @Laza - ok hvala, proveriću
      33. #133
        Na forumu od
        Dec 2003
        Lokacija
        Dortjol
        Poruka
        5.067
      34. Moja mašina
        • OS: Win 10
        • INET: Kablovska
      35. za 6.31%
      36. #134
        Member Avatar korisnika [SAJ]ber Kurajber
        Na forumu od
        Apr 2004
        Lokacija
        BGD, Zarkovo
        Poruka
        15.970
      37. Moja mašina
        • CPU: Ryzen 1700 @3.9GHz - Noctua NH-D15 SE
        • MoBo: Asrock x370 Killer SLI
        • RAM: 4x8GB G-skill Trident Z 3200MHz cl14 @3066 cl14
        • VGA: Asus Strix 1080TI OC
        • MON: 40" Samsung LE40C530
        • HDD: Samsung Evo 850 M.2 500GB, Samsung F3 1TB, Samsung F4 2TB
        • Case: Corsair 600T, Seasonic 760XP2
        • SND: Logitech G51 / Sennheiser HD 515
        • OS: Win 10 64bit
        • LAP: Asus E403N
        • TV: Samsung LE40C530, 49" Grundig VLE6621, Samsung 55NU7402
        • INET: Kablovska
        • Ostalo: G15, MX518.
      38. Dobro, nije toliko strasno, ocekivao sam da bude vise. Ja zaradio prvih 1.5e od juce
        Onome kome ima svrhe objasnjavati, nema potrebe. Onome kome ima potrebe objasnjavati, nema svrhe jer su ograniceni - "Ja"
      39. #135
        Na forumu od
        Oct 2007
        Lokacija
        Cuprija
        Poruka
        4.684
      40. Moja mašina
        • CPU: F82
        • MoBo: MPOWER
        • Case: M4
        • SND: AKRAPOVIC
      41. Odrzavanje racuna u Intesa Banku je 120RSD mesecno.
        Dif skace na svakih ~15. dana. Bice sve veci i veci.
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
