@rastafarian Madshi se bavi pisanjem i drugih programa osim madVR. madCollection ne sadrži madVR. Ako ti treba link za madVR imaš ga u prvoj poruci ove teme. Taj link uvek vodi ka najnovijoj verziji.
Pročitaj poruke na prvoj strani ove teme, biće ti mnogo jasnije.
* some more Overlay improvements
* added "enable windowed overlay (Windows 7 and newer)" option
* added "anti-ringing" option for chroma and luma scaling
* added extra "delay playback start after seeking, too" option
* added new calibration option "disable GPU gamma ramps"
* doubled exclusive mode seekbar in size
* added position / runtime information to exclusive mode seekbar
* removed some tweak options (rendered superfluous by new WHQL NVidia driver)
* madVR window is now created and served by a separate thread
* Windows timer/scheduler is now always set to finest possible resolution
* modified DXVA deinterlacing to work a bit more similar to EVR
* AVI Decompressor output is now always considered to be decompressed video
* added workaround to hide kmplayer crash when resizing video
* fixed: crash when multiple madVR instances are created at the same time
* fixed: freeing madVR instance sometimes resulted in a crash
* fixed: VSFilter passes RGB -> input was incorrectly considered limited range
* fixed: bilinear chroma upsampling used MPEG1 chroma position instead of MPEG2
* fixed: switching deinterlacing mode -> "resetting Direct3D device failed"
* fixed: crash when playing certain video files with AVSplitter
v0.83.7:
* fixed: changing video files sometimes crashed
* fixed: showing exclusive mode seekbar for image viewing crashed
* madVR once again waits for D3D to be fully finalized
v0.83.6
* fixed: some more Overlay related issues (black screen, error messages etc)
* fixed: media player closing and loading a different video was slow
v0.83.5
* fixed: starting in exclusive mode, then switching to Overlay -> error
* modified exclusive mode seekbar design slightly
* madVR doesn't wait for full direct3d finalization, anymore
* improved crash reporting reliability
v0.83.4
* fixed: crash when using Overlay mode
v0.83.3
* maybe fixed: shutdown freezes in certain situations with MPC-HC
* fixed: shutdown crash
* fixed: glitch in the debug OSD
* improved "look" when moving Overlay window with Aero on
v0.83.2
v0.83.1
* fixed: Overlay is only activated for GPUs/drivers which support it
* fixed: Overlay stopped working in certain situations (e.g. switching subs)
* Overlay is now not activated by default, anymore
